Question about Gateway FPD2275W LCD Monitor
Monitor gone dead
My relisys TL766 TFT MONITOR HAS GONE DEAD, NO POWER TO IT
IT HAD BEEN PLAY UP BEFORE THE SCREEN ALL OVER THE PLACE
IT WOULD GO HAY WIRE THEN, GO BACK TO NORMAL, BUT THIS TIME, WONT EVEN TURN ON, I WONDER IF YOU COULD HELP
THANKS
  • pop_422000 Jan 21, 2008
    yes. thats ok. i am using an old monitor, and thats working ok
  • 48 Answers
Does your tower turn on? just check if the monitor is the cause of the problem..
Posted on Jan 21, 2008
  • Anonymous Jan 22, 2008
    hmmmmmmmmm.......... try to reseat all the cables just to make sure if everything is well placed... if it doesn't work, well, a monitor is not that expensive...
6ya staff
SOURCE:
I got horizontal lines occasionally across my Relisys 17'' TL766 black monitor,sometime they disappears when I turn monitor off and on again,sometime not,what is causing them
try to open back cover and remove / insert all connector that you can found including ribbon wire check also soldered side for possible lost contact.
Apr 10, 2010 | Relisys TL 766 Monitor
Horizontal black lines across the screen
you can try contacting Lumaco they are a British monitor repair specialist.
www.lumaco.co.uk
It might even be cheaper to buy a new one.
Jun 19, 2009 | Relisys TL 766 Monitor
I require an adapter for my Relisys TL775 LCD Monitor.
Belkin makes an adaptor for nearly everything regardless of the country. You must specify which connector you have by name and what you wish to connect to for further help. Here is a link to a UK mag review which spells those designators out for you: http://www.pcpro.co.uk/reviews/44632/relisys-tl775.html
If you need further advice please repost. Steve
Nov 30, 2008 | Relisys TL775 17" LCD Monitor
Relisys TL766 monitor. OSD menu continually open, wont close. Standby button doesnt always function.
Here is a definite solution to all those having problems with OCS menu on Relisys TL 766 Monitor.
Having tried many of the posted solutions none of which worked. The only option was to visit my local PC repair shop who disconnected the OCD monitor for UK £15.00. Spare parts for this model are no longer available. Only down side was the power indicator light in middle of now redundant control buttons does not work. Otherwise a monitor works perfectly. NO MORE STRESS.
Oct 15, 2008 | Relisys TL 766 Monitor
RELISYS TL766 17" TFT MONITOR
Hi,I have same monitor and problem,still unable to resolve, I been told to try the monitor on other PC to see if the actual problem is in the monitor or originates from the PC.
Oct 03, 2008 | Relisys TL 766 Monitor
OSD function menu is on screen and scrolling through the menu. I have a relisys TL766 17" TFT-LCD monitor. How do I solve this problem
sounds like a button is being pressed you may need to open it up and see if the inside parts are pinched or damaged
Jun 17, 2008 | Computers & Internet
I HAVE RELISYS TL766 MONITOR AND IT HAS GONE COMPLETLY DEAD, NO LIGHT SHOWING ON FRONT OF MONITOR, COULD YOU TELL ME IF THERE IS A FUSE INSIDE MONITOR, WHICH COULD HAVE FUSED, WOULS APPRECIATE ANY...
Generally inside there is a fuse on the power board. This fuse is soldered in on the board. Before taking this apart and testing the fuse or replacing power board or inverter, test the power supply to make sure it is producing the correct voltage and amperage.
If the fields of the "Brick" are breaking down this could also prevent the unit from operating.
Apr 18, 2008 | Computers & Internet
Gateway FPD2275W LCD Monitor Logo
108 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
