Question about Saeco Starbucks Sirena Espresso Machine
My SERINA leaks WATER . IT only leaks water when the POWER IS ON. PLEASE NOTE: The water is coming from the cavity of the machine, not from between the tank and the machine. 3 Weeks ago I contacted a SAECO tech rep and she sounded quite sure that the black cupped washer that sits under the round plastic housing (on the machine) where the nipple on the tank enters the base of the machine. I purchased two washers, one for a spare, and she shipped them to me here in Mexico. I installed the washer and reinstalled the washer and the machine still leaks when it is turned on. i'm hoping your expertise will help me solve the problem, properly. Cheers, Collin
  • collinmex Dec 12, 2009
    I removed the new lip seal (32) and the existing 'O' ring (18). I cleaned the O ring and replaced it. I replaced the lip seal with another new one (Saeco shipped me two). The leaking has either stopped or is reduced to a very, very slow dribble.
    Please tell me, is it possible that the #22 'O' ring would also contribute to the leak?
    Please tell where I would order new seals for the Sirena if I need them.
    Thanks for your assistance.
    Collin
  • collinmex Dec 13, 2009
    I have allowed the Serina to be tested to see if the leak has stopped. As of this morning the problem still exists. The machine is STILL leaking.
    Could the problem originate from within the machine and not the tank-to-machine connection?
    Please advise.
    Collin
  • 530 Answers
I hate it when my espresso machine leaks. Ruins the whole day!
The link below is a parts diagram of the Starbucks Sirena machine.
Could you locate the washer you have already replace. I just want to make sure we are talking about the same washer. I'm looking at #32, "Lip Seal".
Also if you don't have a diagram check it against what you removed and replaced. Do you remember #18, "O-ring". If you did not inspect this closely you may have missed cracks in this O-ring seal.
It may be something besides the washer or it could be that the washer wasn't seated properly.
Let me know what you remember.
http://www.saecoparts.com/user/Sirena%20SIN%20025RX%20explodeddiagram.pdf
Posted on Dec 12, 2009
  • david mcclellan
    david mcclellan Dec 14, 2009
    The link below should be able to supply the the parts you might need. As long as they are available as a replacement part. However "O-Rings are not really designed to fit a particular product. Most things that call for an "O-Ring" are designed around an existing size available. You can get them at just about any hardware store. The seals are a different matter. Again check the link for those.
    It is interesting that after you installed the seal the leak was reduced. This could mean a couple things. It could be that you overtightened the O-Ring and seal. They really don't need to be tight to make a good seal. Also you may have cleaned the O-Ring to much. A dry O-Ring is almost as bad as a cracked one. Use a little Vaseline on the O-Ring and reinstall it.
    If this doesn't work it could be the other problem which is one of the surfaces that seal up against the seal or O-Ring is compromised some how. This could be from a warp or crack it the surface. In which case it's not ever going to seal properly until the surface in question has been replaced.
    It's hard to say whether #22 O-Ring could contribute to your leak. But to be honest for what O-rings cost you might as well replace it. It certainly can't hurt.
    I have researched your problem and didn't find anything that mentioned any ongoing issues like yours. But you might want to inquire from saecoparts and see if they know of anything other then what you have already tried.
    I also posted a question in a forum but I haven't seen any reply on it yet.
    Please let me know what happens if and after you try anything here.
    I will post anything I find in the mean time.
    http://www.saecoparts.com/StarbucksSiren...
Bosch dishwasher shows an error message E15. Any suggestions on how to resolve the issue. We've cleared the E15 several times by tilting unit and removing water, but seems to reappear
E15 is a leak into dishwasher base. Leak can be as simple as using to much soap powder or a split lower spray arm to more expensive fix of a leaking sump base or wash pump. Need to pull dishwasher out of cavity, remove side panels and front kick panel and run machine and watch base to see where leak is coming from. Have had them leak from 4 main places. Heat exchanger where large plastic nut screws from inside. Bottom of wash pump. Plastic sump base (mainly towards front of machine. And last place is a small pin hole can develop in stainless base of machine towards front of dishwasher. Check soap usage and lower spray arm for splits first.
Dec 29, 2017 | Bosch Dishwashers
Tip
Flashing Light Error on Tasimo Coffeemaker
That blinking error light! I still could not fix it with the other solutions.
I cleaned it, refilled it, and nothing worked.
Here is what I have done that made it work.
There is a floating magnet in the water reservoir. When it drops down,
the error light is SUPPOSED to come on.
I found by jamming a scrap piece of clean plastic in the magnet cavity on the water side of the magnet. This forces the magnet to stay in the up position AND against the sensor contained in the machine itself. NOW the error STAYS OFF. Hurray! So far, it works!
Note: You must monitor the water level under this new circumstance because the error light will not come on even if the water level drops down.
RW
on Sep 28, 2010 | Braun Tassimo Coffee Maker
Replace Water Tank
Connie .. I have a 4070 and I suspect yours is the earlier model (CVA615 ?) and so I'm not so familiar with this model. Nor have I had a water leak like this. Before you buy any parts you need to establish the source of the leak. It could the seal where the tank engages with the unit or anywhere downstream of this in the water path. Replacing the tank may be expensive and may not solve the problem.
Connie .. I have a 4070 and I suspect yours is the earlier model (CVA615 ?) and so I'm not so familiar with this model. Nor have I had a water leak like this however its likely to be an o-ring seal. Replacing the tank may be expensive and may not solve the problem. So before you buy any parts you need to establish the source of the leak. It could the seal where the tank engages with the unit or anywhere downstream of this in the water or steam path. If you're NOT TECNICALLY QUALIFIED you should call Miele and make sure the water is present when they come. I'm technically qualified and have experience working on mains voltage appliances and so I would attempt this service as follows. 1. Locate mains supply and disconnect appliance. 2. Remove appliance from kitchen unit and place on table. 3. Remove top and rear access covers taking very careful note of where each screw comes from. Note: You must replace each screw to its correct location to ensure the machine is properly earthed/grounded. 4. Remove all water from bottom of unit. 5. Re-fill water tank and leave for a day or two (no power connected). 6. If water appears at the bottom then you need to locate the source by inspecting the water path. 6. If no water appears then you know it's a problem when water is pumped around the machine or steam is generated. To test the next stage replace all covers, leave on bench, connect power and use as normal. Note: NEVER CONNECT POWER TO MACHINE WITHOUT ALL COVERS IN PLACE AND EARTH/GROUND WIRE CONNECTED. After making a couple of coffees, check to see if water has appeared in the bottom and then turn off machine, disconnect power and remove access covers. Trace the flow of water to the module or seal that is causing the leak. The above tests should pin point the source of the problem and what parts need to be replaced from Miele. Regards
Nov 21, 2013 | Miele Coffee System
How do you clean pump on whirlpool. 6th sense
Hi
On the bottom right corner of the machine you will have a drain filter.
Flip open the door. It opens vertically from top down.
Please note if your pump is blocked there will be water in the machine which has not drained out. When you twist open the filter anti-clock wise, all the water will gush out. Be prepared for this with towls and mopps. Also open the filter dial, slightly at first and only allow the water to trickle out at first. Once the water is all out, open and pull out the filter. Clean out the flilter and the cavity. Look into the cavity with a torch and make sure everything is clear.
Put back the filter.
Start your machine on the "Drain" cycle only. Check to see if you can hear the water pump working. If there is no noise, then the pump needs further investigation. It may even be faulty.
Oct 26, 2009 | Fisher and Paykel Washing Machines
My front loading GE WASHER WILL NOT DRAIN OR SPIN THIS MACHINE ISN"T VERY OLD WHAT COULD THE PROBLEM BE?
A common occurance is blockage of the water pump propellers. Check your machine's manual to familiarise yourself with the drain filter.
Please note by openning the filter, the existing water in the machine will drain out on to the floor. Be prepared for this with towls and mops.
Clean out the filter. Use a torch to look into the cavity and make sure nothing has gone through the filter to the pump propellors.
Once the filter is clean and all the water has drained out. Start the machine on spin cycle. If you can hear the water pump working then all should be well. If there is no sound from the water pump, it needs replacing or further investigation by a technician.
Good Luck.
Ash
Oct 21, 2009 | GE WBVH6240F Front Load Washer
Pool of water at the bottom after is is ran
Where is the pool of water. At the bottom of the dishwasher (inside) or on the floor (outside)??
I'm assuming outside...You'll need to determine if the water is coming from the door or out from underneath the unit.
If it is coming from the door, this is usually the door gasket. Easy to replace and not too expensive!
If it is coming from underneath, then the leak is coming from a seal around where the motor shaft penetrates the interior cavity or there is a crack in the cabinet cavity itself.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 18, 2009 | GE Nautilus 24" Built-in Dishwasher
Serina espresso machine water low light won't quit blinking
It just needs to be reprimed...put a cup uner the frother wand and turn the water nob all the way on...keep it on till the light stops blinking.
Oct 05, 2009 | Saeco Starbucks Sirena Espresso Machine
I just finished a service call for my 5312UC/UC12. The tecnician says he saw water leaking under neath the machine but hoses were secure and no visible crack to the motor housing, The machines pump works...
i am Bosch service tech you don't need a new machine the d/w is set up so if water leaks it will leak in the plastic base you have to pull it from the cavity to fix it if you have a braided water line and a little slack on the electrical you can do it. if you run the machine and get a F code on the display you have a fill fault or water in the sump most likely it is the presure switch on the side of the d/w left hand side.
call me if you need me to walk you through it
don
262-893-4840
Jul 20, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Washing Machine stops and leaks
A Clothes Washer with the complaint "Leaks in Front" (on floor) can be;
Defective Water-Pump (Very common of non-belt models) - Many water-pumps become defective due to the constant wear and misc. items becoming lodged (coins, necklaces, shoe laces, screws, etc.) or breaking the plastic housing or connections. The water pump is fairly simply to replace and is located on the inside front of the machine.
The water pump is typically a white or off white plastic and will have (2) black drain hoses connected; one coming from the tub and the other going to the drain out the back/rear of the machine. Electric pumps with typically of 2 wires going to and connected to the pump. ** Note: When disconnecting and removing the water-pump, becareful of water remaining in tub that may come shooting/flowing out.
-C
Fremont, CA
Jan 28, 2009 | Kenmore 24032\24036 Top Load Washer
Bosch WFCM 3200 Front load washer leaking from bottom of machine
I would try pulling the machine away from the wall and taking the back panel off. Get yourself a torch and then settle down on the floor while the machine runs a short cycle and wait to find out for certain where the water is coming from and at what stage of the cycle the leak happens.
Safety notes: Turn the power off while removing or refitting the back panel. Keep your hands away from wires and terminals when the power is on, and keep your hands and hair well away from the drive belt while the machine is on!
Once you know where the water is coming from and when, it'll be a lot easier to know what to do about it.
A.
May 27, 2008 | Bosch WFMC 3200 Front Load Washer
Saeco Starbucks Sirena Espresso Machine Logo
73 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
