Question about Denon AVR-1708 Receiver
Cannot get denon receiver to go into dolby digital
Cannot get denon AVR 1708 receiver to go into dolby digital mode
    Sergeant:
    Champion:
  • 277 Answers
Pres the prologic button more that ojne time
Posted on Dec 11, 2009
Denon AVR - 2807 flickers in TV mode with picture & sound.
Change the hdmi cable and try. If not then you have an hdmi fault module.
Dec 15, 2013 | Denon AVR-2807 Receiver
Our denon 1708 only play on stereo mode,no sound when it select on 7 channel.. crackling on dolby. what is the problem on that receiver? please help
The surround sound outputs outputs ic's in the remainder of the system have opened, or there is a short in the speaker wiring, check to make sure that is not the case, if okay! you will need a repairman to assess the situation.
Mar 31, 2012 | Denon AVR-1708 Receiver
Denon AVR-682 center channel has no output
You may have had the receiver set to "Stereo" mode, or Analog instead of "Digital" or "Auto" (automatically switches to digital when it detects a signal) modes. Also, setting it to "Direct" (2-channel from an analog source) could result in loss of center channel. Or your Surround Parameter dial (on the higher-end Denons, at least) could be set to a 2-channel mode.
Finally, if your digital inputs are incorrectly assigned (e.g., COAX1 instead of OPT1, or OPT2 instead of OPT1) for that source, the receiver will use the Analog signal which is stereo-only. You could get a center channel via Dolby Pro Logic II but it would be a "matrixed" signal, not the "real" center channel you could get via digital input using Dolby Digital or DTS.
(If all else fails, re-check your center channel speaker wire connections. It's very unlikely, but also possible, that either the receiver center channel amp or the speaker has failed.)
Feb 13, 2010 | Denon AVR-682 Receiver
How to hook up a Wii to a Denon AVR 1708
If you are video switching through the Denon, you may need to make sure the inputs (analog, composite) are the same as the outputs. For example, you might have component out to the monitor, but composite in from the Wii. I don't believe the 1708 can do the upconversion. Try hooking up a yellow RCA cable from video out to the TV.
Dec 28, 2009 | Denon AVR-1708 Receiver
How to connect xbox360 to denon avr 1708 by hdmi cable
if you have an usb cord hook that up the your xbox then the avr 1708
Dec 20, 2009 | Denon AVR-1708 Receiver
I have the denon avr-1708 receiver and inifinty tss-1200 speaker set up. I know the speakers are hooked up correctly because it plays FM radio just fine, but I CANNOT get it to do any type of surround...
I'm not familiar with this particular model, but it should be a option (or button) labeled "input", or "input mode", or "signal mode". Can you see on display "ANALOG" or DIGITAL when you switch receiver to TV in?
Jul 13, 2009 | Denon AVR-1708 Receiver
No picture
the reason you can't get a signal is the denon 1708 will not pass the 1080p, switch the DVD output res. to 1080i or 720p and it will work
dennis
Feb 02, 2009 | Denon AVR-1708 Receiver
Denon AVR-688 Dolby Digital issues
IT IS ALWAYS BEST TO CONNECT ANALOG AUDIO IN ADDITION TO THE OPTICAL, COAXIAL OR HDMI AUDIO CONNECTION. IF USING OPTICAL OR COAXIAL CONNECTIONS BE SURE TO CONFIGURE IT IN THE RECEIVERS DIGITAL ASSIGNMENT AREA IN SETUP.
ALSO, ON THE FRONT OF THE RECEIVER IS AN INPUT MODE BUTTON, PRESS THIS BUTTON UNTIL AUTO IS DISPLAYED
Jan 03, 2009 | Denon AVR688
No dolby digitaL ON BLU-RAY FIMLS played thro a ps3,
prologic is a form of dolby digital, the 4.0 or 5.1 (versions I and II respectively) to be exact. the type of dolby version is determined by the source disk. the reciever may expand a dolby digital signal into 7.1 but it is actually a 5.1 standard, as is prologicII
Nov 28, 2008 | Denon AVR-3801 Receiver
Dts audio cd
kindly check digital settings on your dvdplayer. The output should be in digital domain. Are u using original dts audiocd or burn dts audiocd.
Oct 01, 2008 | Denon AVR-3806 Receiver
Denon AVR-1708 Receiver Logo
221 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
