Question about Electrolux Dishwashers
It fills with water and then continues to wash but the water does not heat up.the program does not progress.electrolux esl 6114.
    President:
  • 1,214 Answers
Problem is either a bad controller board or bad heating element.
You will need to know how to diagnostic service work using a volt-ohm meter, and be mechanically handy if you want to diagnose and repair.
Posted on Dec 11, 2009
SOURCE:
I'm getting an E10 error on my Electrolux washing machine but only in the cotton cycle - it's not progressing onto the rinse and the fill times out. Is this a faulty valve or the control board?
There is problem with intake water.
Could be: inlet valve, wiring, control board
If in other programs it takes water then I would eliminate the control board and I would suspect that it is a faulty winding of the intake valve or wiring between the control board and the intake valve.
Dado
Mar 22, 2017 | Electrolux Washing Machines
My electrolux front loading washer won't go past sensing mode. What is wrong? What do I do?
Thank you for your inquiry, Sarah!
I see that your Electrolux washer will not go past sensing mode. This sounds like a possible issue with your sensor or door latch and I would recommend performing a reset on your washer to help clear out any miscommunications. You can reset your washer by disconnecting the power cord for roughly ten minutes.
I would check your door latch and door strike for any physical damage that could halt the progress of your washer. If you continue to have issues with your washer I would suggest having a professional out to perform a proper diagnosis and repair. I hope this information is helpful. -Matt
Mar 17, 2015 | Electrolux Washing Machines
Wash doesn't progress to rinse and spin
This is one of 3 faults
1 you may have a problem with the heating cycle check element
2 you might have a water valve not working
3 there may be a program fault
These videos on how to change an element and water valve will help
Jul 22, 2013 | Bosch Classixx WFL 2066 Front Load Washer
Electrolux dishwasher esl 6114 door does not lock
Hi Peter Gumbrell - Often when the dishwasher door does not lock, it is because the of door lock assembly. The door lock or latch may either be faulty or damaged. If I was in your position, I would personally recommend consulting a professional to accurately diagnose the dishwasher to determine the root cause to reduce the risk of unnecessary parts.
Mar 20, 2013 | Electrolux Dishwashers
Electrolux EW757 washing machine not working
if it not getting the required water in it will not start . only a person that can look at the system can help fix this . SORRY
Dec 02, 2017 | Washing Machines
My wmd 1050 front loader won't continue with its cycle. It fills, does a few turns, empties and finishes., all in a few minutes. It doesn't seem to wash but will spin dry when manually put on a spin dry...
Are you sure the machine is not overfilling? next step after filling would be water heating - sounds like a water heating problem if machine spins and drains ok. Maybe a coin in the wash has punctured the element? water heater can be test for insulation / continuity if you have a high voltage tester, or remove it and examine if not by releasing the nut and pulling firmly. If it is scaled, holed or black replacement will be needed. Sometimes socks or clothing stuck on the heater cause localised overheating that will make it fail.
Dec 16, 2017 | Electrolux Washing Machines
Electrolux ESL 6225
before you operate the dishwasher get your water as hot at the sink as you can this will prevent filling the dish washer with cold water and i would use powder or liquid now if you not sure of your heating element turn your washer to dry close the door for about 2-3 minutes get a glass of cold water open the door and pour water on the element if it sizzles its working
Feb 12, 2008 | Electrolux 23 in. ESL624 Built-in...
Dishwashers Logo
294 people viewed this question
Top Electrolux Dishwashers Experts
Mike
tglynn
Level 1 Expert
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
