Question about Mtd 22" Yard Machine Push Mower
No spark to plug already try diffirents plus
No spark to plug already try diffirents plugs i put the agaisnt a bolt to see if it was getting saprk and it wasnt
  • 437 Answers
It have done a test to check and see if the ignition module is working. And by your result it is not, you will need to find the engine numbers on the blower housing to start to find a new one. J19lm is the proper plug.
I would also check the control cable to make sure it is pulling back far enough to open the stop switch on the motor.
Posted on Dec 11, 2009
I'm not getting any spark to the spark-plugs, help?
Check several things first. The coil or module (not sure which one your car has off-hand),or rotor and cap, Let me know if that isn't it, and we will go from there.
Jan 03, 2011 | 1990 Chevrolet Lumina
Timing belt busted and replaced belt, OBD 2 shows that # 3 spark plug misfires. Possibles causes # 3 valve damaged if correct plz reply
yes its possible, start by checking the spark plug and if the saprk plug wire is shorting down in the tube. if all is ok, then check compression.
Jun 27, 2010 | 2000 Hyundai Elantra
Where are the spark plugs located
SAPRK PLUGS ARE LOCATED UNDER THE MANIFOLD. UNBOLT THE TOP PART OF THE MANIFOLD, TAKE OFF THE CLAMPS REMOVE THE MANIFOLD AND THERE IS A LONG BLACK BOX THIS IS YOUR COIL PACK UNBOLT THAT AND PULL IT UP AND YOU WILL SEE YOUR PLUGS.
Jan 31, 2010 | 2002 Saturn L-Series
Spark plug location in a 2001 ford escape
Need to remove upper intake manifold to reach valve cover close to firewall.
1) The location of spark plugs 456 are under the plastic shield in front of the engine. It takes an 8mm socket to remove the three bolts holding the shield once the shield is removed you will see a coil for each spark plug. Use the 8mm socket and remove the coil and rubber boots. You will now see the spark plug (note there are not any spark plug wires).
2) The location of spark plugs 123 are located to the rear of the eng. You have to remove the air intake manifold in order to get to the spark plus. Remove the throttle wire then remove the other items on top of the intake manifold.
Nov 16, 2009 | 2001 Ford Escape
How do i get to the three spark plugs on the back side of the plymounth grand voyager
the easiest way ids yo put the car on jack stands and go from underneath with a extension a swivel and swivel ratchet. when the engine is cold remove the plug wires and reach up between the exhaust pipe and twist and pull wires off, it is not easy. Next be prepared to buy new wire set if you have not done so already. Then take the plugs out one at a time. use dielectric grease on the end of the spark plug wire that connects to the plug put a tiny bit around your pin-ky finger and rub the new wire with the grease so it will not jump spark. next gap the plugs spray a little wd 40 on the threads and insert plugs while you have the wires off tighten the rear valve cover bolts while you have it jacked up.
Aug 17, 2009 | 1997 Plymouth Grand Voyager
97 Tarus wont start
recheck spark by putting a plug into one of the plug wires and place on valve cover, crank engine and see saprk in that plug. check fuel pressure during cranking to verify fuel supply. If you have no fuel pressure check fuses and fuel pump relay, in fuse box and power distribution box under the hood. If all are good check for power at the fuel pump connector with the key in start position, in run position the power will only be there for about 5 seconds, you are correct with fuel and spark it should run, let me know what you find
May 21, 2009 | 1996 Ford Taurus
Replace spark plugs in the 2001 stratus with a dohc engine
I think you are talking about the plug wires
Just turn it loose and pull up
Feb 17, 2009 | 2001 Dodge Stratus
Spark plus
you may have a differnt motor to the standard for your model the spark plugs that fit should be the right ones
Jan 09, 2009 | 2000 Ford Escort
1995 buick regal custom missing
you might have bad plug wires replace wires and saprk plugs
Jun 09, 2008 | 1995 Buick Regal
Mtd 22" Yard Machine Push Mower Logo
Top Mtd Garden Experts
Jim Parker
Jim Parker
lnbn1975
Morne Olivier
Are you a Mtd Garden Expert? Answer questions, earn points and help others
