Question about Mitsubishi WS-55511 55" Rear Projection Television
When I first turn on the TV the picture is curved . If I turn it on and off and few times the pictures snaps back and is perfect ?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
This model uses a single convergence chip--STK393-110 and it can cause this kind of problem. The next time it comes on with this trouble go into the customer menu and select convergence.
Select advanced convergence (instructions will appear on the screen) and if the grid of lines is bowed or skewed and will not adjust--you have a convergence circuit problem.
Most of the time you just need to replace the single chip this set uses.
I have START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS SET.
They tell you everything you will need and how to do the repair--I have repaired hundreds of these sets with this problem.
Let me know if you want the instructions--you can buy the part on EBAY for about 12 dollars plus shipping--I can tell you the seller there to look for--I buy my parts there.
If this has helped you rate this solution as I do this here for free.
SD TECH
Posted on Dec 11, 2009
I m intrested for repair this tv by myself please help me and give me step by step intraction .thank you waqarahmad1@hotmail.com
Posted on Dec 18, 2009
When I turn on the TV with the remote first thing in the morning I get sound but no picture. I leave the TV on with the sound on for 30 minutes and than begin to turn it off and on till I get a picture...
does the screen look lit at all? you may have an issue with the sustainer boards (Y and Z). without taking voltage readings at the power supply board it will be hard to tell. if you check, there may be bulging capasitors on the power supply board. if so, that will need to be replaced. you can contact hdrepair for a diagnosis and repair.
Nov 20, 2010 | Vizio JV50P 50 in. Plasma TV
Picture messed up for a while when first turned on, then better
How old is the tv overall? The tv can be repaired.
https://eservice.sony.com/webrma/web/index.do
Follow this link and you can inquire about getting service for the tv.
Thank you,
Lee
Nov 05, 2009 | Sony KDL-46XBR4 46 in. LCD Television
Picture goes off
A temporary solution is to unplug the TV for a few minutes, remove static from the glass with your hand. It is important to unplug rather than turn off. If you have a degauss button you can also press that before unplugging. Wait several minutes or an hour. Then plug it back in. If you have Picture in Picture it may be an issue with that and to permanently solve may need a repair person. The unplugging may get you by for a few days at a time. That's at least better than an hour.
Mar 13, 2009 | Fisher PC-32S90 TV
Hi, have a 50 inch rear projection Mitsubishi. The problem is that the picture is curved and some of the words around the edges are doubled. Its most noticeable when watching sports because the score board...
power transistors in the convergence circuits on this series TV go bad after several years, making the wavy lines around the edge of the screen and 'doubling' of the edges of the text in varied colors which do not converge. Professional repair is required unless you are brave enough to tackle the project yourself and follow some rather simple instructions, buy a few tools from Radio Shack, and save yourself about $500 bucks...which I did on my own 42" Panasonic rear projection set.
Feb 01, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Picture jumps after a few hours turned on
I have a 3 yr old 55 inch mitsubishi TV and when I turn it on the green light starts flashing and I must reset the TV about four times before it finally comes on has anyone had this problem if so what solution did you have?
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
The tv made a loud snapping noise with a white snowy picture. The tv had to be unplugged since it could not be turned off with the remote. When it was plugged back in, the picture returned for a few...
This is caused by a capacitor on the power board going out. The unit is under warranty, but because it is under 30 inches, will have to be mailed back to California. They will replace 2 boards for you: The main board and the Power PCB. This will fix you good as new.
Jun 05, 2008 | Televison & Video
Blurry Curved Picture
Convergence IC's need to be replaced...change them both..
part # STK392-560.....Check soldered-in fuses...........T.
Dec 25, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Rca 52 inch keeps shutting off and picture is curved
The curved picture indicates failing parts in the pin amp section and probably some faulty parts in the scan amplifier sections. The set is being turned off by the uPC because there is a fault indicated, and it is going in to protect mode.
The set will have to be properly serviced.
Jerry G.
Aug 21, 2007 | RCA 32V420T 32" TV
Mitsubishi WS-55511 55" Rear Projection Television Logo
117 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
