Question about Foxconn 45CMX socket LGA775 motherboard (16897)
Toshiba nb205-n311/w won't boot - Foxconn 45CMX socket LGA775 motherboard (16897)
  • 728 Answers
There could be many things that could stop the board from turning on, Determining if it works is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Also, if your going to load a ide drive, make sure you set your pin setting correctly on it. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four to see if you get any change. If no change, then I usually get another board that I can test the first four, and make sure that they work. After that, then I say you have a DOA Board
Good Luck and don't forget to leave a rating.
Thanks
Mark
Posted on Dec 13, 2009
I have the same problem with my nb205. you might want to look at this toshiba forum. it's a saga, and the (spoiler alert!) ending is the final post, which requires sending back for repair--provided you're not outside the 1 yr. warranty. the descriptions on the page describe my problem to a tee. since you didn't give much detail, not sure what you see or don't (e.g. I have power on light, but black/blank screen, and a hdd light which stays on only for first 2 seconds, max), but you may want to give this info a look.
Posted on Jul 27, 2010
2 Suggested Answers
ganesh_tag
  • 106 Answers
SOURCE: built in HDD/SSD shows None
hard disk power cable and data cable may be loose
Posted on Feb 13, 2010
My toshiba netbook nb205 n311/w won't load windows xp, stop message: 0x0000007B
0x0000007B = INACCESSIBLE_BOOT_DEVICE This means that the hard disk is corrupted and/or defective and the only thing you can do is to replace it and reinstall Windows.
Apr 30, 2011 | Toshiba NB205-N311/W Netbook
Nb 205 blank screen
Is your screen blank when you are trying to turn it on? Do the fans run and such but nothing shows up? If not then I don't know.. but if it is put you laptop in the freezer for an hour. Mine had that problem, but you won't be able to turn it off... ever again... because then it won't start up again. I would suggest to check this out as well if it is that problem. http://www.techsupportforum.com/forums/f108/toshiba-nb200-wont-boot-492391.html
Apr 02, 2011 | Toshiba NB205-N311/W Netbook
My Toshiba NB205-N311/w will no longer connect to the internet. I have tried the Function F8F8 to ensure the wireless is on but nothing happens. The green bars all say I'm connected to my wireless network,...
Go to TOOLS-INTERNET OPTIONS. Go to the CONNECTIONS tab at the top. Go to the bottom where it says LAN SETTINGS. Make sure only AUTOMATICALLY DETECT SETTINGS IS checked and nothing else.
Mar 13, 2011 | Toshiba NB205-N311/W Netbook
USB ports stop working
All of them? That is weird. You can try uninstalling the USB Root Hub devices in the device manager and see if they work when they get reinstalled (happens automatically).
Some more ideas:
http://www.pcauthorities.com/drivers/usb-device-not-recognized
Mar 30, 2010 | Toshiba NB205-N311/W Netbook
I've installed a couple of programs and get a "regedit" error to "update". How do I update the regedit?
Hello,my friend regedit is system registry editor.The message you received says that your program was unable to be installed because regedit failed to update (manipulate/edit) the system registry.So find out which program u have installed is not working properly,uninstalled it and the next time you want to install it try right click and run as administrator.
Feb 06, 2010 | Toshiba NB205-N311/W Netbook
RecoveryDisk Creator does not offer any disk selections to create
To access the recovery partition you need to boot up on a DVD with a partition manager on it, then set the hidden partition as "ACTIVE" and un-Active, the existing partition, then remove DVD and reboot, then the laptop will boot from the recovery partition and should autorun start the recovery procedure.
Jan 28, 2010 | Toshiba NB205-N311/W Netbook
Foxconn 45CMX socket LGA775 motherboard (16897) Logo
1,973 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
