Question about RCA P60921 60" Rear Projection Television
RCA Projection TV Model P60925BL. Has sound but lamps don't turn. Chassis model PTK195LC
I went into setup option and the dvd player disconnected and I can't figure out how to get it working on the tv again. dvd is connected to video 1 on the dvd player and channel 3 on the tv ????
Posted on Jan 02, 2011
How do I locate and change the projection lamp in my rca TV,model d61130,high depth TV?
I know this sounds crazy but please go to youtube and type in 'how to replace my lamp in a RCA rear projection TV' and you will get multiple video's showing how to do this.
Nov 09, 2014 | RCA D61W20 61" Rear Projection Television
My RCA R52WH74 chassis # ITC222A wont turn on. The green power light comes on for about 10 seconds then shuts off. No picture, no sound. How do I fix it? Buying a new TV just isn't in out budget!
That model is famous for having issues with the deflection board failing. Replacing the deflection board should solve the issue. You can get replacement deflection board for the ITC222A chassis from www.tvrepairworld.com under the RCA circuit boards catagory.
Aug 05, 2011 | RCA R52WH73 Projection Television
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
TV won't turn on after cable outage
No your set would not be like the HD52W19 model ,your model number is on back of tv year,chassis & Model # being 10 yrs old ptk195 model------- older Rca ptk169 these sets are 16yrs old.My guess without hands on chassis Bad Flyback Transfomer.
Dec 02, 2008 | RCA D52W19 52" Rear Projection Television
RCA 60" Rear Projection TV Model P60925bl TV screen curved on the top and bottom. Colors are not aligned and images are blurred.
this would be the convergence IC 's that need replacing
if you are going to have a tech come out to do the repair it will cost between 3 or 4 hundered dollars
if you are going to do the repair yourself ( meaning that you can solder and indentify the convergence chips and test the resitors on it) then it will cost about $40 or so
electech
Nov 27, 2008 | RCA P60921 60" Rear Projection Television
Power light
do you have the chassis number?
Jan 03, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
No sound or picture
jerel,
Please provide accurate info for best solution = on back of set =
Model # , service # , chassis # , Mo / Yr built............
Stopped playing = Dead ? ....no sound , no picture, no green
power led on front??...........................Help ! Let me know..T.
Nov 25, 2007 | RCA P52926 52" Rear Projection Television
RCA rear projection tv
Dir TV projection Techcions, I own RCA Model:P52937 Chassis No.PTK195M26B. After a big flood here in Chicago, my basement got flooded and my projection TV was in water up to 1 foot. Befor I turned it on, I dreid it out perfectly, then, I turned it on, and a couple components from the power supply got burned up to the point where I am not able to read the part numbers that are on it. I was wondering if you have this kind of chassis and model service manual for this projection TV, or conponet part number i location 101 on mother boatd power supply. Thank you in advance, Darius If you prefeer, you may call my cell phone: 773-875-3926
Aug 02, 2007 | RCA P52937 52" Rear Projection Television
RCA P60921 60" Rear Projection Television Logo
188 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
