Question about Microsoft Xbox 360 Console
Cannot conne.ct to net. its first effort,test wont
Cannot connect to net. its first effort,test wont allow update download. kc
  • 32 Answers
Check all of your connections your Ethernet prongs that acually touch and enchange info (internet) might be bent causeing them not to connect
Posted on Dec 14, 2009
No audio device can be detected after installing Microsoft Vista
try download on this page:
http://en.kioskea.net/download/download-5399-drivers-for-via-ac-97
The Via AC'97 driver for vista.
Mar 05, 2011 | EliteGroup P4VMM2 Motherboard
I have an internet connection but it wont allow me to play because update wont go through
Here's how I fixed mine. When I got the message stating that the download was unsuccessful I went into settings, then network, and I tested my network connection. During a network test it automatically logs your profile out, but when the test came back good, before it logged my profile back in, it asked me to update again. I hit "a" to accept the update and it worked this time. I think the key is that it has to attempt the update before logging your profile back in.
I saw another response that makes a lot of sense too in case my own fix doesn't work. Go to the network settings screen again, lower your firewall restrictions, then retry the update.
Nov 01, 2010 | Microsoft Xbox 360 Console
Y wont it let my xbox update it wont let me sighn in and play online until i finish the update but it wont let it update
My xbox will not let me update the new updates. It says Cant download the update test connection then it says test connections. it still doesnt work
My computer wont download updates for games, ive only just got my computer. I downloaded and installd Steam fine, but when i came to have to download an update, it wont download. Also, I tried to download...
Steam may be getting blocked by your antivirus program, try getting to the blocked programs list in the antivirus program and allow Steam to connect to the internet.
Jun 20, 2010 | Computers & Internet
How do i check acer net connection
Go to "My netwok connections and see the conn. you are looking.
If the conn. is wireless?
Feb 21, 2010 | Acer Aspire 3680 Laptop
Developing an application with vb.net 2008 and i'm finding it
You need to set up an ODBC DSN and use this in your connection string then instantiate an ODBC connection. For example:
Dim MyConnectionString As String = "Driver={MySQLDSN};SERVER=localhost;DATABASE=MySQLDatabase;" '
Dim conn As New OdbcConnection(connectionString)
conn.Open()
Dim da As New OdbcDataAdapter("SELECT * FROM Customers", conn)
Dim ds As New DataSet()
da.Fill(ds, "Customers")
dataGrid1.DataSource = ds.DefaultViewManager
conn.Close()
Sep 04, 2009 | Microsoft Computers & Internet
My PS3 wont even start the latest system update, COD WAW (Error)
First try to update the PlayStation software itself and then update the COD.
Due to specs of PS3 soft none of updates will allow background download. and make sure that your internet connection is uninterrupted, I sugest u to use wired connection rather than wireless, and while update is in progress try to keep all other internet connection requiring equipment offline for smoother process.
Update me about your progress
Good luck
Jun 22, 2009 | Dmm Call of Duty: World at War
How to connect vb with ms access
se Adodc OR Even better.. ADODB. for this you need to get MDAC fromMicrosoft free download.(check under project_References- Microsoft DataActiveX objects.. the current no is 2.8. if it is not there download invb directory.
next, you can learn about creating a DSN from control panel, ODBC. onceyou learn this, connection becomes a piece of cake. get some free vbtutoriasl from WWW.
then
you need to use DAO or ADO to connect to the database. better study both but since ADO is current, i am showing that code.
under Menu Project_References, put a check mark on Microsoft ActiveXData Objects latest version (though it works for all, currently 2.8with sp pack 1 ).
at the general declarations:
dim conn as adodb.connection, rec as adodb.recordset, esql as string,esql1 as string
Private Function connect()
Set rec = New ADODB.Recordset
Set conn = New ADODB.Connection
esql = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & "D:VBDesigndhana2.mdb" & ";Persist Security Info=False"
'here you put the correct path of your mdb file. and check if you have jet 4.0
conn.Open (esql), , , 0
End Function
private sub form_Load()
connect
end sub
and for adding records:
say let us say you have 3 fields. then have 3 textboxes and 1 command button on the form.
private command1_click()
esql1="select * from Yourtablename"
rec.open(esql1),conn,, adOpenDynamic, adLockOptimistic
rec.AddNew
rec.Fields(0) = text1.Text
rec.Fields(1) = Text2.text
rec.Fields(2) = text3.text
' you need to check if in your access table design you have Allowed Zero length .. set it to Yes for all text fields.
rec.update
if not rec.eof then rec.movenext
rec.close
conn.close
set conn to nothing
end sub
this will add new records to access table from VB.
' for picture store the full path of the path and the picture file nameint the text field. and in the picturebox of VB form for viewingrecords again you need ADO or ADODC and here you code:picture1.picture=Loadpicture(rec.fields(3) ' depending on where thepicture field is located. you need to make a few trials.
End Function
connect
end sub
and for accessing records:
esql1="select * from Yourtablename where id =" & val(text1) ' for integers
esql1="select * from Yourtablename where name=" & "'" & text1 & "'" ' for string
rec.open(esql1),conn, adOpenstatic, adLockreadonly
label1.caption =rec.Fields(0)
label2.caption= rec.Fields(1)
label3.caption= rec.Fields(2)
rec.close
conn.close
set conn to nothing
end sub
' similarly there are routines to ADD, Delete, Edit, View etc.
Feb 26, 2009 | Computers & Internet
Cant route to addresses in certain cities
Perhaps it is just a matter of old maps. According to the Magellan web pages, new maps will be available for download and update in August 2007.
Jun 21, 2007 | Magellan RoadMate 6000T Bluetooth GPS...
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
