Question about Linksys Wireless-G WRT54G Router
My son has a wireless internet laptop
He was able to get on the internet now he cannot
I have a linksys that connects my internet to my computer
I went into it I do not have a host or domin name listed could that be the problem not sure why he had it now its gone
when we tried to set it up says its there but we cannot find it not sure what to try or do
  • Bill Towns May 11, 2010
    What brand and model is the laptop? You might try to reset the router. Another idea is to access the router from a browser (192.168.1.0 or .1) and make sure it is set up to assign DHCP addresses to machines that request access. Make sure that the wireless connection is set up to obtain IP adressesses and DNS servers automatically (unless you have set up your router to give out static IP's). Try these ideas.
  • Jeffrey Polaske May 11, 2010
    If your son trying to connect to the router wirelessly or by cat5 cable? If he is using wireless, what wireless card is he using? What operating system is he using? Have you tried hooking his computer up using a cable? If so, did that work?
    Novelist:
  • 108 Answers
Could be alot of things.
The host name and domain are mainly for organizational purposes, like tags.
If you're using wireless a recognizable CCID is good to have.
If your son is using wireless, he will need to have the security Key, that's set on the Router, in order to go through it. He may be able to connect to the router, but won't be able to go through it to the Internet without the key.
Also, if your son is using a Windows 98 or prior, he will have to use the correct Login credentials. These operating systems don't tell you when you're not using the correct credentials, till you try to do something on the network. More recent Operating systems correct this.
The first step is onto the network, so see if you can see his computer on the network as a "Workgroup Computer".
The second step is through the routers security settings.
Hope something here helps.
Posted on Dec 11, 2009
Trying to run setup wizard on my WRT54G-TM,so i can block other people from borrowing my internet.I have one desk top hooked up and two laptops, works great ,but when i run the wizard disk it tells me...
To test your Internet connection, connect a LAN cable from your computer to the DSL or cable modem and if you can browser the Internet then your Internet connection is OK, then the problem is the LAN cnnection to the Linksys or the Linksys may not configured correctly.
Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link'sconfiguration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jul 21, 2011 | Linksys WRT54G-TM Wireless Router
I have a wireless network of computers, one wired and 2 wireless. in the correct setup, my other acer laptop doesn have internet, but s connected to the router, and this laptop im using CAN connect...
All the computers should have the same NETWORK NAME or SSID.
Recheck the settings and make an adhoc connection for each of the computers to your router.
You can also get a USB wireless adapter to enable ht NO internet laptop and connect them.
Just keep playing with the NETWORK SETTINGS.
Make sure all are connected to the SAME SSID.
Hope it helped.
God Bless You!
Feb 05, 2011 | Linksys WRT120N Router
Laptop says no internet connection
First you need to ensure proper connection and filtering. Make sure the source cable is plugged into the Linksys router first. Direct connections must be made to the router, meaning the cable to your main computer should come from the router, not the main source.
Next make sure that the connection is made. You should see a light on the router indicating proper internet connection. Once this is accomplished, connect your main computer and you should have access to the internet on it.
Now comes the easy but somewhat tricky part (tricky only because icons can vary a little). If you haven't already done so, run the setup disk for Linksys. It's has simple, easy-to-follow instructions to set up your network. Now for the laptop. On the blue bar at the bottom of the laptop screen there should be an icon indicating internet connection. Click on that icon to show available wireless networks. Most likely your Linksys router will show up as a secure network. When you click on that connection it will ask you for a WEP key. That key is usually a 10 digit alpha-numeric key written on the back of the router. Sometimes it's on the box the router came in. Sometimes it requests a 12 digit WEP key, in which case simply add two zeros to the front of that same key. If you set up a password for your wireless network you will need that as well.
NOTE: if you have neighbors close, you should always secure your network with a password.
You may need to shut down and restart the laptop in order for the changes to take place.
It sounds confusing, but once you start you'll find that it's actually fairly straight forward. I hope this helps. Good luck!
Jan 12, 2010 | Linksys Wireless-G WRT54GS Router...
Laptops stopped connecting wireless
how about to reset your router and setup it the proper address by your internet provider..
laptops only connect to the router automatically if you enable it reconnect and detect its network without manually connect internet, this procedure can see in your wireless properties by enabling it.
And also ask your internet provider if theres a problem also with their internet connection.
Jul 18, 2009 | Linksys WRT160N Wireless Router
Can not get the second laptop on the internet with the wireless
The post says he has a router "linksys wireless-g access point router" ???
If it is only an Access Point then Joed is correct you need the router to access your broadband with more then 1 PC
If you have a wireless access router then here are the instructions:-
Easy Solution (you should be so lucky)
Sometimes the value for the Wireless Key is written on the underneath of the router, look for SSID (this is the network name) and WEP or WPA key (called the encryption key)
Alternative Method
In order to find out your Wireless Network Key you must first use a cable to connect to your router.
Once connected check that you are connected to the internet by opening Internet Explorer
The address or the router is usually one of the following values:-
http://192.168.0.1
http://192.168.1.1
http://10.10.0.2
http://192.168.2.1
http://192.168.2.254
Try clicking on each and see if you get a logon box popping up
If you do, that is the correct address for your Wireless router, note it down.
If the box has the username and password completed, then click OK
If there is no value for username try "admin" and for the password try one of the following "password", "admin",
Also try nothing for the username and "admin" for the password
Sometimes the value for these are written on the underneath of the router
Once the router page is displayed, look for an item called Wireless Settings.
Next see if a further option for Wireless Security exists.
The names of these items vary from Router to Router
Once security is displayed the SSID (Network Names) and the WPA or WEP Key can be found.
If there is no security I would set it to WPA or WEP then the original computer connecting will need this value if it is connecting wirelessly
Dec 26, 2008 | Linksys Wireless-G Broadband Router
Xbox 360 live on wireless router
In theory you should be able to "share" your internet connection. I use a Linksys WRT54GS wireless router and I have a Linksys Game adapter on my son's 360. He has not complained about lag or slow server times unless other intensive bandwidth is being used.
Nov 09, 2008 | Microsoft Xbox 360 Console
Linksys wireless-g
It has nothing to do with the brands. I do have different peripherals of different brands and they work well.
Maybe your son's laptop is more recent than yours. When you connect the wireless adapter to your laptop, does it detect the wireless network? I remember having a similar problem on vacation. At the hotel, I could'nt connect to the wireless network. The tech support told me to adjust some settings on my laptop. He said to go to the Network connexions, right-click on the wireless connection and selection Properties. Click on Configure...And select the Advanced button. Then on the list select Power on saving Mode. Other than Max power save mode.
Sep 06, 2008 | Televison & Video
Lost connection on laptop
I would reset the router most of those linksys will have a small hole in the back of them that say reset push it and let it go back to factory default see it that does not fix your prob
May 10, 2008 | Linksys Wireless-G WRT54G Router
Wireless shuts off my laptop everytime I turn it off.
1.You probably have the internet connection shared through your computer..
2. you are either on a different channel or too far away.
Jan 17, 2008 | Acer Aspire 5050-3242 Notebook
Linksys Wireless-G WRT54G Router Logo
47 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
