My maytag dryer turns but dosent dry - Washing Machines
  • Washing Mach... Master
  • 22,326 Answers
Either the heater coils have packed up or the thermostat switch has arced contacts so their not passing current ,not sure on this model as its american as to weither the switch is accessable as such to get to the contacts ,Also look for on the back of the drum for an emergency overload heat sensitive switch .and make sure its not bunged up with fluff which will trigger the heat switch to cut out.
Posted on Dec 11, 2009
My maytag dryer does not dry clothes, it takes upwards of two hours to dry a normal load. Tub turns, timer works, exhaust vent is clear, just doesn't dry.
Your dryer needs a new heating element. Any good Maytag repairman can put one in. If you are very handy you can do it yourself but if not it should not be an expensive job.
Mar 22, 2010 | Maytag PYE2300AY Electric Dryer
Maytag gas dryer wont turn off when done drying in auto dry regular fabrics. does turn off in air fluff and auto dry perm. press. model # d3382
auto dry relies on a moisture sensor to say when its done. so your clothes arent dry enough according to sensor. perm. press. doesnt dry the clothes as much
Aug 01, 2009 | Dryers
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
one thing u can do remove vent tub,
turn on dryer run for about two min
open door touch inside door if hot
u have a vent problem
May 12, 2009 | Maytag PYG2300A Gas Dryer
Electric dryer not drying clothes
The electric dryer requires 220 volts to dry clothes but only 110 volts to turn the drum .reset your circuit breaker even if it looks ok ,if that dosent work, unplug from the wall and check where the plug wire goes into the back of the dryer and look for loose or broken wires.
Apr 26, 2009 | Estate TEDX640JQ Electric Dryer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
MY MAYTAG DRYER IS SLOW AT DRYING
Have you checked it for fluff. Also if the vent is blocked it wont dry properly.
Mar 22, 2008 | Maytag HYE3657A Electric Dryer
Maytag Neptune Dryer--Drying Problems
clean out your vents going out your home have someone also clean out the lint that has been pushed in side your dryer
Mar 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
