Question about Kenmore 23313 Whispertone Bagged Canister Vacuum
HOW DO YOU CHANGE BELT CANT SEEM TO REMOVE BOTTOM TO GET TO IT KENMORE WISPERTONE 116
  • 175 Answers
The top cover to the light lense pops off at the ends. When you get that cover off then you will see 2 screws that are by the swivel neck. Take those out and then the whole body top cover comes off. That will get you into the roller brush and belt area of this machine.
Posted on Dec 11, 2009
Kenmore vacuum cleaner model no. 116. 5861279 belt replace
Do you need the belt or the directions for changing the belt? Sears Parts Direct has the manual for the 116.58612790 here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Vacuum-Parts/user-manuals/manual-downloads/Model-11658612790/0582/0640500?modelNumber=11658612790&diagramPageId=&documentId= . The direct link to the manual is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0802691.pdf . See pages 14-15 of the manual.
To replace the belt, you need to remove the light cover and then the light bulb. Press in the sides of the cover and lift to remove it. the bulb needs to be pushed in and then turned couter-clockwise. Remove the cover screws. Then flip over the Power Mate and use the flat blade screwdriver to release both tabs. Turn the Power Mate back to right side up and press on the handle quick release pedal and lower the swivel. Tilt the cover forward until it snaps free. Carefully, use your screwdriver to pop the brush supports free on both sides to remove the brush. Slide off the old belt. (If needed, slide off the brush supports and washers. Clean the brush before reassembling the unit. Then replace the brush supports and washers.) Push the belt on motor drive and then onto the brush sprocket. Push the brush supports back into place on the base. (Make sure that this isn't assembled upside down.) Then line up the front of the cover with the base and tilt the cover back into place. Press firmly until you hear both sides click into place. Replace the cover screws, light bulb and bulb cover.
The belt is available here: http://www.searspartsdirect.com/Kenmore-Vacuum-Parts/742024/0020/116/Model-11658612790/0582/0640500.html . This is part number 5285; it's the direct replacement for the original 742024 belt.
I hope this helps.
Jun 16, 2016 | Kenmore Vacuums
How do I change the belt on Kenmore vac model # 116 32213200?
Your model has two levers on top of the nozzle housing that you slide to allow you to remove the cover to gain access to the belt and brush roll.
Dec 21, 2014 | Kenmore Vacuums
Kenmore canister,model 116 52512201
Do check and make sure you've removed all screws as some are recessed then look at the front of sweeper to see if there are what I would call clips/hinges holding the bottom plate on gently seperate plat e from head Hope this helps
Sep 26, 2012 | Vacuums
I own a Kenmore vacuum cleaner model # 116. 56550990C. I have lost the instructions to replace the belt in the Power Mate. The Power Mate beater just stopped working and I need instructions on how to...
If unit beater has stopped working it is either the motor, the power connection to beater or the belt that powers the roller. Which is it?
See if you can download the manual from the mfg or google for it.
Sep 05, 2017 | Kenmore 25614 / 25615 Progressive Bagged...
How can I access the roller belt in Kenmore Powermate 116 53313305? with no screws. Does the entire black half separate from the blue half?
If there are no screws on the underside (like mine) you need to remove the top light cover. There are tabs on either side that need to be pressed in so it pops out. Under the light cover there are two screws located in the center. Remove those and the blue and black components should come right off.
Jan 31, 2010 | Kenmore 23913 Progressive PowerMate Bagged...
How I replace the belt for Kenmore 116 3063500C ser M53101631
Turn it over and on the bottom are (2) screws. Remove those and the top cover will come off and you can access the belt.
Jan 08, 2010 | Kenmore 23913 Progressive PowerMate Bagged...
Ken 116 31912100
open the bottom and you will see where the belt goes.clean off the motor shaft before putting on the new belt .the old belt might have left some rubber on the motor shaft.clean the shaft or your new belt won't last very long
Apr 07, 2009 | Kenmore Progressive Bagless Upright with...
Kenmore 23313 Whispertone Bagged Canister Vacuum Logo
756 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
