Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Connection (or disconnection) difficulties
I've been struggling with this router for a while with our current setup. Previously, I had a Linksys WAG54G which was reasonably ok though the ethernet switch part died.
Anyway, the problem I'm getting with this Belkin G+ MIMO router seems to be related to the wireless bit - wired, it seems to be ok as we have 2 laptops connecting wirelessly and a desktop & printer connecting through a switch which is wired into the ethernet part of the router. All (except the printer) have IP addresses allocated by DHCP.
I think the problem is that after disconnecting from the router (either by logging off, sleeping or switching off), the router still retains the computer name and dhcp IP address and will not release it as per the LAN settings: Lease Time >                        One hour                       Two hours                       Half Day                       One Day                       Two Days                       One Week                       Two Weeks                       Forever                       The length of time the DHCP server will res erve the IP address for each computer
I've tried various combinations of settings but it won't release it until either another computer has connected and had an IP address allocated or the router is restarted - sometimes it has to be a restart. Having said that, it is intermittent, and I can't seem to isolate what circumstances cause it to retain the settings or not.
I'm left with several options: restarting the router whenever the problem occurs, returning the router (claiming it's faulty) and replacing it or getting a different one. Or, I could use a wireless access point plugged into the router/switch to serve as the wireless part: laptops would then connect through the access point.
Anyone got any better ideas or suggestions? Or experienced similar problems?
    Scholar:
  • 112 Answers
The time span for the assigned IP address are controlled by the router in the DHCP configuration, which can be set to your satisfaction, by accessing the router configuration page, by entering http://192.168.0.1 in the internet explorer address window. Be sure to use the IP Address assigned to the router.. Also you can release an IP of a computer by opening the MS/DOS command window by clicking Start/Run and typing in CMD and then enter at the courser ipconfig /release this will release the ip. then type ipconfig /renew this will reset the ip of the computer. If this helps please rate as a FixYa. Thanks BPCS
Posted on Jan 20, 2008
Connecting a Linksys WRT54GL. no internet connection detected
The ISP modem connects to the main LAN port on the router. The PC connects to any other port. Done. You should have internet via wire at this point.
Feb 12, 2013 | Linksys Wireless-G WRT54GL Router
I have an older (maybe 4 or 5 years) used WRT54GS and I am starting to have problems with the wireless internet connection with my mac book that I have had for a month. Before it used to work fine, no...
WRT54GS may be more reliable router and you can continue to use it. Try power cycle first check cables! If no improvement you can reset! that will bring it factory default!
Other important matter is check the firmware upgrading firmware is a good solution for these kind of problems!
Currently available routers are much better if you are willing to get a new router N router is the way to go! They wider area coverage and faster network speeds!
good luck!
Sep 11, 2011 | Linksys Wireless-G WRT54GS Router...
Can I use this router with Linux operating system?
If this is a home router you were previously using with Windows it should also work with a Linux distribution, such as Ubuntu (and others).
This of course implies a successful Linux install with all your hardware being recognized.
Jan 09, 2011 | Belkin Basic Wireless Router
I have a Linksys WRT160N router that I am using with a MacBook Pro laptop running Snow Leopard. I used my computer (with some difficulty) to set up the wireless access by way of a wired connection. The...
My Friend ,
Login the router setup page .
And under router security settings uncheck the option (block anonymous internet request).
Set the wireless channel as 6 or 9.
And then use wep security key.
this will surely work.
Regards :-
Amit
Jan 07, 2011 | Linksys WRT160N Wireless Router
Router does not show wireless light. I have reset it but can't access it with the setup wizard. Any suggestions?
* NOTE: If you tried to set-up the WRT-150N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
then do this :
1. Hook up the Linksys WRT-150N Router to the Modem via a LAN cable.
2. Hook up the Linksys WRT-150N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-150N Router.
3. Type http://192.168.1.1 in the address bar of your web browser.
4. Log-on to the Linksys WRT-150N Router with these log-on credentials:
Username: linksys (lower-case)
Password: admin (lower-case)
5. Click on the "Clone PC MAC Address" tab.
6. Click the "Clone PC MAC Address" button.
7. Click "Save", click "Continue".
8. Click the "Wireless Security" tab.
9. Choose "WPA2 Personal - TKIP/AES" for encrypted security.
10. Enter encryption password (passphrase).
11. Click "Save", click "Continue".
12. Exit the web browser.
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-150N Router.
In about 5 seconds, your wireless connection should be up and running.
Sep 15, 2010 | Linksys Wireless-N WRT150N Router
Computer repair tech said Linskey wireless caused internet prob
If you are using DSL as your internet connection there is a timeout period that could be setup in the linksys.
In order to change this you need to log into your router and on check on the setup page. You see the timeout option.
Check with your linksys manual for detailed instructions for logging into the unit. If you dont have it, you can always get it from their website.
Jul 31, 2009 | Linksys Wireless-G Broadband Router
Wireless Connection limited range and intermittent
1. Access the router's setup page then go to wireless tab and change the current wireless channel to a different one.
2. You may also upgrade the firmware of your router.
Nov 08, 2008 | Linksys WRT300N Wireless Router
Laptop setup
just connect the linksys router to wireless router and just install the setup cd given with wireless router ..after configuring your laptop just insert the cd in another laptop and copy WEP key in it and get connected through wireless network
Jun 19, 2008 | Linksys Wireless-G Broadband Router
Router
Before you can get online through the router all you need to do is change the Linksys router's IP address. Because the westell and the linksys has the same range of IP address that creates a conflict on your network that's why you can't get online.
First login to the setup page of your linksys router.
  1. Under the Setup Tab (this is the first screen that you will see after typing in the linksys router's password.) make sure that the Internet connection type is set to Automatic Configuration- DHCP, Then on the same page look for router IP address or LAN IP address. By default its 192.168.1.1, you need to change it to 192.168.2.1. And hit save settings. You will get disconnected from the linksys page, that is normal. If you want to log back in to the router page you use the new address of your linksys (192.168.2.1).
  2. Now you restart your computer to refresh the connection and that should get you online.
Just reply to my post to let me know if your done doing this. We will setup the wireless after we make sure that you can get online wired to the router.
May 13, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
91 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
