Question about Whirlpool Ovens
ELECTRIC OVEN WILL NOT HEAT - Whirlpool Ovens
  • Whirlpool Master
  • 3,051 Answers
Hello there:
Here is some Helpful troubleshooting tips i have made up for you
Hope this is very helpful for you.
If the element looks good, then we progress to basic electrical measurements (hint: that’s an illustrative link put there for your edumucation– read it now). Y’see, Hoss, incredibly, the element can look fine from the outside (and usually does) but the inner core, the part that electricity flows through and gets really hot, can be electrically open. So, we’ll start with a simple resistance measurement of the bake heating element. To do this, you have kill power to the oven and then remove the visible and obvious element retaining screws. Then remove at least one wire from the element; you can, of course, remove the entire element from the oven, as shown in the picture (click for larger view). You’ll be making the measurements with your probes on the element’s terminals.
Measure the resistance with your meter; anything less than 50 ohms is good. If you’re seeing a high resistance reading, like something in the thousands of ohms (denoted with the “K” on most meters) then, ding-ding-ding, you just found the problem– come git you a new element.
If the element tests good, then it’s time to graduate to live tests. That means voltage on the circuit, fire in the hole, fry yo’ ace if’n you ain’t careful. If you don’t know how to safely make live voltage measurements, then stop reading right now and call a professional appliantologist. You’ll also need the wiring or schematic diagram of the oven– these are usually hidden inside the control panel compartment, some disassembly required. Make sure you’ve killed power to the oven before going any further, Homer.
Before we get into the actual live test, it would helpful for you to know how the bake element works so you’ll have some insight into how the live test is done. A bake element operates at 240vac, 120vac is supplied to each side of the heating element. One side is tied more or less directly to L1 or L2 (both of which are tied to 120vac)– see your model-specific wiring diagram, I’m just ’splaining the strategery here.
The other side of the heating element is connected to the electronic range control either directly or through some intermediary controls. (Antique, RV, or off-grid ranges may not have an ERC but rather a mechanical thermostat. Ahh, those were the days…)
Now, here’s where the real strategery comes in. The basic idea is that when the bake element is turned on, BOTH sides of that element should get 120vac (remember, the element is supposed to have 240vac to heat up properly). So we’re going to split the problem in half by seeing which side of the bake element power circuit isn’t coughing up its 120vac. Then we shall deal harshly with its insolence.
ELECTRIC OVEN WILL NOT HEAT - 218_a1.thumbnail.jpgOk, are you ready to rock or are you ready to shock? If you’re still rockin’, here’s how we do the live test:
  • kill power to the oven (which you already did earlier, right? icon_wink.gif );
  • disconnect one wire from the bake element and then secure it so it doesn’t touch anything else
  • clip the common side of your meter to any known ground point, like an unpainted metal surface in the oven;
  • re-apply power to the oven;
  • measure voltage at both of the element power wire leads;
  • the one that isn’t giving you 120vac is the circuit you need to troubleshoot; you can ignore the other side.
See, you just cut the problem in half! Now kill power to the oven again and focus your keen, Vulcan-like squinties on the wiring diagram and locate your problem circuit. Then identify the next component in line between the end of the heating element wire with the missing voltage and wherever it ends up, be it the circuit board or one of the power lugs on the terminal block in the back of the oven. The rest is trivial. Continue applying this essential kata until you find the missing voltage in that circuit.
Posted on Dec 16, 2009
Pre heat works on smw 272 yw but oven or broiler do not heat.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101 ';';
Sep 22, 2011 | Thermador SMW272 Electric Double Oven
I have a My oven will not heat up. The burners work and the display on the oven works but will simply not heat.
heatman101 ;'
Jul 24, 2011 | GE Profile JT912SFSS Electric Single Oven
The oven does not heat up. the microwave work and everything in terms of the display on the oven works, but no heat.
heatman101 ][
May 08, 2011 | GE JTP86 Electric Double Oven
Ge oven will heat up then the pre heat will beep then oven shuts off and the time light will flash 0
heatman101
Apr 01, 2011 | GE Profile JTP18 Electric Single Oven
Oven will not heat up broiler works. its a thermador rdss oven
heatman101 ';
Mar 07, 2011 | Thermador SMW272 Electric Double Oven
Oven does not fully heat up
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
heatman101
Jan 19, 2011 | Jenn-Air JGW8130A Electric Single Oven
Oven won't heat above 160 degrees
heatman101
Jan 18, 2011 | Jenn-Air JJW8330D Electric Single Oven
GE Profile JTP85 (installed 1998). The lower heat element in the lower oven will not heat. I can make the upper element heat up by using the BROIL function, but neither element gets warm on BAKE.
heatman101
Dec 11, 2010 | GE JTP85 Electric Double Oven
The oven wont heat over 105 degrees
heatman101
Nov 23, 2010 | Maytag MEW6530DDS Stainless Steel Electric...
Unit will not heat
heatman101
gkjkgj
Sep 28, 2009 | Whirlpool RBS305PDS Electric Single Oven
Ovens Logo
438 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
