I was using my wonderful old Elna 2 days ago and worked fine...now the light goes on so I know it has power to it. but nothing else happens Elna supermatic help
Http://whitesewingcenter.com/elnaparts.php
these people can help. but from what i know when looking into my Elna Supermatic 722010 is that your knee lever controls a series of reeds, the contacts must be clean, this can be viewed by flipping over the machine and taking off the base with the three screws. Next take off the hand wheel and inspect the motor's commutator and brushes. They must be clean and not scored. The friction wheel should be looked at while your in there so that it has no flat spots (that would make the growl or thumping sound) Hope this helps...
Posted on Jul 01, 2010
  • 78 Answers
Call sears
Posted on Dec 11, 2009
My D-7 will not power up...when turn it on the power light weakly flickers (as well as the power sound) for only sec then nothing. Have cleaned battery connections, used charged batteries and even to
Sounds like electrolytic capacitor dried up needs curing, which is power on capacitor and left it absorb some moisture in humidity on power. Some time a few minutes, hard cases may take a few days.
Feb 08, 2012 | Konica Minolta Cameras
50 inch Sanyo Vizon Plasma TV. Has sound but no picture for last few days. 2 years old
This set has LG insides, it will have failed on either the Y-Sustain PCB or the Z-Sustain PCB.
Quite common.
Repair estimates should be $250 - £350 depending on which has failed.
Stick it on eBay, it will fetch good money faulty.
Sep 06, 2009 | Sanyo Televison & Video
Diswasher stopped working
There is a thermal fuse on the controller that commonly goes out. If you take apart the panel, and see the computer part, there is usually a part clipped on the side with 2 wires on it. When that goes out, it acts like there is no power to the unit. Very easy and in-exspensive to replace if that's it. It's pretty common on those. Good luck
Feb 15, 2009 | Dishwashers
Elna SU
Check the brushes in the motor. My old Elna super did the same thing. We replaced the brushes and it has been working like a charm ever since. It's 40 years old and still going strong.
Dec 07, 2008 | Elna 2007 Mechanical Sewing Machine
Power Issue
sounds suspiciosly like your chord fitting is damaged(loose wires at connection)and shorting.if possible try a friends power supply with same connecter type before renewing cos could be faulty(loose)connection at pc(inside)constant pushing and pulling of connections often causes 1. loose split or disconnected wires at male connection or 2.loose pins on motherboard female connection or broken housing (not difficult to repair)more difficult to find out how to get to internal connection.
Mar 04, 2008 | Toshiba Satellite M65-S9092 Notebook
Elna Carina Zig'Zag Stitch Issue
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Bargain Box
Jan 31, 2008 | Elna 2007 Mechanical Sewing Machine
Dryer won't Start
the problem might be the start switch itself. if the switch is going bad it could have either a carbon buildup on the contacs preventing it from starting (unlikely) or the contacs are wearing out and it is more hit or miss if it will start. as time goes on the problem will get wose
Oct 31, 2007 | Kenmore 84152 Electric Dryer
Heating & Cooling Logo
180 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
