Hi today i disconnect my dvd player(model:dvp-pq1) room change it and when i reconnect it immediately start to blink the green light and it doesnt want to turn on it keeps blinking. please help me. thanks
    Top Expert:
  • Televison & ... Master
  • 82,149 Answers
Disconnect the player ro 5 minutes then plug it back in, if that doesn't clear the problem the player is defective and it will either need to be replaced or repaired, since these players are so low priced now fixing it really makes little sense, just replace it..
Posted on Dec 11, 2009
Power light blinking on sony dvd player
Repair of a portable unit with a power supply problem inside it is likely not to be economical and parts for these units are rarely available.
No magic wand for this issue--unless was a very expensive unit replace it--
May 02, 2012 | Sony DVP-FX930 Portable DVD Player
When truning on my dvp-ns305 the red light becomes green for just a few seconds. The display begins to show "welcome" but stops before it is finished.
when truning on my dvp-ns305 the red light becomes green for just a few seconds. The display begins to show "wel" but stops before it is finished.
Feb 04, 2011 | Sony DVP-NS305 DVD Player
The round center piece that holds the dvd in place broke. Where can I buy a new one?
I need to know as well. I had the type where you push down and 3 clips retract. When you let go it hold the dvd in place.
Sep 11, 2010 | Sony DVP-PQ1 Portable DVD Player
Where can i get a manual from & can this machine be reprogramed to take region 2 dvds thanks ****
Click Sony Support to download instruction manual of DVP-CX985V and region code can not be changed in this model.
May 31, 2009 | Sony DVP-CX985V Multi-disc DVD Player
Need unlock code.
I found this region hack here Sony DVP-NS575P region code , check it out:
"Warning
The following guide describes how I managed to make my Sony DVP-NS705V DVD player multi-region.
There are no guarantees that you will be able to do the same. Be aware that you will probably void any warranty you have and possibly even break the player.
Put shortly, you proceed at your own risk.
Introduction
First of all, the Sony DVP-NS705V can be made multi-region simply by applying appropriate service codes, you do not need to install a so called "mod chip".
This supposedly applies to the entire NS-series of Sony DVD players. There are some encouraging reports out there supporting this, but nothing has been verified by me. Again, if you choose to apply this guide to any DVD player, you do so at your own risk.
If you do find that this procedure works on another model, please drop me a line at sonyhelp@selen.org and let me know. Include the exact model number and original region of your player.
Update: Some users have reported success on the following players:
DVP-F21 (special thanks to Garry Self for this one)
DVP-LS500
DVP-LS755
DVP-LS785
DVP-NC615
DVP-NS300
DVP-NS305
DVP-NS310
DVP-NS315
DVP-NS330
DVP-NS333
DVP-NS355
DVP-NS360
DVP-NS400
DVP-NS405
DVP-NS410
DVP-NS430
DVP-NS433
DVP-NS575
DVP-NS585
DVP-NS590
DVP-NS700
DVP-NS730
DVP-NS765
DVP-NS900
DVP-NS905
DVP-NS930
DVP-PQ1 (thanks go to Michael Joy for this one)
DVP-PQ2
RDR-GX3 (thanks to Andreas Norman)
RDR-GX7 (thanks to Daniel Tapie)
RDR-GX300
RDR-GX700
RDR-HX900
RDR-HX1000
Please note that not all players behave exactly like the NS705. For example, some players do not display "success" when hacked.
Thanks to all who have contributed.
The infrared service codes required to make the update are available on the Internet. Unfortunately, not many people have an appropriate device to enter the codes into. You basically need a programmable remote (Philips Pronto, One-For-All) or a PDA (Palm, iPAQ) with suitable software.
This guide shows you how to make the update with a regular PC equipped with an IRDA port.
The procedure
1. Download the winsamp -package from Blank Frank's site.
http://www.veg.nildram.co.uk/remote.htm
This innovative piece of software allows you to send standard home electronics IR signals using a PC IRDA port.
2. Extract the package onto a bootable DOS floppy disk.
3. Download this IR code
http://www.selen.org/files/REMOTE.TXT
file and place it in the same directory as the package above.
This file holds the five necessary IR codes converted to the format used by Blank Frank's winsamp.exe. Please do not bother Frank with questions concerning this particular procedure.
4. Boot up your PC from the floppy disk and run winsamp.exe.
If your IRDA port doesn't appear as COM2 you may override this by using an appropriate command line switch. For example, use COM1 by running 'winsamp C1'.
5. Press the 'r' key to load up the codes into winsamp.
6. Make sure your DVD player is in standby mode and your IRDA port is within range.
7. Run the IR codes from 1 to 5 by pressing Enter on each corresponding button.
8. Your DVD player should start up and display the text "SUCCESS".
9. Repeat step 7. Your player should return to standby mode.
10.Your player is now multi-region."
Feb 10, 2009 | Sony DVP-NS575P DVD Player
Unable to properly connect sony dvd to tv to play movie
DVD-3 RCA phono outputs(red & white=audio,yellow=video
I have a DVP-NS700,the same happens on mine.Turn it on,goes green to red(standby),then press eject,it will then power up properly.
Jan 03, 2009 | Sony DVP-NS300 DVD Player
Dvd player is not palying dvd movies but it is paying vcd
get a refund. This fault is a can of worms mate. A road you do not want to go down
Dec 25, 2008 | Sony DVP-PQ1 Portable DVD Player
Staying on standby
Check P611 in power supply. Its a 1.5a 60v pico fuse (yellowish in color). Also disconnect
plugs when in order not to get false reading when checking other components
Mar 29, 2008 | Sony DVP-CX850D DVD Player
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
