Question about Baby Gear
Back wheel wobbeling its about to fall off where can i get replacement wheels from
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 274 Answers
Contact www.buggypitstop.co.uk they should be able to help you.
Posted on Dec 11, 2009
Why does my rear passenger wheel in my 1992 ranger still wobbel really bad even after replacing the rim and tire with brand new ones? What could the problem be i need help pleaseeeee!!!
You need to remove and refit wheel as it sounds as if it has not reseated properly.if it has been fitted correctly and all nuts tightened then any further wobble is either due to wheel balance ,,,, or due to compromised structure supporting wheel which need to be checked immediately..i.e. Drive shaft ....axle.....wheel bearing etc.
Feb 19, 2015 | Cars & Trucks
ABS and Advance track lights go on and off, but sometimes not always the front brakes feel like the are locking up (actually feels like the wheels are gonna fall off) replaced the sensor (in the back) that...
Sometimes if your rear sensors are in the brake backing plates, you will get debris from the Emergency brake pads and this will affect the sensor count. As the wheel revolution is perceived to be different from one rear wheel to the other, the Traction Control system automatically activates and applies the brakes to make the wheel revolution match on both back wheels.
The Emergency brake linings can fall off of the shoes and create this problem. The brake pads in the front can also separate from the front discs and make the ABS warning illuminate.
Best have a Brake shop remove the rear brakes as they can be a pain to get off when the Emergency brake linings grind up.
Sep 28, 2013 | Lincoln Navigator Cars & Trucks
When pushing my quinny the back wheel starts to come of byitself
Hi Lisa - It could be that if there is dirt and debris on the wheel axel or inside the connection it would prevent the wheel clicking in properly. Remove both back wheels and give a wash in warm soapy water then dry thoroughly before putting back into place. Does the same side wheel fall off even if you swap the back wheels over? If this is the case it would indicate a chassis problem rather than a wheel problem. If it is the same wheel that always falls off it would suggest a wheel problem. Contact customer services on 01284 413 141 Mon-Fri 8.30-4.30 or e-mail to uk-customercare@dorel.eu for further advice
Nov 14, 2011 | Quinny Buzz 3 Stroller
My older Maytag dryer is making the classic rumbling noise when running. Heat seems fine. I can turn the tumbler by hand and sound like one of the tumbler wheels is vibraiting or wobbeling. what else...
Replace all drum wheels. I would replace the idler pulley and belt if the belt looks worn. Check front and rear felts for excessive wear. Check the blower wheel. Here is a link that should help
http://appliancehelponline.com/dryernoisyge.html
Aug 09, 2010 | Maytag Dryers
To much wobbel in back wheel
Sure you replaced all the spacers?
Mar 24, 2010 | 2006 Gilera Runner VX 125
Car shaking and pop nosie from passenger side wheel
Why drive side bearing could be a bad other.balance yes, tie rod could be bad.
Mar 16, 2017 | 1996 Ford Windstar
Wheels keep falling off on lower rack, clips all
the clips come with new wheels, they should cost about $4 for four, I would replace all wheels on the lower rack
Nov 17, 2009 | GE Nautilus 24" Built-in Dishwasher
Evenflo Tandem stroller back wheels replacement
You may be able to remove the axle of the new front wheels and remove the wheel from the assemble, and then do the same with the rear wheels. Next replace the axle with a bolt and nut.
Dec 19, 2017 | Baby Gear
Lost silver wheel hub from back wheel (wheel can come on and off for stoage), now wheel falls off when in transit.
I have a problem with my buggy how do I get it resolved?
Your first step is to contact your original place of purchase. The retailer has a great knowledge of our products and will be able to arrange a repair/replacement part where necessary.
If the product fails in the first year of ownership due to a manufacturing fault we will repair it free of charge. If it is not practical to repair it we will replace it.
If the product fails due to wear and tear, accident or negligence, or if it is outside the warranty period, we will happily repair it for a reasonable charge. Please note as outlined in your instruction booklet the customer is responsible for freight charges if the product is required to be sent to our repair agent.
UNITED STATES OF AMERICA
Distributor
Regal + Lager
1100 Cobb Place Blvd
Kennesaw GA 30144
USA
Tel: 770-955-5060
Fax: 770-955-1997
Website: www.regallager.com
Apr 25, 2008 | Phil & Teds Explorer V2 Twin Stroller
Baby Gear Logo
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
