Question about HP Photosmart 8150 InkJet Printer
Printing wrong color
Our printer suddenly started printing red instead of black in areas (photos) and not printing some text at all. No rhyme or reason to it. Checked all the ink cartridges and they appear to be full and properly instealled
    Brigadier General:
  • HP Master
  • 3,614 Answers
You must do a deep printer head cleaning on your unit, it could be clogged and dirty and that because it will not produce or print out a proper color.
Let me know here again.
Posted on Dec 11, 2009
Its really not a problem as much as it is a question. I would like to know if I can switch the text color from black to another color to print documents? I am low on black and it is not printing clearly...
Try changing the font color on you word processor software (Microsoft Word) from black to say red ! Select 'all the text', change the color and print it. Should work.
Dec 30, 2010 | HP PhotoSmart C4180 All-in-One Color...
I have a Xerox 7345. Instead of printing red it
In one of these diagnostic areas you will find an auto gradation adjustment, perform that. Here are the steps.
To enter the CE mode:
  1. Press and hold the 0 key for 5 seconds, then while still holding down the 0 key, press the Start button.
    The CE Access Number screen will appear.
  2. Enter 6789 and press Confirm.
  3. The top most area of the UI display will be reversed to let the user know that the mode has changed to the CE mode
  1. Enter the Diagnostic mode.
  2. From the Common Settings screen, select Image Quality Adjustment.
  3. Select Calibration.
  4. Select the button of the Screen Type to be calibrated, that is, Copy Job - Text, Copy Job - Photo, Print Job - Text, or Print Job - Photo.
  5. Press the Target button and then select the type of jobs to be calibrated, that is, Copy & Print Jobs, Copy Jobs Only, or Print Jobs Only.
  6. WC 72XX only: Load A4 paper in the Tray 5 (Bypass). Press Save.
    WC73XX only: Select a paper size and type using the paper supply button
  7. Press Start. The auto gradation routine will run and a message will display upon completion.
  8. Take the print from the output tray. Follow the instructions on the screen to complete the color correction.
Jan 15, 2010 | Xerox WorkCentre M-24 Color Copier
Canon i950 printing many blank strips/areas where text should be
I'm afraid it looks like the printhead is broken. A quick google sees them at about £80. Compare this to the price of a new model. I think 5-6 years insn't too bad though
Mar 23, 2009 | Canon i950 InkJet Photo Printer
Black printing is printing in pinks and mauves.
try and print a document from word with different text colors say blue green and red then in bold check text in black. this will give you a clue to what is happening to the colors.
Feb 26, 2009 | HP Photosmart C4180 All-In-One InkJet...
Epson c88 how print in magenta
Do you mean "how do I print text in Magenta instead of black". Well, you change the colour of the text from black to magenta. For example in Word, you would select (highlight) all the text, click on Format, then Font. Then click on the down arrow at the side of the Font Color box, then click on Magenta. To check you have the right colour, click again on the down arrow at the side of the Font Color box, and select More Colors. Then click on Custom. Magenta has a Red-Green-Blue value of 255-0-255. Now print the document and it will come out with magenta text.
If this is not what you want, please come back with a new comment explaining further.
If this advice has been helpful, please rate it.
Jan 30, 2009 | Epson Stylus C88 InkJet Photo Printer
Canon i860 won't print deep colors
I had similar problem: everything muted and with brownish tint. Tried everything, finally discovered that I installed wrong cartridge: 6PC instead of 6C. The "photo" cartridges are pretty much the same, make sure you have the right ones: 6C, 6M, and 6Y.
Nov 17, 2008 | Canon i860 InkJet Photo Printer
HP z2100 horizontal lines where the text or object are
Check for updated firmware and drivers. Also, if all your object and text or black try changing them to color and see if that helps, maybe there is something wrong with your black printhead, the black may not be used when printing photos, the printer may be using process black for photoes and real black for black text and objects.
Oct 08, 2008 | HP DesignJet Z2100 InkJet Photo Printer
Cartridge/Printer problem - very weird (HP PSC 1315)
quiet easy you have to change you print selection to all or everyday printing that way it will print both color and black all together instead of not this and that
Mar 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
Canon IP3000, problem printing black
Try to change the default printer and check ...
Also try printing from other documents see if you facing the same problem
What version of Works you using ?
Do you have the Dic for Works ?
Apr 14, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
HP Photosmart 8150 InkJet Printer Logo
153 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
