Question about Riso RZ220 Duplicator
Riso 390 has error code d4-534 - Riso RZ220 Duplicator
  • 3 Answers
I had the CODE D04-534 occur on some of the brand new original cartridges and have been puzzled why they did not work. I tried the following on my Risograph RZ-390UI and it worked:
go into test mode..
turn off machine and turn it back on while holding down the left and right print position arrows.
if the error code shows up.. press the yellow reset button to clear it.. you will then see a number (firmware ver.) press the "C" button on the number pad..
you should then see the display all zeros "0000"
enter 890 and press start.
then when it beep press the "C" again enter 112
when it beeps again press and hold the yellow clear button and the machine will reboot...
HOPE THIS WORKS ON YOURS...
Posted on Jul 08, 2012
  • 318 Answers
The machine do not reconise the ink.At the back of the ink there is a electronic chip that tells the machine what tipe of ink it is.There is a problem with that chip or the ink is not compatible.Replace your ink in most cases this will solve it,but let me know if I can futher assist.
Thanks for supporting us.
Posted on Dec 12, 2009
3 Suggested Answers
  • 17 Answers
SOURCE: Riso 390 has error code d4-534
D04-534 means incorrect ink cartridge set. This could be caused either a) it IS the incorrect ink cartridge, or b) the RF tag that is struck to the end of the ink bottle is damaged. Try a new ink bottle.
Make sure to use RISO ink designed and made specific for an RZ230.
Posted on Mar 30, 2010
  • 17 Answers
SOURCE: Error Code -534 on my Riso RZ 390. Drum is stuck
Why do not feed more than one or two pages
Check if there is dust or if the output is holding paper sheets to pass. It may be that some of the gear output paper is loosely screw on the shaft causing the problem. Also check the registration sensor inside the machine and clean it. I hope I helped you.
Jul 08, 2014 | Riso RZ390 Duplicator
How do you enter user codes on a riso RZ 390
by pressing print position keys Plus 15 & minus 15 at a time with one hand and by using other hand machine power on, and release both keys u will in test mode
Jun 19, 2014 | Riso RZ390 Duplicator
Riso printer 390 u a01 -211 error message
I found a small sliver of a cut master inside the master feed assembly. Once it was removed, the machine worked fine. It was hard to locate,but if you remove 2 gold screws from the top of the master feeder you can gain access to the area.the screws are just below the coil springs for the master assy. lid.
May 03, 2012 | Riso Office Equipment & Supplies
Necesito bajar el driver de la riso rz 390 ui gratis
Please follow this link to download the driver from the original source - Riso:
http://www.risographie.de/riso/index.jsp?page=187&lang=1
Please notice that this site is in German language, but do not hesitate you will find what you need!
Apr 21, 2011 | Riso RZ390 Duplicator
ERROR CODE T04-513 FOR RISO RP 3790
riso rp 3790 no imprime, no copia, me dijeron que borrara errores pero no se donde, creen que sea eso
Feb 27, 2010 | Riso Office Equipment & Supplies
Jan 06, 2010 | Riso RZ220 Duplicator
Error Code -534 on my Riso RZ 390. Drum is stuck in machine and won't release.
Jan 03, 2010 | Riso RZ390 Duplicator
ERROR D17-237(CAN'T DETECT MASTER) THIS ERROR IS ON A RISOGRAPH RZ 390, PLEASE HELP?
Hi
The RF tag on the master roll in not detected. try getting an oem ( original) master roll
these rolls are chiped
Jan 17, 2009 | Riso RZ220 Duplicator
657 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
Adorjani Laszlo
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
