Question about Fuji FinePix S5200 / S5600 Digital Camera
Fujifilm s5200 digital camera
The button/lever on the camera that turns it on and snaps the picture came off. Is there any way to repair that?
SOURCE: I need to Repair my Fujifilm Digital Camera
I had the same problem with my S3100. Last year I sent it back to Fuji and the power board had to be replaced. It cost around $80.00 to get fixed. I got the camera back last Xmas and I am having problems again. You can call 1-800-800-3854 and talk to their repair dept. I am going to replace mine, it is ridiculous that you spend all this money on a digital camera and then have continuous problems. I have always had Fuji cameras and liked them, but I think I am going to try another brand.
Posted on Oct 28, 2007
SOURCE: zoom error message on fujifilm a350 digital camera
whilst reading out loud instruction to fix the 'zoom error' my wife turned and twisted the zoom lens clockwise and shake th camera gently - all of a certain it worked again as per normal - try it - hope it works for you too!
Posted on Feb 26, 2008
  • 75 Answers
SOURCE: FUJIFILM 3X OPTICAL ZOOM FinePix 4.0 mega pixels digital camera A340 its about the xd-picture card 2GB
Be sure you have formatted the card, not the internal memory (if the camera has that).
Be sure your battery is fully charged, so that the device can fuly write the file.
Be sure you are writing the file to the card, and not the internal memory, as there may not be enough space on it to write the file.
If this does not resolve the problem, let me know.
Posted on May 30, 2008
  • 1952 Answers
SOURCE: finepix s5200 camera
Try buying lense cleaner to remove fingerprints, smudges and other 'particles' from the optical lense. Call Fuji, let them advise you.
Posted on Sep 10, 2008
  • 1447 Answers
SOURCE: how to take black an white pictures with the fujifilm A850
check in the settings if you have option for sepia or grayscale. choose this and photos will be in black and white.
Hope this helps
Posted on May 13, 2009
  • 6831 Answers
SOURCE: My fujifilm finepix S5200 camera
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Posted on Sep 21, 2010
0 characters
1 Points
My Fujifilm FinePix A800 is not displaying any image
This camera needs to be sent away forrepairs. Just like a motor vehicle, some repairs to your camera require atechnical specialist to fix your problem.
Apr 18, 2012 | Fuji FinePix A800 Digital Camera
I have a Fujifilm Finepix S5200. Need to know if there's an option to set a 2 second timer PERMANENTLY, and not have to set the 2 second timer every time i take one picture. Thanks -Leo
I'm sorry, but I don't believe that can be done. The settings for the timer should clear after you power cycle the camera. The timer is not the default setting, so it reverts.
Thank you.
Mar 23, 2011 | Fuji FinePix S5200 / S5600 Digital Camera
I am looking for a replacement operators manuel for a Fuji Finepix S5200
Try looking under S5600 on the fujifilm uk website. The manual is identical because it is the same camera. The S5200 is the S5600 in the usa
Dec 30, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
I have no picture coming through on the screen or viewfinder, just hazy purple with jumpy lines. Fujifilm model#s5200. Pictures on card i can view. Any ideas? Rob from Ontario
That is strange, maybe taking the batteries out and putting them back in could reset the camera to normal. Electronic problems are real tough.
Nov 29, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
Power on to take picture, but view finder is dark, and snapping a picture, provides a black picture.
Probably the CCD is dead. It's a well known problem with S7000. It's a hardware problem, the CCD has to be changed. For S7000 it usually comes with the lens and it makes the repair quite expensive. It's about 250-300$ here. You should contact your local Fujifilm service center.
I work in a camera service center authorized by Fujifilm.
Sorry for the bad news!
Aug 01, 2009 | Fuji FinePix S7000 Digital Camera
Can't get it to picture mode
This camera's playback function works through the lever around the shutter release button. Change it to picture taking mode (the red camera icon).
Feb 14, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
Back buttons frozen
Yes im having the same problem ,however i open/disassembled my camera and my results was a broken ribbon connector from the Rear Button Board to the Main circuit board.....
The only problem is i can not find any parts list information or where i can get this part....
can any one help me with this??
FUJIFILM F460 Camera
Rear Button Assembly
Dec 13, 2007 | Fuji FinePix F470 Digital Camera
Fuji FinePix S5200 / S5600 Digital Camera Logo
97 people viewed this question
Top Fuji Digital Cameras Experts
Steven Wander
Steven Wander
Are you a Fuji Digital Camera Expert? Answer questions, earn points and help others
