Question about Garden
My Troy-bilt Storm 7524 snow blower goes off after 10min running
My Troy-bilt Storm 7524 snow blower always starts on first or second pull. However, when it runs about 10 min, the engine goes off and I cannot start it right away. I need wait a while to restart it. Also, engine goes off when I blow heavy snow. What could be the problem? Thanks
  • 108 Answers
It sounds like it may be you armeture[coil], it heats up and stops.
Posted on Dec 22, 2009
SOURCE:
Not getting spark troy bilt snow blower model 7524
1st disconnect the auger /drive safety kill switch wire , see if it starts ? no? then it's most likely a bad ign modual or ign coil yes? then look at auger/drive control handle , i bet the spring broke and its not moving all the way up to disengauge the auger or drive
reconnect safety wire before using machine
Feb 23, 2015 | Garden
How do you adjust steering on a storm 3090 xp ?
howdie the Pins in the front adjust the holes According to your Height or lower them Thks For your Time
Sep 04, 2014 | Troy-Bilt Troy Bilt Storm 3090XP Snow...
How can I adjust shift lever to shift arm? troy bilt storm 7524
if you have followed your manual for adjustments on page 10 of your manual then check your friction disc and friction plate. If your disc is worn then your cannot compensate for that replace disc and or plate
Aug 16, 2014 | Garden
Troy bilt repair manual
Check with the engine manufacturer if you have trouble with Troy built.
Aug 03, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Remove rim from Troy bilt snowblower?
Excellent. Put some grease on the axle before you put it back together so it comes apart next time.
Aug 02, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Augur wont turn on troy bilt model 2410 snowblower,stall s out when i engage the augur
ICE OR HARD PACKED SNOW IN BLOWER HOUSING
warm up or pour hot water down chute to thaw out
Feb 13, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
I have Troy-Bilt storm 7524 snow blower which normally works fine, however, it has started to have problems shifting back into forward gear after being reversed. I'll put the snow-blower into reverse gear...
Try lubing the linkage where it shifts from forward and to reverse the linkage is most likely freezing up or has snow or ice build up causing it not to shift, My thought is your shoving it hard enough that it finally engages when you get the snow or ice to break off.
Jan 05, 2010 | Garden
Garden Logo
794 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
