Question about Visonik V308XT 180W x 2 Car Amp Car Audio Amplifier
Gearbox i want to add gearbox oil to my gearbox in my car and cant find where tp put it
  • 3 Answers
What PIERRE235 told you also applies to VW...you will see a cable going into the gearbox...normally near the rear part/side of the engine...remove this and you should see a whole
Posted on Dec 29, 2008
  • 2,039 Answers
What kind of car like certain mazda you have to remove speedometer cable or sensor add gear oil untill you see oil at the bottom of the hole some gear box take heavy gear oil some motor oil 5w30 dont put to heavy oil it gonna be hard shifting when cold cheers let me know what kind of car cheers
Posted on Jan 20, 2008
I just rebuilt a 1993 Lancer wagon gearbox,what type of oil and how much should I use to refill it
90 wt gear oil. with the gearbox installed and level, open the filler plug and add oil until it starts to drip back then put the plug back in.
Mar 17, 2016 | Cars & Trucks
5-spdt M/T. Why has it stopped shifting into reverse?
Firstly check if you have gearbox oil in it seldomly so happens that a gearbox makes a noise but when it does make a kind of winding noise the gear inside the box has gotten damaged. Sometimes when lucky if you add gearbox oil the noise goes away.
Mar 09, 2016 | 1997 Volkswagen Jetta
Gearbox oil drain plug
Know where the drain plug is but cant find the place to put the oil in at the gearbox Atos gls
Apr 15, 2013 | 2007 Hyundai Atos Prime
I cant find the fill point on my 85 diesel pajero 5speed gearbox can you help me plz.
You have to access the underside of the vehicle. On the side of the transmission about 1/2 way up the side of the transmission, you will find a plug. This plug will have a square end. Remove this plug and put your little finger in and hook it down to mid way the second joint. If you feel oil there is enough, if not add here in the same hole until you feel oil with your finger.
Sep 24, 2011 | Mitsubishi Passenger Cars & Trucks
Cant find where to fill datsun 120y gear box
if it is a manual gearbox there should be a plug on the side of the gearbox,it could be either side, it is oil level as well as the filler plug,you will have to access it from under the vehicle,just screw it out & add oil until it runs out of the hole,then replace the plug.......hope this helps.....cheers.
Jul 22, 2011 | Datsun Maxima Cars & Trucks
How check oil in gearbox of a 1999 hilux
if it is a manual gearbox there should be a plug on the side of the gearbox about halfway up unscrew it & by putting your finger in & feeling down you should be able to feel the oil, if not you need to add oil, this plug is also the oil level plug, you add oil until it runs out of the hole,if it an automatic transmission you should find a dipstick similar to the engine dipstick & you add oil through that tube......hope this helps......cheers
Jun 20, 2011 | Toyota Highlander Hybrid Cars & Trucks
My 2006 vw jetta needs transmission fluid. The manual says I have to take it into a vw dealership however, the closest one is two hours away. Can I add the fluid myself and how?
1. Check and add transmission fluid on a 2006 VW Jetta with manual gearbox:
2. Check and add transmission fluid on a 2006 VW Jetta with automatic gearbox:
May 26, 2011 | 2006 Volkswagen Jetta
Gearbox
you cant ,its done from underneath with the correct computer software ,if it works leave well ,no leaks?' then it doesnt need topping up .Dont play with it ,the oil will last forever and never needs changing because it doesnt get dirty ,its only hydraulic oil which doesnt have any viscosity additives like poly meythyl methacralate.Yes dealer might say it needs changing but thats only to boost their income.
Nov 20, 2009 | 2002 Jaguar X-Type
I cant seem to find where to top up the gearbox oil on my 83 land cruiser
I dont believe thatford ********, ---get under the cruiser half way along the gear box on the left hand side you will find a bung plug 1/2way up the gearbox that is your filler and oil just dribbleing out that hole is the level.----at the back of the gearbox but attatghed to it is the transfer case this is made of aluminium,at the back of this slight y to the left about 1/2 way up is another bung that is the filler for the transfer case and also the level ,NOW LISTEN GOOD if you havea hose conecting the gearbox ******** to the transfer ******** thats good it just means the previos owner ,.or one of them had their head screwed on . W hat happens is this, strange as it seems the transfer case oil gets forced up into the gearbox,with the end result that the gearbox gets over full and the transfer gets low on oil,what we have been doing for many years is putting a bypass hose between the two fillers and as the oil gets forced up into the gear box it gravity feeds back down into the transfer case,,,so if you cant find the bungs but you have that hose you now know what it is all about, -------please let me know if that solves your problem, I know I am right but it is nice to be told
Sep 08, 2009 | 1983 Toyota Land Cruiser
Oil leakage
hi from uk if your oil ? leak is from rear of engine area ? but you say oil level in engine is ok? and not needed to top up ? then i would check the gearbox/transmission oil level? for any loss? asap it may be your leak is coming from g/box/transmission front seal ? but either way gearbox will have to come out do be able to replace both rear engine crank seal and g/box front seal at the same time ? hope this helps you don;t delay in topping oil level in trans ?
Nov 11, 2008 | 2005 Honda Pilot
Car Audio & Video Logo
97 people viewed this question
Top Visonik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Jerry Umali
ELECTRICKS
ELECTRICKS
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
