Question about Lexmark X4270 All-In-One InkJet Printer
Printer deposit ink on paper ,long black lines
Thank you for your solution. i tried, and removed ink from the rollers,etc i'm thinking ink has prehaps leaked onto the rollers.. if you have another solution, i'd like to hear from you
  • 3,230 Answers
Can you please describe your problem in details as what you ask on your previous question.
Thanks
Posted on Dec 18, 2009
The roller under the print head has no black stuff on it. Does that mean my printer is dead?
in the properties section where U find the maintenance program is there a choice that says clean bottom roller - try that - also try using a paper towel to soak up any ink that might be on the rollers and if that is the problem just run a bunch of junk pages and the lines should eventually fade away
Apr 13, 2014 | Canon PIXMA mini260 InkJet Photo Printer
Paper jam
To fix this kind of error, remove the ink cartridge and turn the printer upside down and gently shake it.Check if anything comes out.If nothing goes, or you can't hear anything rattling around, get a piece of card stock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there. Open up the printer and clean the insides with a soft cloth and a brush. That should remove all the bits of paper inside.The teeth on the roller sides may have some dirt stuck on them which does not allow the rollers to roll freely and hence is as bad as paper jam. The idea is that the rollers do not roll whether because of paper or some dirt on the roller teeth. They have to be cleaned.
Thank you !!
Jul 16, 2010 | Kodak Esp 3250 Allinone Multifunction ( ...
Hp deskjet 5550 is always had a paper jam. what do you think is the problem of my printer? what is the possible solutions?
When removing a sheet of paper from a jambed printer, you need to be careful to slowly remove the paper without tearing the paper. This could lead to a tiny piece of paper being left behind and this will cause other paper jambs.
When this happens, the printer may need to be dismantled to remove the paper.
The other cause could be that there is uneven pressure across the rollers or dirty rollers which causes the paper to feed through unevenly and results in a paper jambs.
Check the printer for pieces of paper near the rollers and gears.
Clean the rollers, make sure there are no deposits on the rollers.
May 26, 2010 | HP DeskJet 5550 InkJet Printer
How to remove a large black line in middle of
unplug printer cables, replug in
take cartridges out, put back in making sure sure nothing is obstructing the ink dispensary on the cartridges and that they're clean
look in the printer where the cartridges go, making sure nothing is blocking the ink
check the rollers to make sure no paper is caught inside the printer
turn on printer and try this
hope this works and good luck
Apr 27, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Re: Canon Pima MP500 Printer.Despite running cleaning settings for print head and rollers ectc,I am still getting a 1cm wide line of black ink through the length of the reverse side of printed pages....
On back side of printed paper?
It means that you have an ink in paper path, i would ques on registration roller (long black roller which you can see when you open the printer cover).
Try to print 20-30 white sheets or similar to get rid of stripes
Jan 18, 2010 | Canon Pixma MP500 All-In-One InkJet...
Cannon Pixma MP500- I get a solid black line on the reverse side of a printed page. Went through all the cleaning procedures and new cartridge, no change.
For some reason, the printer is designed to dump ink into the bottom of the tray before feeding on the paper. The paper is then dragged over the ink, leaving the black line. This is a software issue, not a hardware one. I'd advise that you update all of your print drivers, as well as your firmware.
A temporary fix is to clean the rollers and base plate of the printer for ink spills.
Check for any bits of paper or debris that may be caught in the printer. Be careful to feed in the paper perfectly straight, as this printer does not have good rollers, and it will cause paper to break off and cause problems. If any debris has caught or absorbed ink, it will cause the back of the paper to smudge, and you have black lines.
Jun 23, 2009 | Canon Office Equipment & Supplies
Printing (text suddenly blurry bold after closing lid).
open the toner access door remove the toner, slowly lower the tone access door and ensure that the top roller (charge roller) is lowering straight. the roller in the bottom of the cavity (the transfer roller) push down on this to ensure that it has spring tension. if the top one is level and the bottom one has tension then you'll need to change the high voltage power supply.
Jan 15, 2009 | OKIFAX 5780 All-In-One Led Printer
Big black line of ink prints on the back of the paper. Help!
This is caused by a blocked or full "Ink Absorber". I replaced mine myself and took a few photo's. Any waste ink is absorbed into a large area under the paper delivery rollers at the front of the printer. If there is a blockage or it becomes full it leaks out onto the front rollers creating the famous think black line.
The ink flows along the red arrows. http://i296.photobucket.com/albums/mm189/Shadeyman67/DSC00495.jpg
And out into the ink absorber here.
http://i296.photobucket.com/albums/mm189/Shadeyman67/DSC00493.jpg
The blockage in my printer.
http://i296.photobucket.com/albums/mm189/Shadeyman67/DSC00494.jpg
Hope that helps some of you.
Dec 13, 2008 | Canon Pixma MP500 All-In-One InkJet...
Black ink is faint
First I would suggest performing any head alignment functions with your printer's menu to be sure you have the stepper motor feed adjusted properly. Use the paper you are currently printing on for this procedure so that the thickness of that paper is factored in.
If you stil see the banding after doing this, you can use the Advanced Media Control button under Printer Settings in ColorBurst to fine-tune the paper feed adjustment. Print out the "Media Advance.tif" target (located in the ColorBurst/images & Targets folder) to use as a guide. For white bands, you'll need to enter a negative number (to shorten the paper feed).
Dec 12, 2008 | Xerox Phaser 6110 All-In-One Laser...
Ink blots deposit onto feed rollers which in turn transfers to all new prints
Most likely you have a leaking print cartridge (toner cartridge). Does it have the same problem if you use the Manual Bypass tray?
It could also be a worn fuser sleeve that is causing the print defect...the fuser would need replaced in that case.
Sep 30, 2008 | HP LaserJet P2015n Printer
Lexmark X4270 All-In-One InkJet Printer Logo
14 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
