Motherboard up grade Packard bell
I have an imedia 4506, I have a new flat screen and keyboard, mouse etc.
I need more speed and Ram, so consider to chage the mother board, what would you suggest?
    Genius:
  • 1,067 Answers
What cpu do u have ? amd or instell what soket
Posted on Jan 20, 2008
  • nick helpap
    nick helpap Jan 20, 2008
    CPU Support
    • Supports Intel Celeron FC-PGA (Flip-Chip Pin Grid Array)
      • 533/66 MHz to 766/66 MHz
      • 800/100 MHz to 1100/100 MHz
    • Supports Intel PIII Coppermine FC-PGA
      • 450/100 MHz to 850/100 MHz
      • 533/133 MHz to 1200/133 MHz
    • Supports 32-bit AGTL or AGTL+ bus addressing (no support for 36-bit address extension)
    • 66/100/133 MHz Host Bus speed processors are supported
  • nick helpap
    looks like ceron fc pga style harder to get with max 800 fsb ok
Imedia 1414
would upgrade to better board first jim
Mar 20, 2014 | Packard Bell Computers & Internet
I want to update my graphyc card to ASUS PCI-E ATIRADEON 7770. IS IT COMPATIBLE WITH MY MOTHERBOARD PACKARD BELL RIO ID0027?
If your PC has a PCI-Express graphics slot, then there should be no reason why the graphics card should not work. Make sure you have the correct drivers for your graphics card and it should all be fine.
Best wishes,
Graeme.
Jan 05, 2014 | Computers & Internet
Packard bell imedia MC2569 show no signal on monitor
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Test all power and data leads that attach to your hard drive IDE,SATA the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty if its a 40 pin flat ribbon type it will be the first to fail make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even something as small as a faulty electrical fan and its lead can cause you problems computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error Check your RAM. The RAM is located in the middle of the motherboard. There are tabs that you can push to release the RAM. Remove it and put it back in place until the tabs pop out. Loose RAM can cause your computer not to start properly where you want to see a video signal.
Make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free Restart your computer then reinstall it this should activate found new hardware wizard Check the vga lead for secure dust free connection or try another vga lead.
Feb 07, 2013 | Packard Bell iMedia SL 9553 (P660401806)...
What kind of ram is there in the machine N3600
here download this.. it will give you a detailed overview of your pc.. including ram, motherboard, cpu , etc!
http://www.cpuid.com/downloads/cpu-z/1.56-setup-en.exe
akuma_ryu21
dont forget to rate
Jan 23, 2011 | Packard Bell iMedia 6826 (P481000502) PC...
I have Packard Bell iMedia 5094 (P660403401) which is very slow on start up and running programs can upgrade or add to the memory to speed it up
Howdy. unless you are doing nothing but very basic word processing, that computer will not run most modern programs well or at all. There is no way to speed it up enough to match current applications. A variety of faster machines are available for as little as 200 dollars. You can keep your mouse, keyboard and monitor and just replace the tower, or get all new for just a little more. walmart, tigerdirect dot com or overstock dot com have a bunch of deals. It's cool that it still works, though. you must keep it pretty clean. Farmerbear at FixYa
Oct 19, 2010 | Packard Bell iMedia 6826 (P481000502) PC...
When switched on, my packard bell imedia 1508/2 sounds long beebs and dosen't send any sign on the screen.no message shown.
Your RAM is not working properly. Remove your RAM from your RAM slot brush it with a dry brush and reattach in your RAM slot, if not then your RAM slot is damaged.
Jun 16, 2010 | Packard Bell iMedia 6826 (P481000502) PC...
How do i upgrade my packard bell imax mini n3600? i want it to wrk better as a gaming computer
This is a media PC and not meant for hard gaming. My advice don't waste your money on this PC to turn it to a gaming PC. The components are all built-in onto the motherboard except for the RAM & HDD.
May 31, 2010 | Packard Bell iMedia 6826 (P481000502) PC...
Packard Bell IMedia 5055: GA-8SIML will not post or boot. Removed all PCI cards,RAM,Hard drive, optical drives etc. Only CPU and mobo but no post/BIOS screen. CPU fan runs and front panel LEDs work. Do get...
Put just the ram back into the motherboard, the pc will not boot without processor, ram and graphics pluged into the board, check this, if it will still not boot and you still get 3 beeps its a memory(ram) problem, and you will need to replace the memory stick.
Feb 04, 2010 | Gigabyte GA-8SIML Motherboard
Continuous beeping sound
you can see out put in screen if no you must chek ram's
else you should remove your keyboard and mouse in test ather
Dec 16, 2007 | Packard Bell iMedia SL 9553 (P660401806)...
Led pins
I think you will have the an instruction manual of Packard Bell imedia 5106.In the manual an outline of the motherboard will be given.Figure out power and reset pins in the diagram given.
Usually the pins are at the corners only.
There will be labels near the pins like pwr rst etc.
Try connecting in the same configuration.
Please Rate me ;-) >Karatela
Dec 07, 2007 | Intel Motherboard
Computers & Internet Logo
765 people viewed this question
David Payne
David Payne
