Question about Sharp Microwave Ovens
Model r-1501 no power, it is a cabinet unit - Sharp Microwave Ovens
I have a whirlpool stainless steel microwave oven built in above my oven, model MH3184XP, purchased it in Fall of 2005, it has been working wonderfully, then it just stopped, quit working alltogether, I checked the fuse and the breaker.. all fine.. any ideas
Posted on Dec 23, 2009
  • Sharp Master
  • 9,098 Answers
It may be a blown fuse, the cavity thermal cutout, or the magnetron temperature fuse.
We have the full service manual and have uploaded it to our site here to help you.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so with a one-year guarantee.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Dec 13, 2009
I want to replace oven
If you are wanting to know who to replace the unit then I think I can help. If this unit is above the kitchen range then there should be a cabinet above the oven. You need to look there for 2 bolts that go thru the cabinet floor into the microwave. have someone there to help hold the oven as you take out the bolts and the oven will come down it is also in some cases hanging on a lip on the back of oven so let it down slowly. There should be a plug in the cabinet as well so you will need to unplug it. Installing the new one is the reverse.
Apr 28, 2014 | Goldstar MV-1501 Microwave Oven
Location of fuse
Remove the cover. You will find the fuse near where the cord enters the cabinet. Make sure you get a proper replacement.
Jun 14, 2012 | Goldstar MV-1501 Microwave Oven
Chaging light on gold star modle 1310w how to do it
To get to the bulb all you have to do is open the cabinet.remove the screws from the back of the oven and the top and sides will slide off then you will see the bulb.
May 17, 2011 | Goldstar MV-1501 Microwave Oven
The Sharp R-1501 came in our used RV and had no display or power level choice; now 9 months later it sounds as if there is only partial power and the turn table is rotating very slowly. At this point I...
It might be worth saving. I've worked on these for years.
Please contact me directly for full details since FixYa doesn't always inform us of follow-up questions. Remind me of the full model number and FCC ID number from the tag and your detailed symptoms.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
Nov 12, 2017 | Sharp R-1501 Microwave Oven
Where is the fuse located?
In general you can locate the internal fuse by opening up the microwave cabinet. To get to the fuse, remove the outer cabinet of the unit, which is usually held in place with a few screws. Once the outer cabinet is removed, follow the power cord into the unit. It will take you to the fuse holder, where the fuse sits. The fuse holder is located two or three inches into the unit, and may be attached to a power board.
Jun 01, 2010 | Westinghouse WST3504 Microwave Oven
Where is the main fuse?
Hello :
To locate the fuse, remove the outer cabinet of the unit, which is usually held in place with a few screws. Once the outer cabinet is removed, follow the power cord into the unit. It will take you to the fuse holder, where the fuse sits. The fuse holder is located two or three inches into the unit, and may be attached to a power board .
The picture bellow is showing a blown fuse .
please rate .
Mar 29, 2010 | Kenmore 80412 Microwave Oven
Unit just died for no reason?
Take the cover off...comes apart many different ways on various models. Once cover is removed look for blown fuses...should be one on the main input near the power cord. May be additional fuses at the transmitter. Could also be as simple as removing input power for 15 minutes and then reconnecting; I recommend you try this step first.
Feb 07, 2010 | Maytag MMV4205 Microwave Oven
Emerson Model MW9325SL microwave oven looses power
It sounds like either a filter is clogged, an air vent in the back is blocked, or the internal cooling fan is not running.
We have a sound clip here of what a microwave should sound like when the cooling fan and high voltage section are working.
This overheating can happen if you put it in a cabinet or push it against a wall.
Many Emerson microwave owner's manuals are available for free download here.
Even though yours may not be there, there might be one close enough to help you.
For more help from Emerson
visit here or get help using your appliance at 1-800-898-9020.
Since it's new, it's under warranty, and any trouble you have should be taken care of.
Get help locating an authorized servicer or parts at 1-800-695-0098.
Oct 29, 2009 | Emerson Microwave Ovens
Ge spacemaker installed over stove-----need to remove it
Her is a link that I hope with work that shows the bracket and how it was installed.
PDF]
  JVM1850BH/CH/SH/WH – GE Spacemaker Over-the-Range Microwave Oven File Format: PDF/Adobe Acrobat - View as HTML
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Removing Old Built-In Microwave
You did not note your Make and Model. As there are many different types, all I can give you are basic directions.
First make sure the Power Cord is UN-PLUGGED from the wall.
1. Remove the Top Vent Grille Cover. There are screws holding this on, either Three you can see (one on each side and one in the center), or Open the Door and look for screws at the top of the Frame that go Up Into the grille.
2. Look in cabinet above unit for screws that hold unit up. Usually two (one on each side, front), can be more. Remove.
3. Look where Top Vent Grille Cover was removed. There should be a Long Screw or Screw-Type Lock at each( top) corner. These hold the unit tight on the Wall-Mount Plate. Remove. You should have HELP at this point as you will slide the unit forward until it comes clear of the Support Arms.
GOOD LUCK!!
Jan 31, 2008 | Microwave Ovens
Microwave Ovens Logo
42 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
