Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Whining also The machine whines, slows down, picks up, slows down. Flyhwheel seems stiff. How would you check flywheel for thread caught? Should it go to a repair shop rather thatn keep sewing with this whinin noise.
  • asperry Jan 20, 2008
    My machine is doing the same thing. A bought the machine the end of Dec 06 but didn't take it out of the box until Jun 07 (was waiting on my retirement from work!). I've been using it for about 4 months now. I'm taking mine up to Atlanta to a warranty service center this coming week. My feed dogs also have quite working with the lever - I can manually push them up. I bouth a Singer Simple at WalMart last week just to be able to finish a project I'm working on. The feed dogs on it don't work either. I'm beginning to wonder if maybe my allegience to Singer has been outlived by the people in Chine that are making all of Singer's machines! You can e-mail me offline (stitchesbyanne@gmail.com) if you'd like to know what I find out is wrong with my futie. Cheers - Anne
  • 397 Answers
ASAP....please it might just need service....how old is the machine?
Posted on Jan 20, 2008
Why magnolia not picking up bobbin thread
Despite what the instruction book tells you, do not use the auto downup button to pick up the bobbin thread. Instead pull the wheel toward you and do it manually. Many times the bobbin thread gets caught and the machine halts if that auto down button is used.
Jun 19, 2014 | Janome Magnolia 7330 Sewing Machine
Top thread is making a small loop around the bottom thread which seems tight
It sounds like your top thread is not properly placed in the tension unit. Try retreading. If this doesn't solve the problem, check the tension unit for bits of broken thread which may have gotten caught in your tension. Use a tooth pick to remove any excess lint and debris which may be caught between the tension discs.
May 29, 2014 | Bernina Sewing Machines
Machine stopped sewing even though it sounds like its running
I would suggest taking the machine to be checked to see if the machine has a broken part or jumped time.
Nov 26, 2013 | Necchi 3620 Quilter Mechanical Sewing...
HOW TO FIX SINGER SEWING MACHINE MODEL 223; GREASE WAS USED AND MACHINE IS FROZEN THOUGH MOTOR SEEMS TO BE RUNNING OK
Make sure no thread is caught in shuttle, or around bobbin case, etc. Check "plate teeth" also. Manually turn handle/wheel to engage and slow press pedal.
Is there a burning smell of rubber? Bad motor. Check warranty.
Aug 29, 2013 | Sewing Machines
My problem is between the needle and the bobbin. The tread continues to get caught just below the needle- inside of the machine. The bobbin seems to be lifting up and thread gets caught beneath the needle
Hi. So is this a horizontal hook? Where is the thread getting caught beneath the needle? Maybe on the hook? Check your upper threading to make sure the thread passes through the thread take-up lever. If thread is not through the lever, it wont get pulled up , which can lead to multiple thread loops getting caught on the hook, not pulling off after the rotation.
Apr 15, 2011 | White Sewing 2037 Mechanical Sewing...
Machine is Whining
Any unusual sounds should be checked out by your dealer to prevent serious damage. However, first check the flywheel, on the top right side of the machine, for any thread that were caught between the flywheel and casing, causing the motor to work harder. If not, take it to your dealer.
Jan 18, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
102 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
