My Janitrol 55k BTU shop heater has 3 wires coming from it Where do they go. I hooked up 2 of then and the thing starts and blows with heat, but it kicks off after about 3 minutes then back on again in 10. Never gets very hot in the shop.
    Problem Solver:
  • 19 Answers
Are the three wires labeled and what kind of stat do you have?
Posted on Dec 11, 2009
I have a 150,000 btu MasterHeater that comes on,blows good heat,no smoke then shuts down in 5 seconds. Ifyou push the restart button it does the same thing. Iknow it's related to the ignition sensor but...
Thermostat (little dime size heat measuring disk with heatproof wires) is probably a little too close to the heat source. Try to bend it back a couple thousands of an inch at a time and see if it goes longer.
Jan 11, 2014 | Master Heaters Heating & Cooling
How can I convert a Raypak B55MP 55K BTU spa heater from propane to natural gas?
You would need to change the gas valve and the orifice in the pilot assembly.
Jul 19, 2011 | Raypak Versa 55k Btu Natural Gas Millivolt...
I hooked up a coleman electric furnace to a janitrol condenser heat pump . The t-stat wires on electric furnace are red white green and yellow. I added a blue for common off of transformer for digital...
Hi, first of all you need to get a hand full of 5 amp auto type fuses and install one on the hot leg of the 24 volt secondary side of the transformer. Just use 2 female crimp on connectors and put the fuse in the middle of the hot wire. Saves $$$$ on replacing transformers when you have a dead short on the low or high voltage side of any transformer, just a trick of the trade, food for thought. Fuses are much cheaper. On your electric unit, you may not need the common on this to operate the digital stat if it has batteries. This may be your dead short. On the Janitrol condenser, the red is your 24v as you no. They are using blue in place of yellow for cooling. Red is hot, W is heat, G for fan, and blue is cooling on this Janitrol. Keep in mind you are connecting to a heat-pump also, so make sure the wiring is correct. Are you installing this for secondary Heat?? More then likely, the blue common you have added is the dead short as the janitrol uses the blue for a cooling relay in place of yellow. Anyway, use the 5 amp fuse, trick of the trade to save on the transformers. Please keep me posted, as I know know you have this under control.
Shastalaker7
A/C, Heating, & Refrigeration Contractor. Good Luck!
Feb 09, 2011 | Coleman Heating & Cooling
I have JANITROL GAS FURNACE that the MAIN LIMIT
First, replace the limit. What causes a furnace to cycle frequently would be either a malfunctioning thermostat, a shorted thermostat wire, a bad control or the thermostats heat anticipator is not set right.
Jan 30, 2010 | Heating & Cooling
We have a Janitrol gds80904bna less than 3 years old. We have had several repair people out here and none have a clue why the unit keeps running. No heat. Just fan. They want to replace several parts and I...
Make sure that there are no wires connected to the G terminal on the circuit board. There is a blower relay on the circuit board that is probably bad, replace board.
Dec 26, 2009 | Goodman GDS80904BNA Open Flame Heater
Auxilliary heat just started blowing cold air
SOund like you heating element has a open limit or the sequencer is bad. Another thing that it may be is the element wire has broken. Either way it sounds like you need a technician to come out and repair.
Jan 27, 2009 | Honeywell TH4210D1005 Heater
Vent free wall heater starves for gas
The 3/4 pipe will provide enough gas provided that it does not have a lot of elbows in the run. The more elbows you have, the less gas you have at the end of the run.
I recommend that you call the company which provides you with the gas and have them come out and look at your problem. They will be able to analyze your situatioin and make a recommendation to you. This is a free service. Good luck with it.
Jan 22, 2009 | Procom 10K BTU, Vent Free, 2 Plaque...
Built in thermostat and fuels
diesel fuel requirs a hotter spark for ignition and burns pretty dirty, better off with K1 kerosene. You could change the ignition system to a mutifuel but it's not cheap and may not mount to your current houseing but would still work. As for restarting it is one of two things: the hight heat limit control or most likely teh CAD flame sensor, both of which you can get from Mr. Heater for less than 3 bucks each. the mount for the limit control is different but you can simply remount it to your heater mount. Same thing with the flme sensor, the wires are different but you can splice the to your wire harness and it will be fine. there is no wrong way to hook them up so don't worry about ground or hot.
Jan 20, 2009 | Reddy Heater-30-55,000 BTU Variable
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
