Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
Boiler Shut down
Our boiler keeps shutting down on a blower air, ignition lockut alarm. Three times this week. Does anyone know the cause and solution?
    President:
  • Raypak Master
  • 1,378 Answers
What make and model is the heater? Could be things like debris in the air switch on the blower, air in the gas line, bad flame rectification, bad ignitor, poor grounding, etc...
Posted on Dec 11, 2009
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Boiler ignition failer
Try adjusting the gas to air mixture and flow rate. I don't work well in very cold weather, either. I think that's fairly typical. Even a diesel engine is difficult to start in cold cold weather. Perhaps heating the room where the boiler is would help or at lest insulate the room well. Including stopping any drafts that may be causing a windy condition in or around the combustion chamber.
Feb 06, 2014 | Honeywell Triangle Tube Prestige Solo 110...
Boiler ignition is loud, boiler runs for a few seconds then goes out
flame sensor, air flow restriction or blower not producing enough pressure. clean the flame sensor to start. inspect venting, etc
May 13, 2013 | Jandy Lx Pool & Spa Heater - Electronic...
I have a halstead finest gold combi when I turn the boiler on the boiler goes into its ignition sequence when it comes to ignite the boiler fires but after the igniter stops the boiler cuts out completely...
Difficult to get too specific without knowing if you have gas or oil. Also, I am going under the assumption you mean the burner shuts down, not the whole heating system. That being said, all heating appliances have whats called a safety curcuit. Each control has the ability to shut down if certain critera are not met. There is a sensor that senses light down the blast tube. If no light is sensed in a predetermined time period, then the sensor cuts power to the burner. This stops delivery of fuel so if it does ignite you wont blow up.
(I suspect that the ignitor and burner shut down simultainously.)
It may be the sensor (cad cell eye) is doing its job, however why is the question. Could be a number of things including the fuel delivery, ignition, improper air adjustment, etc.
No qualified professional should diagnose a problem unless they are in front of the appliance. I recommend you find a licensed qualified heating techician. Hope this helps.
Feb 04, 2013 | Water Heaters
Keeps giving a code of ops on boiler and will not kick blower on
Are you certain this is a boiler? Furnaces use blowers; boilers do not.
Could you be referring to an induced-draft small blower motor that normally runs immediately on a call for heat?
Is there an electronic control board measuring about 6 inches by 8 inches visible?
We can help if you give us a model # and brand name. Does it operate by oil, natural gas, or propane (LP)?
Feb 02, 2013 | Water Heaters
We needed to turn the water off at the stopcock to repair a tap and for safety we turned the boiler from all day to off. when we turned the water on again the boiler was off completely. what do we need to...
Hi the temperature control on the boiler should start the boiler as soon as you restore power to it. I don't know if you have a automatic ignition module or a standing pilot. If it is a standing pilot, make sure it is lite.You should have a temperature gauge telling you the water temp., and if it was off all day I am sure it is very cool. Do you have a drain valve on the front bottom of this boiler? If so, and you have a floor drain, turn it on as you may have gotten air in the system causing it not to fire up. If not, open all outside hose bibs/faucets and indoor faucets and let them run for awhile. If the water was drained out from the boiler to repair this tap, its off on its low pressure shut off switch. This is a safety. After bleeding any dirt or air from the system, make sure that you hear the boiler filling up with water. Once it reaches its low pressure cut off, it will fire up and start to heat the water. I don't know how large it is, but it may take some time to reach its cut out switch before it will fire again. Please keep me posted in the comment box. Please rate me on my help to you, and I thank you for this.
Sincerely, Shastalaker7
A/C, & Heating Contractor
Feb 20, 2011 | Heating & Cooling
I have a vaillant ecotec plus 630r1 system boiler, since two weeks ago the central heating part of it is causing problems. Even when i put the heating dial on max most of the rads would not get hot and...
You either have a bad circulating pump or you have air in the system. A little bit of air can completely stop water flow in a boiler system. Your problem is more than likely air though. Each radiator should have an air bleed on it. Turn your boiler completely off. Go to each radiator and open the air bleed. It will be located towards the top of the radiator. After air is bled out, close the air bleed and go to the next one until all have been done. If you have a two story house, start at the lowest level of radiators. When you are finished start the boiler back up and let it run for about 2 to 3 minutes and shut it back down and bleed all the radiators again. If you are making progress and getting more to heat up but not all of them yet, keep repeating process until all of them heat up.
Jan 30, 2011 | Heating & Cooling
Boiler keeps tripping flame roll out switch. boiler is new. boiler also blows t&p when shut off manually.
When you are getting a flame roll out control trip its One of three. Not enough air in the room for a proper combustion. Your chimney/ Flu piping is clogged not allowing exhaust gases to escape or your gas is not tuned properly
Nov 23, 2010 | Heating & Cooling
Boiler leaks when shut down
I hate to tell you this but you probably have a leak in the casting of the boiler...it is very slow... therefore the water will evaporate as long as it is hot and you do not see the water...but if you let it cool , not only will the casting shrink and open the hole a bit, but none of the water evaporates....
After 35 years it is time to replace that boiler...
heatman101
Apr 21, 2010 | Water Heaters
Boiler will not shut off
boiler does not shut off when thermostat reaches temp, i already replaced aquastat but condition still exists
Nov 14, 2007 | Heating & Cooling
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
243 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
