Question about Profile AP1200 Car Audio Amplifier
Wired amp up and turned car on and it right away goes into safe mode ( the red light comes on). i am trying to run dual ap1200 amps and i tried it single and it does the same thing. its not the car wiring i think it may be something with the amp but im not sure.
    Novelist:
  • 108 Answers
The first diagnostic move is to remove the speaker connections and try it that way.
(The Amp is like a battery, if the + and - connections don't have enough resistance between them, it fries.)
If it still goes into Safe Mode, there is something wrong with the Amp, power source, or signal input. If it dosn't go into safe mode, be shure your speakers have sufficient resistance, Ohms, for your amp.
The amp will have a minimum resistance for speaker, and the speakers will have a Wattage and resistance. The key is to get the resistance as close or higher than the amp requires, and the wattage as close or less than the amp can supply.
The further from equal ratings will reduce performance. ie: a 200Watt speaker on a 100Watt Amp will only make half the sound it's capable of; and equaly, an 8 Ohm speaker on an amp that can handle a 4 Ohm speaker will only play half as loud too.
(Going beyond these capacity limits requries you to regulate the power output manually, or risk blowing something up.)
FYI: A few laws of Resistance.
Two speakers hooked together in parallel, (All positive connections together and all negative connections together), will provide half the average resistance so 8 Ohms + 8 Ohms = 4 Ohms.
Two Speakers hooked in series, (Positive of one speaker hooked to positive terminal on amp; the negative terminal of the other speaker hooked to negative terminal on amp, and remaining terminals of each speaker hooked together), will provide the sum of all the speakers resistance, 8 Ohms + 8 Ohms = 16 Ohms.
Further diagnostics: Check if the amp smells. (A burnt out amp will keep a burnt out smell.)
If removing the speakers allows the amp to work, attach the speakers again, or even just touch their contacts onto the terminals briefly while it's working to see what happens.
It will work,or it won't.
Hope this helps.
Posted on Dec 11, 2009
    Sergeant:
    Champion:
  • 277 Answers
Check for earth
Kenwood kac 628 red light comes on and no audio output
The red light you describe on your amp, is the protection mode warning light. An amp goes into protect for many reasons. Here's a checklist.
1st check the fuse (s) on your amp and make sure they are not blown.
2nd check the inline fuse next to your car battery (if you have an inline fuse)
3rd, disconnect the speaker wires with amp on, does the light go off?
4th check your ground, this may be ok if you have tried another amp with the same wires.
5th.if none of these turns the protect mode off, it may be an internal fault.
you may have blown transistors and it is a tricky job to repair and costly.
Jan 28, 2013 | Kenwood KAC-628 Car Audio Amplifier
The Ground wire is hooked up right but the red light wont go off and stay green so the amp will work. It is very frusterating all the cables are the right size its is a 1000 watt amp. I have two 500 watt...
Sounds to me like the amp is going into protection mode. Try placing one sub on the amp with very little gain. One of the biggest reason why this happens is because the subwoofers are wired wrong. What is the brand and model number for your amp?
Apr 14, 2011 | Car Audio & Video
Wiring diagrams for clarion dxz535 car stereo
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
Sep 26, 2010 | Car Audio & Video
The saftey red light keeps coming on
It means that the subwoofer is blown. The red light is called the Protect light. Disconnect the speaker wire from the amp and then turn the amp on and see if the red light goes away. But if as soon as you hook the speaker wires back to the amp and the red light turns on that DEFINATELY means the sub is blown.
Apr 04, 2010 | Cadence TXA 1000D High Power Mono...
The status lights up red and then goes away, iv tried new speaker wiring as it the manual said they could have shorted, still nothing and idea as to what it could be? The amp turned off when i went over a...
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Feb 03, 2010 | AudioBahn A2300HCT Car Audio Amplifier
Unit only stays on for 4 seconds then turns itself off.
This is a short or unstable ohm load. Remove all speaker wire connections to see if the amp will stay on.
If the problem goes away when disconnecting the speaker wires try this:
1) Check volume level on zone one and zone 2 if connected. If it is too high the amp will go into protect mode and shut off exactly as you described.
2) Make sure no wires are touching any other wire or the metal surface of the amp. This will cause a short and send the amp into protect mode.
Nov 21, 2009 | Denon AVR-1705 Receiver
I have 1000 watt sony XPLOD amp and i just installed it today. with new monster cable&ground. the green light turns on& thumping goes for a little. i try to raise up just a little bit& after 2...
it isnt getting enough power and its tripping the internal switch on the amp and putting it in safe mode. either your wire isnt a high enough gauge. you might need a capacitor or you need bigger wire.
Jun 13, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Vx4004
More than likely, your speakers are wired up in such a manner that they are creating more resistance than what the amp can handle. That's usually what puts amps into protect mode.
Car speakers should be 8ohm's resistance, but if you're bridging and running a dual voice-coil sub or two subs in series... you could have inadvertedly wired it up so the amp is seeing 4 or 16 ohms of resistance? (depending on which way you went)
Try removing the speaker wire completely, then turn the amp/car on and see if it still goes into protect.
Aug 22, 2008 | Planet Audio VX4002 Car Audio Amplifier
My amp turns on and off
Sounds like there could be a short somewhere. Check to make sure that there aren't any (exposed/bare) wires touching each other or if there is a bare spot of wire touching something metal. Check both ends of all the wires. A speaker wire may have come lose and is shorting out against the frame or some other place. Usually if it goes straight into protection mode or you're popping fuses you have a short somewhere. I assume the capacitor you installed is somewhere on the power line, which would be for helping with
noise. You can also try disconnecting your amp from your stereo and see what happens but leave the speakers connected, you don't want to run the amp with out a load on it (the speakers). If your amp doesn't go into protection mode when the stereo is disconnected, then you have a problem with the stereo and not the amp, assuming you already checked for any possible shorts first.
Jun 15, 2008 | Pyramid PB1236GX Car Audio Amplifier
My sony xplod 1000w xm-1652z doesnt work anymore
First off, according to the manual, the protect light should be green. That's normal operation. If it is red, that's a problem.
If it does go red, disconnect all of the wiring to the amp except the +12V and ground. Short the remote connection to the +12V to force the amp on. If the protect light still lights red, the issue is inside the amp and will need repair. If the issue goes away, try reconnecting one wire at a time until the protect light goes red again.
Mar 23, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Profile AP1200 Car Audio Amplifier Logo
106 people viewed this question
Top Profile Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Profile Car Audio and Video Expert? Answer questions, earn points and help others
