Question about Dell Inspiron 6400 Notebook
Control Button stopped working? How to reset?
I think I may have inadvertently reset my Control key on my Dell Inspiron 6400 laptop. It no longer functions - no CTRL C, CTRL V, CTL ALT DELETE. I rely on the Control Key for basic functions like copy and paste a trillion times a day so this is downright painful!
I do not think this is a hardware issue. I think I bumped something or held a key down to long somewhere along the line. Can someone share how to check your keyboard settings and possibly how to reset the almighty Control Key?
Thanks!
  • Tasha-Bee Jan 21, 2008
    My Ctrl button and Del also seem to have stopped working on my NEC laptop keyboard. Unfortunately the solution by Chipside didn't work in this case. Any other solutions? I haven't thought of any other way to resolve this problem.
Actually it matters not what computer you have, it's the operating system that's the problem. This is a very common fault in windows 7 and to a lesser extent XP. There are a few problem areas and solutions. Firstly, forget uninstalling the keyboard drivers or checking your files with scannow or doing malware adware checks, or ctrl alt fn buttons or installing Clipspy or going back to restore points. that's all BS and a complete waste of time, these answers are usually offered up by people who have never experienced the problem and actually muddy the waters with all sorts of number lock key board this and that answers BS answers. Put-up or shut-up! You either know the answer to the problem or you don't, and you don't if you haven't experienced it. It's annoying, frustrating and shows just how far Microsoft hasn't come.
The underlying problems with losing ctrl C ctrl V arise with eithe;r Java and/or Skype, or both. 1) Skype updates knock out the control C control V function, usually with the BS click call, it's not compatible with windows 7 and has a number of conflicts that Skype, although they claim to have patch fixed, have not solved. Even their click to call conflict patch doesn't work, an error message comes up on the download no matter where you get it from. 2) Java has conflicts with Windows 7, control panel type in Java,go to updates, if the update doesn't work you will have to remove and restore Java. It has comp 3) You can sometimes solve the problem by force switching-off your computer, without going through the normal sequence, then starting it in safe mode, which may load any missing files that have been knocked out by the aforementioned Java and Skype. Failing this, and as a last resort, you're going to restore to factory restore, but remember, this will only work for a while, until Skype updates its system and bang you'll be down again. So make sure Skype cannot update, go into Skype tools, updates, turn-off automatic updates. I hope this helps. I've had the problem 14 times and lost the will to live going through the myriad of file,sequence,number lock,uninstalls,file/malware checks BS that's out there. Even Microsoft help doesn't list the problem. James
You'll finish up going to all sorts of forums and none of the geeks or pseudo geeks have much input. Forget even the retore poin
Posted on Jun 10, 2012
You have made an update, installed a new software, or have gotten some malaware that has disabled your (Ctrl/Shift/Alt) key. You get them working again, by going into the control panel of your Operating System (2000, XP, Vista) and disabling your keyboard manually and then starting-up again. Here's how you do it:
01. Go to Settings ---> Control Panel ---> Performance ---> System.
02. In the System dialog box, choose Hardware.
03. Go into Device Manager.
04. Find Keyboard in the list.
05. Click on Properties.
05. Disable the Keyboard.
Now you must restart your computer. When it starts up again, it will automatically recognise your keyboard as a 'new' device and re-apply the drivers from your XP operating system, as they were before you got them messed up.
It will again ask you to restart. Click yes. When your computer starts up again, it will magically restore whatever keys that got stuck, or wouldn't work. Tada!
Posted on May 07, 2008
  • ldhkah301 Dec 08, 2012
    Thank you! I knew something was disabling the control key--whenever the IT guy is there something goes wrong. lol I just didn't know which program it was and how to re-enable my control key. Ctrl does work with ctrl + home and ctrl + end in a Word document, however. It is being used in conjuntion with dictation software. If I hit Ctrl + Up arrow, it increases the speed of the dictation. Ctrl + down arrow and it decreases the speed. IT guy told me to get a new keyboard. Even I'm not that dumb. Thanks for your help.
Go to MS Word, word options, customize, customize, keyboard dialog box, commands not in the ribbon. Choose word right and put in an alternate to Ctrol + right like Alt + right. Type that. Do the same for word left. Choose it and put the mouse in the box to the bottom right and type Alt + left. This will give you the option of using Alt instead of Ctrl.
Posted on Dec 07, 2012
In addition to the Ctrl key not working, the Del key also wasn't working, and right-clicking did not bring up the normal menu. I tried the sticky key solution plus other remedies described on other websites, and nothing worked. Then we updated our browser to Internet Explorer 7, and that fixed all these problems (and a few more that we which weren't key-related)!
So it is very possible that the solution is to update your browser.
Posted on Jan 24, 2008
Try using the on-screen keyboard
  • 49 Answers
Sir try holding the Fn key then press F10 i think its just a numeric key to alpha key configuration
Posted on Jan 20, 2008
  • chris albert navarro
    chris albert navarro Jan 21, 2008
    lolz if my rate is locked i wont help you... just joking... if that is not the Fn key problem the sticky key on the accessibility option inside your control panel... turn if of if that suits you... if still getting the problem check he keyboard icon in control panel then click hardware tab then properties button.. it will take you to a windows that will provide info if your keyboard is working properly...
Hi I have Inspiron 6400 laptop and the problem, it...
Here are some tips
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
If the system is posting but will not boot to Windows, then try re-seating the drive, resetting BIOS defaults and running diags on the HDD (Fn+Power Button to start diags)
May 21, 2010 | Dell Inspiron 6400 Notebook
On my dell inspiron 6400 notebook, the z,x,c,v keys have stopped working. all the rest of the keys are fine. help?
just look on line for a new keyboard and you should be able to find a walkthrough on how to replace it to
Oct 26, 2009 | Dell Inspiron 6400 Notebook
Memory stick pro not recognized any more by dell inspiron 6400
I suggest going into the control panel/device manager and removing all the usb devices.
Restart the computer and let it find the devices again. That might help.
Also--have you tried the stick in another computer just to make sure it works?
Sep 25, 2009 | Dell Inspiron 6400 Notebook
Touchpad not working
Hello, my best solution would be to check ebay and order one there. If you are familiar with removing the power button bezel, do so and remove the keyboard as well. Then check the connection for the mouse. Its a small little ribbon cable coming from the mouse area.
Here is a direct link you can get these parts from:
http://computers.search.ebay.com/Dell-Inspiron-6400-touchpad_For-Laptops-Notebooks_W0QQcatrefZC6QQcoactionZcompareQQcoentrypageZsearchQQcopagenumZ1QQdfspZ32QQfromZR2QQftrtZ1QQftrvZ1QQsabfmtsZ1QQsacatZ158885QQssPageNameZRC0022QQ_trksidZp1638Q2em120
I hope you have a great day, Please rate my solution.
May 20, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Vista CD Drive Does Not Recognize CDs
Try to use dvd cleaner disk to clean the lens, if it doesnot work, i think you have to replace your drive , this happens with Dell alot. but try to clean it, uninstall then install the driver back and check if its work.
Best Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 14, 2009 | Dell Inspiron 6400 Notebook
My dell inspiron 6400 right click dosent work
Go to control panel and Mouse settings. Make sure settings are set up correctly. Same place for the Touchpad.
Mar 07, 2009 | Dell Inspiron 6400 Notebook
Computer sound not working
ah, try the FN key and holding i down then quickly pressing the end key without releasing fn, then release them.
i have an inspiron laptop computer too just an older version so this might not work, if it doesnt go to control panel, sounds,audio and etc. then go to "Adjust System volume" or one of the other ones under "Sound" which are already up when you click onto that
-CG
Jan 20, 2009 | Dell Inspiron 6400 Notebook
Can't get num lock to work on Dell Inspiron 6400
The 5th key from the right on the top row of your keyboard should is the Num Lock Key...
Dec 08, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
5,599 people viewed this question
Alun Cox
