Question about RIM BlackBerry Curve 8310 Smartphone
My Verizon 8330 track ball only goes side to side and not up and down
  • 50 Answers
Dr. Cell Phone can replace the trackball on your blackberry for just $49.99 (including parts and labor). Just send in your phone for repair.
Posted on Dec 11, 2009
Cursor won't move to the right
Give this a shot- get out a couple of pages of computer printer paper, place the paper on a flat surface; lock the key pad on your curve. Place your blackberry face down on the paper and gently (don't press down) rub your phone up and down, back and forth a few times. Try your cursor now, believe it or not, this works pretty well (the paper gives enough resistance to make the track ball move). As long as there isn't a bigger issue with the track ball, this should solve your problem.
Dec 15, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
Roller ball won't work
First Try to carefully clean the track ball with a q-tip dipped in rubbing alcohol, if that does not work see if the device is under warranty before trying this next step (verify warranty by calling carrier) take a small jewelry flathead screwdriver and remove the chrome piece from around the ball and clean the entire assembly with rubbing alcohol
Hope This Helps
William
Sep 22, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
The track ball moves up and side ways, but will not roll down at all
Please select Options from the Main Menu
then click on Screen/Keyboard
then scroll down till you get Trackball, just below that you will find
Horizon Sensitivity &
Vertical Sensitivity, please increase the numbers then Save and check the effect.
If you still face the same problem you need to take the Handset to the nearest Service centre and get it checked cause it could be the problem with the Trackball itself.
Thank You.
Nov 05, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Got my trackball a bit wet and now wont work, what should i do?
You might have damaged some circuitry, but can try cleaning the trackball with alcohol and a Q-Tip. You need to roll the ball around with the alcohol-soaked Q-Tip, then let it try. This will have the nice side effect of helping drive off any leftover water, too.
Aug 13, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry 8330 unresponsive to push any buttons
you know the track ball was white when you first bought it right? the dirt and oil from peoples fingers dirty it up making it unresponsive. the silver plate around the ball pops out. when you get the ball out use an alcohol swab to clean it off. when its dry put it back in. also you should be able to get a replacement ball and plate from verizon. I know sprint usually carries them.
Jul 22, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
My keyboard and track ball do not work. I can not
Buying a new one would be very expensive. Go Visit Cell Phone Repair Center located in Dallas Tx if you are local. If you are outside Dallas you can Mail-in your Phone to them.
For more information visit www.drcellphone.com. They are the best Cell Phone Repair Service Center in the Nation.
Jun 12, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
The tracking ball rotates but it does not move over the icons on the left side. Is there anything I can do to fix this?
Depending on how comfortable you are with removing the trackball it's not hard to fix... you may have some dirt or grit interfering with the trackball and/or sensors. Take a small screwdriver or blade and gently pop the silver ring around the trackball off. This will free the actual trackball housing. Use an old toothbrush to clean everything. I also soaked the trackball in a little rubbing alcohol. Just make sure it is completely dry before reassembling. If that doesn't work you can purchase replacement trackballs from places like crackberry.com.
Apr 18, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
RIM BlackBerry Curve 8310 Smartphone Logo
169 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
