Question about GE Washing Machines
Gorenje washing machine. Which compartment does fabric softner go
Hi I have a gorenje washing machine, model wa61111. I've lost my user manual so I'm not quite sure which compartment to put the fabric softner...
  • 220 Answers
SOURCE: fabric softner does not empty
I had a similar problem and removed the complete dispenser drawer and washed it in with hot water. The small inner cups for the fabric softener and bleach should be removed and the hot water directed into the small "stand pipes" on the back side of the covers. It appears the fluids in the cups are siphoned out and if the pipes are clogged at the bottom there will be no flow. Also is the plate is not fully seated, the siphon effect is will not work.
Also, my wife said she does not use the cheaper brands of fabric softener anymore because we think that might have caused some of the clogging.
As a side note, if you remove the top of the washer, there is an adjustable dial where you can fine tune the amount of liquid dispenced. You can try adjusting that too. I think my final fix was to clean the back side of the face plates inside the dispenser and ensure they are fully seated to allow the proper siphon effect.
Posted on Jan 15, 2009
skrbin
  • 121 Answers
SOURCE: I need schematic diagram for gorenje wa 50050
I find a schematic diagram on internet address www.masine.sigma-com.
Thank you for trying!
Posted on Jun 30, 2009
  • 127 Answers
SOURCE: gorenje washing machine on display shows F31. what
it means"The connection to the tacho generator is open or short-circuited". that means the motor is not turning. 99% it is the brushes (20 eu) and it wil work again.
marko
Posted on Aug 13, 2009
barkencoa
  • 3463 Answers
SOURCE: water in the fabric softner compartment after wash cycle
You need to poke all the holes clear in the top of the dispenser housing with a piece of wire or similar.
This should solve the problem.
Posted on Dec 15, 2009
beltronic205
  • 1474 Answers
SOURCE: Wont drain water Gorenje WA61111
locate the filter and clean, this should cure
Posted on Dec 16, 2009
I have just moved into an Apartment with a Gorenje wi 62112 Washing machine, I have no manual Can anyone tell me what the numbers on the Dial mean What should I choose for a general wash.
Gorenje has some documentation for their washers here: http://www.gorenje.com/simplicity/en/washing_machines/simple_manual_for_washing . The numbers indicate the water temperature (in Celsius) for a given cycle. The common choices are a cottons load in hot water (60 degrees). This is great for towels and other whites. The mixed load is for permanent press that can be in warm water (40 degrees). Then there is a cold water cycle for delicates (30 degrees). However, you should check the fabric care label before choosing the cycle.
I hope this helps.
Apr 20, 2016 | General Washing Machines
Washing machines
/manuals/_washing_machines/gorenje.html
you can get the item you need here good luck
Jan 12, 2014 | Washing Machines
Need a Gorenje WA61111 Manual
the manul is here in pdf form:-
http://www.gorenje.co.uk/support/manuals?t=instructions&cm=wa61111
Dec 20, 2012 | Washing Machines
Gorenje wa72145bk erro f2
it your door lock that faulty
Jul 01, 2012 | Washing Machines
How long should the spin cycle programme last on a Gorenje Wa61111
Methinks you could do with a manual- for now and possibly later!
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Apr 25, 2011 | Washing Machines
Dec 16, 2009 | Asko W600
Need Gorenje WA 64153 service manual
Look behind the control panel or inside the cabinet taped to the wall.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2009 | Washing Machines
No manual for Gorenje front loading washer.
Here is a link to the Gorenje website, you can download the manuals from there which explain all the symbols. This link is for the WA50140 machine which I have, just click on the 'manuals' tab
http://www.gorenje.co.uk/laundry/washing_machines?c=161105
Jan 27, 2009 | Washing Machines
Washing Machines Logo
123 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
