Question about Olympus FE-170 Digital Camera
I have an olympus Fe-230 and when I try to turn it on the lens goes in and out several times before just closing. Is there any way to fix this?
    Novelist:
  • 108 Answers
If you have tried running the camera on Brand New Duracell, or Energizer or equal batteries with a Full and complete charge, and the camera tells you to turn it off, or simply as you say, Shuts down, then consider the following.
High Risk Solution.
This may or may not work, but it has worked for me twice on two different cameras.
The problem you have originates from the lens being bumped when the camera is on, and the gears that extend the lens skipping over a few teeth.
To set it back, watch your lens as it move in and out. Notice which way each of the barrels (levels) of the lens turns while it moves out.
Since the lens cannnot extend to it's full functioning position, (Because the gears are missaligned), it will require a little help. While it is extending, assist the barrel as it moves outwards with a small force turning the barrel in the direction it is moving while it is extending.
A click or two will tell you the gears have jumped a tooth or two, and the lens may be able to extend to it's proper postion.
Turn the camera off and on again to see if there is any difference. Perhaps repeat this several times.
Be VERRY Carefull about this and Use it Only as a Last Resort. Rely first on your warrantee if you have one, and second on your cash, if you can take it to a repair shop where they can do this.
With Great Caution, I hope this helps.
Posted on Dec 11, 2009
SOURCE:
Power on olympus camera
Do you experience low battery? Have you tried using brand new and fully charged rechargeable batteries like NiMH or NiCd?
May 06, 2010 | Olympus FE-340 Digital Camera
My FE 340 Olympus Camera tries to turn on, but can't. Lens goes in and out several times then shuts off completely. Battery is fully charged.
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 19, 2010 | Olympus FE-340 Digital Camera
Problem with my Olympus FE-230
When I turn my camera on, the lens goes in and out a few times. Once it's finally on and I look at the screen, everything is blurry. When I take the picture, it's blurry too. If I try to use the zoom to adjust, the lens starts going in and out all crazy and won't adjust right.
Jun 20, 2009 | Olympus FE-230 Digital Camera
Olympus FE 230 Problem
I had the same problem. I hit it a long time ago when it did it for the first time. It has been a year since then and it is doing it again. I tried the book solution again and it will not work. I tried holding the lens, no luck, and I tried applying pressure when the lens went back in, again, no luck. Honestly, I don't think I will buy another Olympus fe series camera again. The solutions provided do help the first few times your camera does it, but you might want to start checking the market for a new camera.
Jun 04, 2009 | Olympus FE-230 Digital Camera
When I power on, the lens keeps going in and out repeatedly
Turn on camera, makes grinding-type noise, then lens goes in and out several times...try to put your camera in a table lcd side down and turn it on...while lightly tapping on the sides of the lens. also try to check out this link
http://www.olympusamerica.com/cpg_section/cpg_servicerepair_warrantyinfo.asp
Nov 26, 2008 | Olympus FE-230 Digital Camera
Olympus FE-230 Digital Camera Jammed
Nov 22, 2008 | Olympus FE-230 Digital Camera
Olympus fe-230
lens appears to be off track and needs repair
Oct 06, 2008 | Olympus FE-230 Digital Camera
Olympus FE-230 Digital problem
Someone on here with the same problem mentioned that they shook the camera violently and it fixed the problem of it not focusing. I tried the same thing and actually gave it some light slaps on the tabletop. Well, now it works! I'm somewhat concerned that this fix won't last long.
Like many others' FE-230s, this camera began not focusing shortly after the one year warranty expired. I found my receipt and it turns out that I purchased the 2 year service plan at Best Buy and could get the camera replaced. But, now it works. Will it fail again after the 2 year plan expires? Jeez....
Jul 27, 2008 | Olympus FE-230 Digital Camera
Fe 230 problem
try olympus repair for about $80.00
Jul 14, 2008 | Olympus FE-230 Digital Camera
Olympus FE-170 Digital Camera Logo
100 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
