Question about Sirius SP-B1 Boombox
The antenna plug is loose. how do I open up the
The antenna plug is loose in the back of the box. how do I open up the boombox..I have taken the four screws out but it seems stuck and I don't want to force it upon just in case I missed something...
    Sergeant:
    Champion:
  • 277 Answers
Send it to the suplier
Posted on Dec 11, 2009
SOURCE:
How do I open the case on a Radio Shack Presidian boombox cat number 14-108
check for a tab ( bit of paper)with a name , number or writing on it as manufacturers use it over a screw to determine if the unit has been interfered with when a warranty claim has been made
pressing in the center of any paper stuck to the back may reveal a hole underneath in which will be the last screw
Dec 29, 2015 | Audio Players & Recorders
Repair
Fist you flip the cube so that you are looking at the battery charger. There will be four allen screws on the box and four on the outside tubing. Remove all eight of the screws. You might have to use a small hammer to remove the tubing. By removing the tubing it will be easier to get to the inside of the radio. Then open up the charger door, there will be eight philips head screws. The four on the outside need to be taken out. The four that look like they are holding clips on do not need to be taken out. Then the whole back should come off. Be careful the aaa battery thing that keeps the time right is connected with a red wire is kind of tight, that is why taking the tube off helps. You should see the aux plug in on the side. Use hot glue to reattach the plug in. Then put the metal outer piece on if you still have it, if not I guess just be careful when plugging into it. You should be good.
Jun 17, 2013 | Bosch PB10-CD Radio/CD Boombox
Where can i fine antenna replacement for sony xplod cfd-g505
Go on line to the SONY website and request the parts list for your boombox. THen order it!
Jan 01, 2013 | Sony CFD G505 Boombox
My Crosley CR66 won't come on after being plugged
TRY THE SWITCH IN THE BACK , TRY IN BOTH DIRECTIONS !!
Sep 17, 2011 | Audio Players & Recorders
My sirius kt-sr3000 also works fine in car dock, but when inserted into it's plug+play boom box,boom it displays "antenna not detected"
Try swapping the boombox antenna with the car dock to see if you get the same problem. If yo do, you know the boombox is bad. Otherwise, its the antenna and you just need to get a replacement.
Jun 13, 2011 | JVC KT-SR2000 SIRIUS Radio Receiver
MY BOOMBOX KEEPS TRYING TO ACQUIRE A SIGNAL AND WON'T PLAY
Check the antenna plug in in the back of the unit ! There is a very fine wire that sticks up in the middle of that jack ! It is very easy to bend it over losing a good solid contact to the antenna ! Also these things run very hot ! Carefully remove the speaker grills and the two screws they cover. Then you can open them up and drill cooling holes in the housing to let them shed some heat !
Jan 19, 2011 | Sirius Hoods Sportster SP-B1 Boombox
Just purchased new xbox. Xbox live was working fine when hardwired, but computer and xbox will not work thru wireless. It finds the router, but when I try to open the internet or connect to xbox live it...
I had a similar problem a while back with a netgear gateway. All four ethernet ports on the back worked but it wouldn't work with wifi. I had taken it apart and found that the antenna solder point had came loose. If the antenna isn't hooked up it won't send out a signal. Mine broke because it fell off of the back of my tv
Sep 15, 2010 | D-Link AirPlus DI-524 Wireless Router
Fm rod antenna
Hi, The antenna can be replace ,in which you have to open the back cover of the appliance and you get the antenna from an electronic shop
May 19, 2010 | TruTech T350B Boombox
Need to disasseble my subx2 boombox to replace the attenna plug found only 3 screws under the handle and its not releasing
After dissassembling my subxr2, I have come to the conclusion that the issue with my antenna not being detected is in the female contact of the antenna's plug, not with the connector in the box (as I expected to find). I have not yet verified this by trying a new antenna. Here is how to dissassemble the box in any case.
Very carefully, with a small very flat screwdriver, remove the front grille of the unit. There are 8 additional screws set in deep holes that need to be removed. Once done, the front panel will pop right off.
The inside of the case is a mess of wires. You do not need to disconnect them if you do not want to.
Pry the grill off the bottom of the box. Remove the 4 screws that hold in the speaker. This will allow you to move the speaker that is in the main body out of the way.
The antenna jack is _not_ a part of the circuit board. If you look into the box, you will see a rectangular cut-out in the edge of the circuit board. There is a wire with a silver connector that is held in place by 2 screws. Remove those screws and you are now holding the antenna jack.
Feb 23, 2010 | Sirius SUBX1 Universal Plug and Play Boom...
Sirius SP-B1 Boombox Logo
178 people viewed this question
Top Sirius Audio Players & Recorders Experts
Larry Alex
Level 1 Expert
Tom Chichester
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
