Question about Linksys Wireless-N WRT150N Router
Hi, Lately I forced to rebut all wireless network (pc + modem + router) every day. Can you please send me any leads to resolve this problem before I am going to bay some expansive router. Thank you, Leon
  • davidkeegel May 11, 2010
    What are the symptoms before you reboot your wireless equipment? Can you try rebooting one device at a time and then test afterwards to see whether rebooting one or two of them makes the symptoms go away? (So one day you might try rebooting the PC first, next day you might try rebooting the router first, etc.)
  • 39 Answers
The first idea to try is to make sure there is not an over heating problem. Make sure the router and the modem are not sitting on each other, and make sure there is plenty of room in between them. If that doesn't fix it, reply back.
Posted on Dec 21, 2009
SOURCE:
How do i connect the belkin n+ wireless modem
Connect a computer to any one of the four LAN ports of the Belkin wireless router.
Launch your web browser on the computer. In the address bar, type http://192.168.2.1
Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit and you will be able to login to the router.
To setup your wireless network, perform the following steps:
1.Disconnect or turn off your broadband modem.
2.Connect the wireless router to the broadband modem through a network cable and then turn it on. You will have to plug in the network into a port called Internet, WAN or WLAN. The other ports on the router are for sending and receiving information to other devices on the wireless networks.
3.You can now connect to the internet via the router with the help of the wireless network card installed on your pc or laptop. The wireless card on the computer has to be turned on for it to recognize and connect to the wireless network.
You can check if the wireless network has been successfully setup by accessing the default router address via a web browser. You will be prompted for a username and password. After you have entered the default username and password, you will be directed to the routers configuration page. For your router, please use the address 192.168.1.1 Username "admin" and password "admin" (without the quotes), in case the blank does not work.
If this doesn't work for you, please comment and let me know, and I will be happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this free solution.
Thank you.
Oct 23, 2010 | Belkin F5D7234-4 Router
Hi, I have a problem lately where my modem was malfunction and replaced. However after replace a model and confirmed I can direct link to internet from any of my computers, I now face a problem when I...
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 23, 2010 | Linksys Wireless-G WRT54G Router
Is Netgear Route WGR614V5 compatible with Windows 7?
Please note that this router is compatible with Windows 7. Please perform the below steps on your Windows 7 computer to connect to the wireless network:
1. Click START, Click Control Panel.
2. In the main screen, open up NETWORK AND INTERNET.
3. Click on Connect to a network.
4. Select your network and connect to it. If you have a Password setup on the router enter the security key.
5. This should setup the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jan 04, 2010 | NetGear WGR614 Wireless Router
Configure Modem Echolife HG520s With WRT54G OR WRE54G
Not sure if I understand properly but your router should have a WAN port or an "Internet" port
your modem should be connected to it and your PC should be on any of the LAN port
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
WLAN is not working
Hi masif - please don't rate this yet! Unplug your modem and router. After 60 seconds plug in your modem. After the modem lights return to normal, plug in your router. Give it 15 seconds and then try it. Let me know what happens.
Jeff
May 22, 2008 | Toshiba Satellite Pro 6100 Notebook
Hi i cant connect to internet
I don't know why this is posted in UPS problems, but anyway...
Try two things--the easiest is to turn off (unplug from power) your router and your modem. Let sit a few minutes, turn back on, then see if that has done the trick.
If that doesn't work, you may simply need to go to network and sharing center if you have Vista, click on "connect to a network", and see if your router is found as a wireless connection available to you. If it is, just click on it, and you are in business. If you can't find your router via the windows utilities, (various other things to do are in "help"), you may have to
reconfigure your router setup by resetting your router to its virgin state--usually by pushing a paper clip into the reset hole in the router--usually mentioned in the directions. Then just reconfigure it according to directions, and you are in business.
Jan 12, 2008 | Computers & Internet
Can see my network but wont connect
Yes you may trying chaing the channel to 11, because i have hear that chaning the channel will resolve this problem
Oct 23, 2007 | Belkin (F5D9230-4) Wireless Router...
Card does not acquire ip address. repair does not work defaults to 169.254.244.38
What is the network adapter connected to - a modem or a router? Is there any other computer or device that is connected to that modem or router and is able to acquire an ip address? This would generally happen when the network adapter is not able to automatically negotiate with the connected device (which might have 10/100 ethernet ports). You can resolve this by forcing the network adapter speed to, for instance, 100 mbps. Please revert back with further observations.
Apr 16, 2007 | GigaFast Ethernet EE110-AXP (EE110AXP)...
Linksys Wireless-N WRT150N Router Logo
69 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
