During the spin cycle, my washer seems to spit water out through the draining hose faster than the hose can take take. Water comes out where the draing hose is. How can I stop this?
  • 57 Answers
You have no control ove rthe speed the water comes out of the drain hose, only the ability of the drain to cope with it. You may have a build up of detergent in the drain upstand which has narrowed the paerture of the pipe. Try putting some drain unblocker down the wate pipe into which the hose is, I assume, popped into.
Posted on Dec 11, 2009
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
It seems like my 1st problem may have been water spilling out during the spin cycle but that could have been a sump pump or draining spout problem. Next my problem became the spin cycle would not start. ...
Hi just read your posting.Error code 37 is called PUMP BLOCK ERROR.Which hose did you disconnect?Is your machine draining the water?Please reply with additional information and I am sure I can help you further.Looking forward to your reply.
Sep 16, 2010 | Fisher and Paykel GWL11 Top Load Washer
Ge top load washer leaks from over flow during spin cycle
check your pump it may be partly plugged if it is try to clear or replace pump
Aug 06, 2009 | Washing Machines
High speed drum rinse ..drum not spinning during rinse cycle
Clean out coin collector thoroughly. Replace drain pump if necessary. Water will drain if you can place drain hose on floor and let water siphon out.
Mar 23, 2009 | Frigidaire GLTF2940ES Front Load Washer
Help Guru Please
Ill try,
first off its normal for water to spray in during the final spin( its a spray rinse), as far as the water coming back into your machine after the final spin stops, you have an issue with oyour drain, i would assume that the drain hose is NOT going into a stand pipe"open drain", but instead clamped to another hose leading outside or to a drywell, in which case youll need to install a "one way check valve". whats happening is after the final spin is done al;l the waterin the drain line is reurning back formn the drain hose.Proper insstallation will cure this.
lastly its hard to describe"slower than usual spin" it will progressivly spin faster as moire water is removed form the machine, i wqould rectify the drain issue before i concern my self with this( and make sure you not selecting a :gentle spin" option of coarse... hope this is helpful to you!
Jan 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer does nothing during rinse then leaks during spin cycle
hi thanks for the question i would check the drain hose your problem is the washer is not draining check the drain hose thanks the appliance doc
Sep 27, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Will not hold water during initial cycle
The drain hose needs to be lifted above the high fill level in washer.The easiest way to fix this is take the drain hose (if your drain hose starts from the bottom of machine and goes up)tie or strap it to the back of the washer so it cant sag or drop down and start syphoning the water.Remember the washer will drain out the water if the drain hose is lower than the amount of water in the tub.Thats why your making sure by tieing the drain hose to the highest point before it makes it way to the drain .
May 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Apr 22, 2008 | GE WBSR3140DW Top Load Washer
Probably a main tub seal, big job!
Nov 16, 2007 | Maytag MAV7600 Top Load Washer
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
