Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
I have a side by side Whirlpool refrigerator. It is about 6 yrs old. It has recently started having ice build on the floor of the freezer. Any idea for a fix on this problem?
  • 4,070 Answers
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Dec 11, 2009
Testimonial: "Sounds like that may cure the problem."
My Whirlpool refrigerator builds up ice in the freezer around where the cold air comes from. Eventually it starts to fill the bottom of the freezer with clear ice. It has done this almost from since it was...
you should manually defrost fridge/freezers every 6 months for optimum performance.also fill any spare capacity with clean waste foam, cuts down on all that cold air dropping the floor/warm air filling void (i put foam in plastic bags. works for me
Feb 08, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer compartment has frost buildup
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 24, 2009 | Whirlpool GS5SHAXN Side by Side...
Bottom of feezer building up ice and leaking
This just happened to me. take the panel off inside of freezer and you will see the evaporator fan this could be the problem. test it before placing.Also there is a thermostat in there too. A little round device that will kick the fan on when the temp is around 34. Both parts together are about 90 bucks if you get them yourself online. About 170. through a dealer.
Apr 10, 2009 | Refrigerators
Freezer not freezing
Your clicking noise is a defective start relay on the compressor. It must be replaced. You can get the part and do it yourself. Just pay attention to the wires. Replace them on the new relay as they come off the old.
The relay is attached to the side of the compressor.
Mar 26, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool GD25DF auto defrost drain problem
There is a drain hole in the back of the freezer on the bottom. Get back there with some hot water. Most of the time it is just lime build up. Unless you know what feel back there. Another way is to move the freezer out and from the back side you can see the drain line. It just pulls right off
Feb 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice build up on floor of freezer drawer
Check the drain tray under the evaporator its probably froze over causing water to overflow in the freezer
Mar 02, 2018 | LG LRFC25750 Refrigerator French Door
Ice build up under the freezer drawer
drain is blocked. remove back panel inside freezer and melt the ice off at the bottom with a hairdryer then follow up with hot water till drain flows freely. if fault reoccurs, then you may have a fault with the defrost system
Jul 06, 2008 | Whirlpool GB2SHKXL Bottom Freezer...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
184 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
