Question about RCA 100-Watt Stereo System With 5-CD Changer & Cassette Player RS2653 Shelf System
Rca rs2653 a disc with no scratches will skip, tried cleaning
Rca rs2653 a disc with no scratches will skip, at that time cd changer will switch to next disc. i tried a cleaning disc/ didnt work
    Sergeant:
    Champion:
  • 277 Answers
Its the disktry the rubbers mite be worn
Posted on Dec 11, 2009
SOURCE:
Cd player plays for 30 sec than skips to another track or to the end track
This indicates a laser pickup assembly problem, overtime the laser becomes weaker until it cannot track the disc properly causing it to skip, one possible solution is to purchase a cd cleaning kit and follow the instructions and attempt a recovery, if this fails it is cheaper to replace the bookshelf system than have it repaired.
Oct 26, 2011 | RCA RS2653 Shelf System
When a cd is playing it skips back to beginning of cd & will not advance to next song or it skips the cd entirely & will not continue to play
unfortunately if your disc is clean and scratch free your laser will be weak and need replacing,, on that model cleaning the laser is a waste of time and money as its a sealed cabinet --check for flaws on your disc itself
Sep 01, 2010 | Sony CDP-CE335 5-Disc CD Changer
Disc will not play appears to be skipping
There is a product called a cd/dvd lens cleaning disc. Worth the investment to have around.
Be sure discs are free of dust and scratches.
Apr 27, 2010 | Technics SL-PD6 5-Disc CD Changer
The cd door is stuck as if a cd is out of place. Won't open enough to see the problem.
Before, when trying to see the problem, I clicked "skip" to see if it would go through all the discs. It did, but still wouldn't open the door. Later, I clicked "play" each time, then "skip", and after going through all 5 discs, the door opened. Go figure.
Dec 19, 2009 | RCA 100-Watt Stereo System With 5-CD...
RCA RP-9515 stereo, CD player won't play
RD probably stands for "Reading Disc" and ND probably stands for "No Disc". If the CD player doesn't recognize any discs, then either the laser is dead or the motor has died. MOst likely you will have to replace the unit.
Mar 22, 2009 | RCA 100-Watt Stereo System With 5-CD...
5 CD Changer won't work
my rca 5 cd changer skips on all cd's?
Jun 26, 2008 | RCA 100-Watt Stereo System With 5-CD...
RS 2653
I had a rca system similar to this little different. It's a problem you'll find in any cd player after awhile. You'll need to replace the laser. It's quite easy google for some instructions to replace a cd laser. Look around for a laser that can read cd's and cd r and cd rw and you'll be ok. The disassembling might be a bit tuff but it's worth it. I had to replace my hifi laser and after i did sound was incredible again no skipping. Make sure when opening your system you power it on and unplug it to make sure all charge is gone wait 30 minutes or so before you go and operate.
Feb 10, 2008 | RCA 100-Watt Stereo System With 5-CD...
Cd player on RCA R52653
overheating or lens dirty in unit buy lens cleaner cd to clean it
Jan 27, 2008 | RCA 100-Watt Stereo System With 5-CD...
Stereo won't read cds
You might try running a cleaning CD in it (which cleans the lazer lens). These are available from Wal Mart and many other sources. If a cleaning doesn't get it going, then you may have a lazer that is weakening and might need to be replaced (sorry!). Hope just a good lens cleaning will do the trick.
Jan 09, 2007 | RCA RS2652 Shelf System
RCA 100-Watt Stereo System With 5-CD Changer & Cassette Player RS2653 Shelf System Logo
574 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
