Question about ASUS P5RD1-VM Motherboard
HDD problemon asus motherboard p5rd1-vm
I just bought an 160 GB Seagate SATA HDD
but after i connect it to my motherboard it's unable to detect it
I don't even get it in the BIOS
I booted from my WIN XP CD and it says no HDD atached
plz help...
  • Dave Thompson
    Dave Thompson May 11, 2010
    Is it possible that it's DOA?
    President:
  • 2,351 Answers
Try removing your system memory. If you have two DIMMS only reset DIMM 1 only. The 160GB Seagate drive must be connected to SATA1 port. See page 1-7 in your manual. Try booting the system and enter the BIOS by pressing the delete key every 2 seconds. If the BIOS fails to load than clear the cmos/bios. See bottom of page 1-23 for this. Do not forget to set the cmos jumper back to normal. Try entering the bios again. Double check all connections within your system. Once your able to enter the bios menu you should be able to see your 160GB drive listed. (Remember all SATA drives are seen as master drives).
See page 2-14 section 2.3. You'll than need to open the Advanced menue. See page 2-24 Here you'll need to [Enable] the Serial ATA Controller. This enables the SATA controller allowing you to use the SATA ports.
If you intend to use the 160GB drive as your primary drive and install windows on it than you'll also need to open the boot menu. See page 2-31 section 2.6.1. Here you'll list your Seagate drive. On the other hand if your Seagate drive will be used as a slave drive there is no reason to list it in the boot order. Save your changes and exit the bios.
Now, if you are able to enter the bios and you enabled the SATA controller and your bios does not list your SATA drive than the SATA controller is defective. This is not uncommon for an Asus MB. If your board is less than three years old you can RMA the MB to Asus. The SATA controller can not be repaired. Call Asus tech at 812-282-2787 EST M-F 8:00am to 5:00pm.
Good luck.
Happy holidays1
Mike
Posted on Dec 12, 2009
  • 244 Answers
You need to install the SATA drivers that belog to your specific motherboard.
When you are installing Windows thru your Windows CD, there is a moment at teh beginning of the process that you will be asked to press F6 if you want to install 3rd party drivers.
That is your call.
Once the SATA drivers are installed, you will be able to continue with your Windows installation.
Don't forget to rate this answer if it helps.
Hello, My my motherborad is ASUS p5rd1-vm;RAM1GB and hard disk is PATA 80 GB but the HDD is having some kind of problem and the windows have shown a warning about it several times. Now i want to buy a...
Yes, it's compatible with the motherboard, no, it's not compatible with the XP install disk because it doesn't have SATA support. And since Asus doesn't provides it special driver needed (one that must be put on a floppy) it means that you simply cannot install XP on this disk.
All you can do is to obtain another PATA hdd what ever its size and install XP in it. Then put the new SATA disk in and use it to store all the installed programs and all your files on it. As a bonus you won't lose them if the new PATA disk fails or XP gets corrupted.
Or install Vista or 7 instead of XP, the have support for SATA disks
Jul 28, 2011 | ASUS P5RD1-VM Motherboard
I want to install xp sp2 on Sata HDD The motherboard is P5RD1-VM but there is error set up did not find any hard drive plz tell me settings of bios to sata compataibale
It's likely a problem with your connection cable from the HDD to the motherboard. The bios shouldn't have to be set up for the HDD to be recognized through a sata port.
Jul 17, 2011 | ASUS P5RD1-VM Motherboard
Sata HDD NOT DETECTING IN XP SETUP
If you're using a scsi card and connecting the hard drive to the card you need to have the scsi set-up floppy disk. When the blue screen starts during windows installation watch the bottom of the screen. It will tell you to press F6 key then to insert the floppy disk.
If you're using a sata drive connected directly to the motherboard (not in a raid configuration) you shouldn't need anything but the windows disk. The motherboard drivers and utilities disk should have the files to create the scsi install disk.
Sep 11, 2009 | ASUS P5RD1-VM Motherboard
My MB is PRD1-VM & i qam not been able to connect my 160 gb Sata Hard disk to the MB
The board certainly supports SATA drives.
First of all make sure you have the SATA lead and power plug, they look like this >>>
The SATA ports on the motherboard look like this (not all the same colour and arrangement) >>>>>>
If you have all the leads and have them connected to the motherboard, restart the PC, as it starts up hit the Del key and enter the BIOS, in the BIOS set the configuration to defaults, hit F10 save the changes and exit the BIOS.
The computer will restart and hopefully detect the SATA drive.
Regards.
Aug 03, 2009 | ASUS P5RD1-VM Motherboard
Raid problem
Windows XP does not support SATA you need to load the SATA drivers from the motherboard manuf. You should have a cd for RAID/SATA drivers. When you boot off the XP CD it give you an option to load third party drivers watch at the bottom of the screen. When you see this message you can insert the CD that contains the drivers it is looking for the you should be able to load Windows XP.
I hope this help. Please rate.
Feb 18, 2009 | ASUS P5RD1-VM Motherboard
Install SATA HDD for asus p5rd1-vm
The motherboard will support this drive.
I will assume you simple need it as additional storage set up as an additional drive?
If you do not see it in My Computer after connecting power and SATA cables, you will need Activate the Drive and Format it
To do this go to Control Panel - Adminstrative Tools - Computer management - Storage - Disk Manangement
You will see the harddrive here, right-cick it, Activate as a simple Partition and then format it.
You will now see it in My Computer and will be able to store on it.
Jan 05, 2009 | ASUS P5RD1-VM Motherboard
How to install SATA HDD for asus motherboard P5RD1-VM?
Do you have previous Seegate Harddisk or SATA one?
If the SATA is installed previoulsy then it is not to much difficult to install a new SATA HDD. But if you are trying to install Sata on Seegate HDD or in combination then it can not be done.
Let me know in either case, with more detail as you can provide here (For OS, Hardware Specification etc)
Thanks
Nov 15, 2008 | ASUS P5RD1-VM Motherboard
Sata hdd detected but problem with booting&installation
i have sata hdd 160 gb of seagate and hdd detected in raid channelbut when start installing window it shows message press enter for fresh installation "no hdd found please check power card,bios configuration
Jun 30, 2008 | ASUS P5RD1-VM Motherboard
Problems Installing my 160 GB Seagate SATA HDD
you need to go in bios and set sata to legacy for no F6 driver. if its on native it need a driver from floppy on xp cd boot . if its not detected in windowws as a slave. u need to run diskmgmt.msc and fin the unalocated drive and create part then format it ntfs
Nov 05, 2007 | Asrock K8Upgrade-VM800 Motherboard
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
ASUS P5RD1-VM Motherboard Logo
497 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
