I have NVIDIA FX 5200 video card. I try to connect the HP LCD and TV. When I select clone mode, I will be able to change the resolution on the LCD side because TV can only change the resolution max to 800X640. Is there a way that I can use a different resolution on the LCD? Thanks. TJ
  • TECH-86 May 11, 2010
    what cables are you using for your tv and monitor
    Genius:
  • 1,066 Answers
Not in clone mode, you would have to do the extended mode to control the resolutions separately.
Posted on Dec 28, 2009
SOURCE:
Hi, just installed a GeForce FX 5200 / 128MB DDR / PCI / TV-Out / Video Card (S Video) ,works fine but I can't get it to display video in the TV though I get the Windows desktop wallpaper in it (no...
Sounds like a driver problem, did you install the driver that came with it or did you just put it strait into the computer? I would recommend downloading (or check windows update) for a newer version of the driver. That or right click on your desktop and go into your display settings and make sure you have the proper resolution picked!
May 06, 2011 | Nvidia GeForce FX 5200 Video Card Graphic
How can i run my program on tv out which is running on my pc same to same as powerpoint show and tv play both at time.??
I assume you already have a cable (s-video) connecting your tv to the video card, on windows video settings you can select the clone mode that mode make the both screen display the same. on windows xp use right click on the screen select proprieties and on the last tab set the desire configuration you can extend or clone, use clone. on windows vista or 7 just use the shortcut WIN + P and use the duplicate mode.
For that normally you but boot your pc wit the video cable already connected.
After doing all you can set the proper resolution and configuration of the additional screen on the display properties.
Mar 13, 2011 | Nvidia GeForce FX 5200 Video Card Graphic
Where can i find graphics drivers for FX5200 128mb ddr 128bit+tv? how to change screen resolution? all things on decktop are very big.
Driver can be found here
http://www.nvidia.com/object/winxp_175.19_whql.html
To change the resolution right click on the screen , select Settings and move the resolution slider to the right, click Apply, click OK twice.
Jan 30, 2011 | Evga e-GeForce FX 5200 ,128MB/128 Bit DDR,...
I have an S-video cable ran to my tv and it only shows I have one moniter installed. I have my moniter as well as the S-video cable plugged into the pny card. should it be that way? I have also just bought...
First thing to do is to lower the resolution to say 800x600
call up the Nvidia control panel by right clicking on an empty part of the desktop and click the Nvidia CONTROL PANEL
there are two methods one is the MULTIPLE DISPLAY WIZARD (Just follow it through and it will do most of the work for you)
OR
Use the SET UP MULTIPLE DISPLAYS option. (my choice)
It is better to select the "CONFIGURED INDEPENDANTLY" option often knows as dual view.
Below that are two boxes the first sets the order of the display. Set it so your regular monitor is first on the list.
the box below that selects the PRIMARY display normally leave this to your default monitor until you have finished setting up both displays.
when you have two displays then go to the "CHANGE RESOLUTION" (still in the Nvidia panel not the regular display panel)
click on the display you want to change and alter to suit your taste.
now do the same for the other display.
If you get an "out of range" error drop the resolution as you are trying to do more than the display can handle
There are similar procedures for other makes of graphic cards.
Try avoid the VGA to component leads as they are hit and miss in this type of application.
S-Video is quite good
your best option is DVI and it the one I use to drive a 50" sony
You have to let your card know about other displays using the steps above or similar
Sep 05, 2009 | PNY Verto GeForce FX 5200, (256 MB) PCI...
NVIDIA GeForce 7300GT TV-OUT issues
You could try selecting properties on the shortcut and checking the run maximized box. Or you could try to find the .txt file with the game settings in it and manually insert a resolution. However, since I do not have the game, I cannot tell you were to find that. I hope this helps, Yannick.
Jun 09, 2009 | Nvidia GeForce FX 5200 Video Card Graphic
LG 22" TV with Geforce nVidia 5500 FX 256MB AGP card
Try getting a new video driver. Foreware = motherboard drivers and such, not video.
I saw this driver on Nvidia.com
Its the XP driver for those 5000 series FX cards like yours. Try installing that and checking out the Nvidia Panel after.
1680x1050 is an odd resolution for TV, that is what normal 22" monitors have but I guess it will do up to 1680x1050 only when hooked up to a PC.
Feb 21, 2009 | LG 26LX1D 26 in. LCD HDTV
No signal on HDTV
Your graphics card is probably too old to support HDTV signal (720p, 1080p)
Dec 04, 2008 | Nvidia GeForce FX 5200 Video Card Graphic
Crashing comp with nvidia geforce fx 5200
your agp video is overheating, see if the cooking fan attached in it is working fine.
Oct 27, 2008 | Nvidia Geforce FX 5200 Graphic Card
Monitor Resolution
have you tried the newest drivers for your card?
Nov 30, 2007 | XFX GeForce FX 5200, Graphic Card
Nvidia fx 5200
The only time that this can happen is if the driver is not installed correctly, as on install you are normally asked if you want to activate support for dual monitors, so if you havent already, uninstall the card driver, restart and install driver again from the cd or from the NVIDIA website. http://www.nvidia.com/object/winxp_2k_93.71.html If you have already tried this my apologies.
Apr 09, 2007 | Nvidia GeForce FX 5200 Video Card, 128MB...
Computers & Internet Logo
101 people viewed this question
Alun Cox
k24674
