what sort of error.. turn power off and on again ? the lense oes in and out 3 times and then says turn off power and turn on again?
if this is so, use some canned air and blow around the lens joints when turned on, turn it off and on to see if that fixed it. If not turn off power bang face down on palm several time ( no its not a joke) then turn it on again,keep doing this untill it clears it will save you $175
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned. Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal. More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc" uploaded on site http://www.esnips.com/web/papputatiyasStuffIt will be helpfull for you. Its is a step by step solution with images. RegardsMukesh
"lens error" will only be fixed by sending into repairs. 800-706-2534 and keep choosing option 2. Tell them you have a lens error and they will tell you where to send it.
