Question about Acer Aspire 3680 Laptop
I have an Acer Aspire 3680 and about a month ago I had to replace my hard drive because it said a failure was immiment. I ordered the recovery disc from acer and totally re-done my laptop. Well last night, I had that blue screen pop up and it said a problem was detected and windows had to be shut down. The error it gave was KERNAL_DATA_INPAGE_ERROR. Tech data...0x0000007A, 0xc0000185, 0x18349884, 0xC000E000. Physical memory dumped failed with status 0X0000185. Now all of a sudden its saying the same thing like before that a hard drive failure is immenint. Why is this happening if I just replaced my hard drive? Could it be going out again? Im at my wits end with these problems, I even done another recovery and and it continues to say my hard drive is failing. When Windows ran the memory diagnostics tool, it said no problems detected. Im at a loss and don't know what to do next...please any detailed help will be greatly appreciated.
    Problem Solver:
  • 14 Answers
Whilst this error can occur due to a faulty hard drive or corrupt page file, but is also a symptom of faulty RAM memory. Unless you have heard "clunking" noises from your new hard drive, its unlikely to be the new disk this time.
Re-seat the memory first. If you have two memory modules installed try removing one at a time (see page 67 of the manual here ftp://ftp.work.acer-euro.com/notebook/aspire_5600/manual/AS%205600_3680.pdf )
Check the System Log in Event Viewer for additional error messages that might help pinpoint the device causing the error. Disabling memory caching of the BIOS might also resolve it. Finally, if all the above steps fail to resolve the error, take the system to a repair facility for diagnostic testing. If you the laptop is overheating, or you can't hear the fan running then fan failure might also be a possible cause.
Posted on Dec 11, 2009
I have an Acer Aspire 3680, I had to do wipre my
sounds like the hard drive still when i re install on mine i take out hard drive re instert juast to be sure its in nice and straight no bent pins ect pop in your windows disc and turn on it normally says press any button to boot from cd so tap a button then you should follow the guide for install not repair then do quick format it wont take as long and is goos enough let it go to the point ware you can see a basic list of size of your hdd and partions just allow delete every thing then you should just see unpartioned space if 40gb then it would be 39000mb ect then install there that makes sure that nothing else is on you hdd that could mess with the boot if you are still not sure email me and i can send you a more detailed set by set guide its shaunhoop1981@googlemail.com
Jun 05, 2010 | Acer Aspire 3680 Laptop
Failure to bootup
This message means that the computer could not find the MBR (master boot record) & the most likely cause is a hard disk failure. To prove this obtain an installation disk of an operationg system, say Windows XP, place the disk in the drive, and while its booting up, press F2. From the menu set the boot order to... 1. CD rom drive. Save and exit. The machine will now begin to install the operating system to your hard drive. If you get the same message again, you have a hard drive failure and it will have to be rep-laced.
Apr 05, 2010 | Acer Aspire 3680 Laptop
SMART Failure Predicted on Hard Disk C: WD800BEVS-22RTSO WARNING: Immediately back-up your data and replace your hard disc drive. A failure may be imminent Press F1 to continue I am able to get to the...
Hi:
Your hard drive is in dire trouble, and often you can still recover files from it sometimes. One suggestion is to buy a new hard drive, install your operating system on the new drive, and get your computer up and running, then install your old hard drive as a secondary slave hard drive and see if you can copy your files to your new hard drive.
Nov 19, 2009 | Acer Aspire 3680 Laptop
I have an acer aspire 3680. I started up my computer and it said replace hard drive, immenident failure possible. It gave me the option to run startup repair but as is going thru the process, its keep...
Sounds like a virus. Remove the drive from the laptop and connect it to another computer using a USB cable. These cables can be purchased for around $20 from tigerdirect.com or compusa.com. After it is connected, scan the drive for viruses using your desktop antivirus program. If you do not have an antivirus program, I recommend that you download Microsoft Security Essentials for free from Microsoft's download site. http://www.microsoft.com/Security_Essentials/
Nov 17, 2009 | Acer Aspire 3680 Laptop
Acer aspire 3680 can't find op system
THE CMOS BATTERY IS BAD REPLACE IT AND REBOOT SYSTEM.
THE SYSTEM DOESNT SEE A HARD DRIVE, CHECK THE CABLES TO THE HARD DRIVE CHECK THE POWER CONNECTIONS
FILL THE HARD DRIVE SEE IF YOU FILL MOVEMENT, IS IT WARM,
POWER SUPPLY MAY BE ANOTHER ISSUE
NO OPERATION , NO SYSTEM, NO CONFIGURATION, CMOS CLEARED, POWER SURGE, LOSS OF POWER,
ROD
Jan 11, 2009 | Acer Aspire 3680 Laptop
Acer Aspire 3680 start up
This is generally caused by a hard drive failure. You can try to repair or reinstall the operating system with your recovery or operating system disc. If you have any issues or problems during or after the repair/reload then the hard rive has failed and will need to be replaced.
Jul 20, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Complete Restore
http://www.acerpanam.com/us Go to that website and click on "eRecovery Disc Purchase". Acer does not come with recovery discs. It only comes with a recovery partition from which you can make recovery discs. If they discs were not made you'll find the provided website useful. If you're trying to recover from your recovery partition, then continuously hit the F11 key at startup. This F11 option is not always displayed. If this doesn't work then your hard drive is corrupt or damaged and you will need the discs (and potentially a new hard drive).
Apr 13, 2008 | Acer Aspire 3690-2196 Notebook
CAN NOT GET INTO WINDOWS
Try reseating the memory modules and hard drive and see if this helps. If not, get back to me.
Thanks!
Ron-
Nov 25, 2007 | Acer Aspire 3680 Laptop
ACER ASPIRE 3680 WINDOWS ERROR RECOVERY
hi
you said u did try to press F2 or F8 to get to bios setting, are you saying pressing these would not open bios setting windows?
shakeel
Nov 06, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
261 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
