Question about Dell Inspiron 9100 Notebook
After removing screws what is trick - Dell Inspiron 9100 Notebook
  • richryan55 May 11, 2010
    trick to what? what problem are you trying to fix?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 123 Answers
What are you trying to do? If you wish to take the laptop apart you should try & get hold of a service manual for you particular machine. This makes it far easier than guessing how the machine is taken apart. You can cause more damage if you do not remove items correctly.
Posted on Dec 11, 2009
Remove impellar?
Remove back cover from motor. Hold shaft stationary with wrench or screwdriver(depends on motor) Unscrew impeller. Some impellers have a screw in the middle securing it to shaft. The screw is reverse thread.
Mar 27, 2010 | Pentair 1.0 Hp Whisperflo Pump
How do I change the gasket on the refrig door? Freezer above the refrig. The refrig is a Magic Chef with the freezer above the refrig.
take the door off the fridge fold back the gasket to expose the screws remove all the screws put on new gasket put screws back the trick is to keep the door very flat or it will warp or bend it is not hard just remember the trick...good luck..
GAR
Aug 04, 2009 | Refrigerators
Front disc screw
HI THE SCREWS THAT SECURE BRAKE DISC TO THE HUB are only for keeping the dic and hub wheel bolt holes in line when you remove wheel and do not play a part in brakes safety as the wheel locks everything to hub when secured if you have problem removing screw ? due to rounding off ? try using an impact driver tool this does the trick normally however you can drill off the head of screw and remove disc then try a good set of grips to try removing rest of screw then fit new screw but no panic if you fit new disc without screw as you can aligne wheel bolt holes b4 fitting wheel
Apr 05, 2009 | 2003 Hyundai Accent
How do you replace the elements in a Hobart 4 slot toaster? I took off the bottom but there must be something I am missing. It's awfully small in there to manuever. There has to be a trick. Please share.
No Tricks. The elements are loaded and removed from the top.
DISCONNECT THE POWER CORD
Remove the crumb dtrawers, they are handy to put the parts on so the don't roll away.Remove the temperature knob after releasing the set screw, remove the lever knob after removing the pivot screw. Remove the 3 front and 4 rear cover screws with a philips driver. note the length of the screws from the locations.
Locate the element to change, disconnect the connections at front and back on the top of the element. With a small flat bladed screw driver, open the crimp tabs on each end of the bread guides and lift up. They come out of alignment holes in the lower frame. Replace the element/s, with the correct voltage replacement. 208 and 240 elements are different numbers. Reassemble in reverse order. Be carefull not to catch the element with the bread guard wires. It's common to see a bit of smoke during burnin of new elements for a short time.
Feb 24, 2009 | Hobart ET27 4-Slice Toaster
Removal of eMachine M6410 optical drive
There are two small screws that the monitor cable would screw into, these have to be removed (7mm i believe) to be able to remove the base. The optical drive will typically pull out of the side after a screw has been removed and latch has been opened. I wouldn't go as far as removing the entire base.
Dec 08, 2008 | E-Machines M5305 Notebook
Conveyance Problem
Good Day;
Yes, there is a TRICK of removal of centerboard. Remove back cover, after disconnecting the POWER CORD, remove 2/3 screws from black chassis frame, on back bottom, release wire restraints, look for two clips on front of black chassis. Can see easier if you remove speaker grill and small panel. Remove all golden type screws from PCB. Replace IC’s STK392-570 (2).
Good Luck, big IRISH.
Sep 26, 2008 | Mitsubishi WS-55807 TV
More iris problems
I tried the cover trick with no success. I wanted to get at the iris by opening the camera . After removing a dozen screws, I could not remove the lens becauce of hidden screws. I placed the batteries back in and it works now. No more black screen.
Pierre
Sep 25, 2008 | Canon PowerShot S2 IS Digital Camera
I want to replace the joystick
nah, theres not really a trick to it, apart from sony tricking you into voiding your warranty. if you want to change the joystick, your gonna have to remove the faceplate. get a small phillips head screw driver. the first thing you should do is put the psp face down on a flat suface. next remove the two screws on the right of the console, and the one on the very bottom on the underside of the console. now, take the battery out and there should be two stickers underneath one black scrwe and one silver screw. remove the black one. now, you only have one screw left, but problem is its under neath the warranty sticker and if you remove, you remove your warranty. it is possible to take it off using a hair dryer, just so long as you dont damage the sticker. once you have the sticker off, the faceplate will just pop off so just take out the screws on the back of the joy stick, slap your new one in, put it back together and away you go!
Mar 16, 2008 | Sony PlayStation Portable (PSP) Console
Dle5932w electric dryer
the back of the dryer have about 16 sheet metal screws.remove all the screws with a nut driver.the back should come off.
Jan 08, 2008 | LG DLE5932W Electric Dryer
Dell Inspiron 9100 Notebook Logo
154 people viewed this question
Clive
Clive
Alun Cox
