Question about Frigidaire 24 in. PLD2560LCC Energy Star® Built-in Dishwasher
Dishwasher lock key
Ran the dishwasher and while in the drying stage the lock light came on. This happen once before and we did finally get it to turn off but not sure how. It came on again and I can't get it off. Nothing in the manual about the lock light. Please advise.
  • lockit Jan 21, 2008
    Thank you very much. Some one should suggest to Frigidaire to add that statement in there manual. What a hassel.
  • 23 Answers
To prevent a child from accidently starting the dishwasher there is a child lockout feature. Press and hold the Rinse and Hold pad (certain models) or the No Heat dry pad (certain models) for # seconds to Lock or UnLock the controls
Posted on Jan 20, 2008
    New Friend:
I tried to press and hold the heat dry button and it didn't work but when I held the rinse button a couple of seconds and then the heat dry button it turned off. Thanks for the rinse button idea kd3ke.
Posted on May 17, 2010
  • watscooking May 12, 2011
    YES! Thank you!!! I held the heat dry button for about 3 seconds and it came off as well. Your advice was just what I needed. Much appreciated.
    New Friend:
We have a Frigidaire fdb1100rhs2. Holding down the Heat Dry button for about 5 seconds worked for us. Good Luck!
Posted on Jan 06, 2014
6ya staff
SOURCE:
WDT790SAYMO dishwasher will not start. Appears locked. Help
Control Lock On
Use the Lock to prevent your dishwasher from accidentally being turned on. Use the Lock, also, to prevent accidental cycle or option changes during a cycle.
LOCK ON
When LOCK ON is lit, all buttons are disabled.
NOTES:
The dishwasher door can be opened while the controls are locked.
You can turn on the Lock while the dishwasher is running.
To turn on the Lock:
Press and hold NO HEAT DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light flashes 3 times.
To turn off the Lock
Press and hold NO HEAT DRY for 4 seconds. The light turns off.
If the lock light flashes constantly this indicates that a key (or keys) is most likely shorted or stuck. If this is the case the console or touch pad must be replaced. The console is only available in black (part number 3384340).
Jul 31, 2017 | Televison & Video
Frigidaire dishwasher stuck on heat dry
That happened to me also. The button dance did not work for me. I turned the switch on the fuse box off and waited for two minutes. When I turned the switch to fuse box on again my son two light were blinking and I told him to press the start button on the washer and it worked.
May 14, 2012 | Frigidaire 24 in. FDB635RF Built-in...
Dishwasher will not work. heated dry and child lock lights are lit up. tried holding heated dry button for 3 seconds to turn off child lock nothing happens.
Try finding the electrical circuit that powers your dishwasher. Turn off the breaker for a while (15-30 min.) This may reset the computer to factory defaults.
Apr 29, 2011 | Haier ESD310 24 in. Dishwasher
Lock on light flashing
I finally decided to calm down and use my head and managed to solve the problem. I read the instructions that are on the top of the dishwasher door. ( Smart move on my part HUH!) It said that when the door lock light is on everything is disabled. Hold the air/dry button down for 4 seconds and the lock light will go out. Guess what, IT WORKED. Here is what I learned from this. Always read all instructions. I spent $9.95 for an answer that was right in front of me. Humans can be so dumb I am!!!!
Jan 28, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwasher model 665
Ok got the solution from a very friendly rep at Sears. She was all excited because she has been out of telephone support for 2 years and just came back and remembered this problem from her earlier days. Her solution worked and she is now my favorite person in the world. Five stages...read them forst then execute!
1. Press Heated Dry 2. Press Normal 3. Press Heated Dry again 4. Press Normal again. At this point all of the lights on the dishwasher will illuminate. Now, the final stage is 5. Press Start. Worked like a charm
Dec 22, 2008 | Dishwashers
Dishwasher locked key has been activated.
To turn on Lock:
Press and hold Heat Dry for at least 4 seconds. The Locked light
glows. If you press any pad while your dishwasher is locked, the
To turn off Lock:
Press and hold Heat Dry for at least 4 seconds. The Control Lock
light turns off.
Dec 18, 2008 | Whirlpool Dishwashers
Whirlpool Quiet Partner II dishwasher
I held down the heated dry button & it worked!
Aug 26, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore elite dishwasher 665 15962990
Hold down the "HEATED DRY" button for 4 seconds to unlock.
Try to press these botton in sequence,Heated Wash, Heated Dry, Heated Wash, Heated Dry.release your hand, the unit will go into diagnostic mode. that is all leds will ON for a few seconds,and start normal operations.
If that does not work, you might need to check the electronic control board if the ribbon is seated properly.
Finally solution, is to change the electronic control board.
Jul 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Dec 29, 2007 | Dishwashers
Frigidaire 24 in. PLD2560LCC Energy Star® Built-in Dishwasher Logo
3,296 people viewed this question
Top Frigidaire Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Mike
Vitally Alcher
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
