Question about Moen 7437 Chateau Single Hole Kitchen Faucet with Side Spray Chrome...
How do i remove the cartridge from a moen pull out spayer
How do i remove the cartridge from a moen pull out sprayer, mine is leaking and i would like to replace it.
    Champion:
  • 244 Answers
Call moen. get free new cartridge. with white plastic tool and vce-grip, you'll get it out.
Posted on Dec 18, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 35 Answers
There is a tool for this job. Its a stem and cartridge puller made for moen fausets.PASCO makes one in my area.Ask a sales rep at a local plumbing supply.The rep should be able to sell you one ,or tell you where to get one.
Posted on Dec 12, 2009
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Moen 2 handle bathroom faucet is leaking out of base of the left handle
    There is a plastic retainer not with two tabs used for removal. You will need a removal tool to get this retainer off. Any plumbing supply that carries Moen should have this tool.
    After removing the retainer nut, the cartridge pulls right out. Good luck!
    May 23, 2017 | Moen Kingsley Two Handle Bathroom Sink...
    2 year old Moen 87845 began leaking at handle - some water coming out where it attaches to deck, some leaking out from under sink. Do I need a new cartridge? Also, when using sprayer, not all water is...
    Yep, you have a bad cartridge and a diverter, the handle leaks all come from the cartridge
    just remove the handle expose the U clip that keeps the cartridge in place. This is were yo will need a handle puller to extract the old cartridge. When you get it out make sure you clean out the inside befrore you place the replacement unit it. If not the junk will mess up the work you just did.
    Make sure you use a food base lube to make surre the new one going in with out cutting O rings.
    While you have to spout removed youo will see the diverter and pop that iut and put in a new one and the water to the spray unit will work like new.
    Hope this helped you out, Be safe and take care
    Tom
    please take a second to rate us for its the only way if we know what kind of a job we did for you.:)
    Sep 10, 2011 | Moen 87845 Quinn Single Handle Kitchen...
    Trying to change cartridge on Moen single lever kitchen faucet with sprayer. Now that it's been reassembled, gets no water from spout when turned on. When lever is turned on, sprayer goes off and...
    Moen has a diverter built in that will need to be replaced.
    use the same steps as when you replaced the cartridge, but this time you will need to remove the spout, there is a small diverter, you will see it when spout is removed.
    take this part with you to the hardware store, along with the O Rings from the spout, as they will need to be replaced also
    use a non silicone faucet lubricant when putting back together
    Aug 08, 2010 | Moen 7437 Chateau Single Hole Kitchen...
    Have a Moen single lever kitchen fawcet with seperate sprayer and it drips. I poped off the center cap on top of the fawcet and can see a cartridge but don't know how to remove it. It's brushed chrome.
    Most MOEN single handle faucets use the same cartridge, the 1200 or 1225. If you have it apart enough to see the top there should only be a few more parts to remove to get at the stem ie the handle and cap. Once there you should see the horse shoe clip that holds the stem in. Once you slide the horse shoe clip off, the stem should be ready to go. Now sometimes these will come out easily, but most of the time they are a little tough. You can use a crescent wrench and gently turn the cartridge at the ears where the horse shoe clip was removed and this will loosen the cartridge, then you can use the handle or what ever you can grab the stem with to pull it out. FYI a lot of the home improvement stores carry a MOEN cartridge puller and they make it a lot easier. After cartridge is removed install new one and your done. DONT forget to turn off water before you begin. Hope this helps.
    May 13, 2010 | Plumbing
    I have a Moen kitchen faucet with a leak.
    By "leak in the stem" I assume you mean you're getting water in the cabinet below the faucet. High likelihood is it's the hose - either loose where it connects to the faucet or the sprayer. You can pull it out and check to be sure it's tight at the sprayer. To check the faucet end, you'll need to be under the cabinet with a light. If you don't find one of those connections loose, it's likely one or the other is leaking, due to a hose defect or washer (or missing washer).
    The only way to see that is to turn the faucet on full (cold) with the sprayer pulled out and look for a leak in the hose behind the sprayer. If not there, leave the water running (may need another person to hold the sprayer) and inspect under the cabinet with your light for a leak either in the hose or at the connection to the faucet. If the problem is the hose or one of the nuts, it's an easy deal to buy a replacement hose - Home Depot stocks Moen.
    Feb 02, 2018 | Moen Plumbing
    Moen one handle tub & shower is leaking from spigit
    A stem is a cartridge in a real old valve. You have pulled retainer clip, you can try to pull it out with pliers, but you might need a moen cartrigde puller.
    Sep 06, 2009 | Moen & One Handle Tub & Shower Faucet
    Moen One-Handle Kitchen Faucet Leak - Hot Only
    http://www.moen.com/browsecatalog/catalog/specpartsearch.cfm?location=TopNavCustomerSupport
    Moen uses a cartridge on their faucets. You have to remove the handle. You will find the stem and a small U shaped retainer. Pull the retainer out and pull the cargridge straight up. Sometimes the cartridge is in there pretty tight and you have to pull hard. Once you do this, take the cartridge to your local hardware store. Replace it with the one you have because they have 2 different one. Install it back in the same order it was removed. Hope this helps and good luck.
    Apr 10, 2009 | Plumbing
    Moen 7437 Chateau Single Hole Kitchen Faucet with Side Spray Chrome... Logo
    544 people viewed this question
    Top Moen Plumbing Experts
    john h
    Don Numinen
    Don Numinen
    Mike
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
