Question about Philips Televison & Video
Phillips tv model #42pf5321d/37 we replace the signal board and we have picture now but the picture on the right side is too wide
    President:
  • Philips Master
  • 1,779 Answers
You should have downloaded the eprom information onto a usb stick then transfered it back to the new board, or just removed the eprom off the old board onto the new. It is my recommendation to have an authorized service center come out and realign it within the factory service mode.
Posted on Dec 11, 2009
I have a phillips 42PF5321D/37. All of a sudden it started flashing 6 times when I tried to turn it on. I unplugged it downloaded software update and updated the tv with the instructions provided and tv...
if the tv is only working when it's being updated then there is either a problem with the update firmware or the tvs memory chip. the chip is on the main av board and its best not to touch it if you don't know what you are doing, replacing the board may only be your option.
Jun 06, 2017 | Televison & Video
42" Plasma 42PF5321D/37 will not power on. I replaced the fuse on the power supply board with a 3 amp (that's what it looked like, but I'm not sure it was the right size because it was burned
Always replace fuse with fuse value required If fuse value is less it will burn out . If you replace with fuse that is required and it burns out then you have bad short in power supply circuit In that case check bridge rectifier
Dec 07, 2012 | Philips 42PF9630A 42 in. Plasma Television
I have a Philips 42pf5321d/37 that won't turn on.
send me a email sonny@tvcircuitboards.com and I can assist you with troubleshooting it to determine whats happening with the set.
Aug 07, 2012 | Televison & Video
Phillips 42PFP53320 42" Plasma TV. No picture,
Hello jporter...
welcome here in fixya..
That problem is one of the common problems of plasma TV (have sounds but no picture)..As a expert of flat panel for more than 5 years I already encounter that kind of problem many times..
Actually that problem is caused of either X,Y or Z sustain board or even both 3 boards are faulty..Because some models when the one of those boards have short circuit or bad there are possibility that other sustain board are affected..But most the problem like yours is "Y-SUSTAIN" board..
I can't find your model online please double check it it either Phillips 42PFP5332D/37 or 42PFP5532D/05
And for specific and easy way to find replacement please try to look at the part # of that board (it is usually printed on the sticker attach to the board itself..
Hope it helps and please don't forget to rate my answer..
Have a nice day!!!
regards,
Chester.
Feb 04, 2012 | Philips Televison & Video
Phillips 37PFL5332D/37 I have a blue power light but no picture, sound or anything. Please advise?
When tv power on.U have a solid LED green or red power light incadication?Yes,than 100% ur tv Tuner signal board is the problems and the causes.That the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Jan 13, 2011 | Philips 37PFL5332D 37 in. LCD Television
Phillips model#42PF5321D/37 black screen and red light flashes.unable to turn on. sonia
Power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 21, 2010 | Philips 42PF9431D/37 TV
Phillips 42PF5321D/37-Green power light, but no A/V.
bad powersupply, the powersupply has 4 voltages, +12, +5, -12 & +12 the led only tells you that the +12 is working.
Dec 16, 2008 | Televison & Video
No picture on tv. model 42pf5321d/37. red light flashing on lower right. flashes 4xx see Morgan ref. 719nt
Purchased new Pansonic TV,, old one [2 years] was not projection tv. In for repair for kids.
Oct 07, 2008 | Philips Televison & Video
Unable to exit TV's menu
Try to replace the remote sensor board inside the bottom of your tv. If that won't work, you need to replace the Small Signal Board (SSD Assy) of your tv.
Nov 24, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
367 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
