Question about Siemens Lands Phones
I have 2 handsets from Siemens Gigaset A180-A185 that do not work that once did. tried re-registering them but to no avail any ideas? Jim
CORDLESSGURU
  • 106 Answers
SOURCE: Registering a base station of Siemens Gigaset 2415 Cordless Phone
To register your handset to that base station, you must put the base station in registration mode at the same time you put the handset in registration mode. This is how you do it. At the handset you push OK when it asks you to register. If it asks you for the pin enter 0000 (factory pin) and push OK. The handset should say "registering base 1". Then at the base press the page/reg key down until it flashes (its to the immediate right of the cradle where you rest the handset for charging). That puts the base in registration mode and now its looking for the handset and vise versa. Now watch your handsets display. If it asks to to select an intercom number, then push ok and your done. If it says "invalid pin" then you need to reset your pin on your base (thats a different problem see below). If the handset times out and never registers, you need to repeat the process a couple times, you may have a bad base or it needs to be defaulted. If you need more help you can download a manual for free or get free technical help at the link below.
http://www.barclayent.com/manuals/Gigaset%202415%20User%20Guide.pdf
If you need to default your pin, you can do so but it will default the base station to factory settings. To do so remove the power from your base, hold your page/registration key down, and apply power back to the base. Count to 15, then let off the key. Turn off the power, count to five, then apply power again and follow the steps again to register the handset and you will need to reregister every handset that was previously running on it.
Posted on Feb 10, 2008
  • 3230 Answers
SOURCE: need a manual for siemens gigaset as185 or as185
Well you can please follow the below link to get your manul -
http://gigaset.com/medias/sys_master/A31008-M2026-L101-1-7643_en_GBR.pdf
Good Luck!!
Posted on Apr 02, 2010
fathitkf
  • 1871 Answers
SOURCE: user manual for gigaset ac180 in english
Hi :
I have found this User manual SIEMENS GIGASET AL 180 for you .. Some times a manual for a close product to yours from the same manufacturer can help .
I hope it will help you ..
Please don't forget to rate !
Posted on Jul 09, 2010
SOURCE: I want to register my Siemens Gigaset AL145 Phones
1. On the base station:
press and hold the registration/paging key
(¢ page 1) for min. 3 sec.
2. On the handset:
within 60 sec. of pressing the registration/
paging key
MENU ¢ Settings ¢ OK ¢ Handset ¢ OK ¢ Register HS ¢ OK ¢ Enter the
system PIN of the base station (default is 0000) ¢ OK.
Registering flashes in the display.
Registration takes approx. 1 minute.
Posted on Aug 14, 2010
  • 5723 Answers
SOURCE: My Siemens gigaset A 490
To register the Gigaset handset, you need to have the handset near the base. Press and hold the Register/Paging button on the base for 3+ seconds (it's hidden by the handset when on the base). A shorter press of the button will activate the Paging feature. Then within 60 seconds of pressing the Register button on the base, press Menu and select Settings. Press OK and go to Handset. Press OK and then select Register HS. Enter the base PIN (default is 0000) and then press OK. (Use the up/down arrows to navigate the menus.) You will see Registering flash on the display of the handset for approximately 1 minute while the registration is processed.
The manual for the Gigaset A490 is available here: http://gigaset.com/medias/sys_master/A31008-M2200-R301-2-3S19_en-fr-es_USA_CAN.pdf . If you need it in another language (or country), start here: http://gigaset.com/hq/en/product/GIGASETA490.html?tab=manuals .
I hope this helps.
Posted on May 27, 2011
Base is flashing and cannot dial out
HERE'S THE LINK TO THE MANUAL.
The handset is either too far from the base or it needs to be registered. The instructions are in the manual.
http://m.gigaset.com/medias/sys_master/A31008-M2050-L101-1-7619_30-10-2008_en_GBR.pdf
Dec 25, 2012 | Siemens Gigaset 4010 Cordless Phone
My Siemens gigaset A 490 cordless phone is showing Register HS what i have to do pl advise
I hope this helps.
May 26, 2011 | Siemens Gigaset A490 Twin Cordless Phone
Our Siemens gigaset A2 keeps flashing at us and doesn't work.
First pull the battery fron the handset, pres the register button (Page) for a long time, eg 10 sec, then register the handset through the menu, setings, handset, register
Aug 07, 2010 | Siemens Gigaset 8825 Cordless Phone
Registering a Gigaset AL185 handset
i couldnt find a link to your owners manual, but, if you go into the menu in your phone and scroll down to "register handset" that should work
Jun 21, 2009 | Siemens Gigaset 4215 Cordless Phone
Siemens Gigaset A260 cordless phone fail to register
We've tried to register the Siemens A260 handset to the base but it continues to flash "Base".. and does not work.
Jun 19, 2009 | Siemens Gigaset 8825 Cordless Phone
Handset won't work
I went through this exercise with a Siemens Gigaset 8800. The solution is to DE-register the handset first. Then register it with your base. This function can likely be accessed in the handset menu. The phone you purchased is apparently still registered to the previous user's base.
May 23, 2009 | Siemens Gigaset 4200 Cordless Expansion...
Registering a handset for the siemens 2400 handset
Siemens Customer Service They offer a 24 hour help line and
can walk you through the process.
http://www.wedophones.com/Manuals/Siemens/Gigaset%202400%20User%20Guide.pdf
One handset is preregistered to the base. You had two. You indicated returning the pin to 0000. To do so, you must have entered a code to deregister the pin and go to factory defaults. Your best option is to call and let them walk you through a clearing and registration process if the above links does not suffice to the quick reference guide.
Feb 19, 2018 | Siemens Gigaset 2420 Phone
Problem Siemens Gigaset 4000 and 4200
You did get spiked from the power company, and your system needs repair. Go to www.cordlessrepair.com for help.
Jun 23, 2008 | Siemens Gigaset 4000 Phone
If you had a storm, and the only handset that works shows line in use, then your base has gone bad and needs repair. The reason the phones are flashing base 1 or something to that effect is because they don't see the base anymore, which typically means no phones will see your base, so its odd that one phone is actually seeing the base. Either way, you can try re-registering the phones to the base, but if you get the line in use after they register (if they will register), then your base is bad. If they won't register, your base is bad. For additional assistance you can go to www.cordlessrepair.com
Jun 15, 2008 | Lands Phones
My siemens gigaset 4215 and 4000 don't work and need some kind of code whats the code?
Hello, Almost never is it the handset that is bad when those symptoms occur. It sounds as if your base has gotten hit by a power surge and won't boot (the handset now can't "talk to" the base and its always searching for it). Most people report this after a storm has passed through their area. You can try re-registering the handset to the base, but unfortunately it probably won't work, sorry. You can order the base only and register your handset to the replacement base when you get it. To order a replacement base using google, search for Siemens Cordless Repair and click the first non sponsored link. Good Luck
Dec 08, 2007 | Siemens Gigaset 4000 Phone
Lands Phones Logo
440 people viewed this question
Top Siemens Lands Phones Experts
Marvin
Marvin
Jaime Hernandez
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
