Question about Candy Ovens
I have a dual oven. The bottom one which is a fan oven stopped heating. The light is on, the fan is on but not heat is generated. What can I do?
  • Candy Master
  • 3,463 Answers
You need to replace the oven element at the rear of the oven, where the fan is located.
Hope this helps.
Posted on Dec 11, 2009
Why is my oven not heating up?
Call an electrician. Sounds like a thermal cut out or a bad element.
Jul 17, 2014 | Smeg Ovens
Oven will not heat up
Is the gas turned on? Do the stove top burners work? Check for kink in gas hose.
Nov 11, 2012 | Ovens
My cooker won't heat up
remove the rear panel covering the fan (4 screws) from inside oven. The element is round the fan. you may see where the element has burnt through or split or distorted the element.
Jul 23, 2010 | Electrolux Ovens
The bottom oven has stopped heating up. In fan mode and oven mode it does not operate. The grill in the bottom oven still works.
It is probably the oven fan element that has failed.
It is located at the rear of the oven compartment behind a removeable cover.
I am basing my solution on the basis that the oven is electrically heated, and not by gas.
Feb 23, 2010 | AEG D5701-4 Electric Double Oven
Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Oct 18, 2009 | Belling XOU592 / XOU593 Electric Double...
The fan and oven light in bottom oven works but not heat.
The heating element is the likely culprit as they burn out and go open
circuit..(ie ...disconnected and will not heat up )
If you can use a multi-meter , then the element can be tested using the resistance range (with the oven SWITCHED OFF )
Aug 30, 2009 | Neff U1721 Double circotherm Electric Oven
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
Bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Dec 17, 2008 | Bosch Ovens
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
Ovens Logo
149 people viewed this question
Top Candy Ovens Experts
ray gallant
Dado
Tom Chichester
Are you a Candy Oven Expert? Answer questions, earn points and help others
