I want to change all the cartridge for my epson aculaser c1100, first of all display show "cmyk toner low" , then i change a "c" toner, after that display show "myk toner low" , but how can i replace the "m","y" and "k" toner, because the machine only look "c" toner physically ... please help ...
If you wait until the colour has completely run out, you will see a message to that effect, and the correct cartride will be presented. If you wish to change before this:
1. On the
printers' control panel, press the "right" button (labeled no. 3) once and then
the "down" button (labeled no. 4) until you see the RESET MENU.
2. Press the
"right" button (labeled no. 3) once.
3. Press the
"down" button (labeled no. 4) until you see "CHANGE TONER X" appear on the
screen (where X is either C, M, Y or K, Cyan. Magenta, Yellow or Black).
4. Press the
"right" button (labeled no. 3) once. The printer will rotate the toner carousel
to the correct position for you to change.
5. Open the
printer door and change the toner as normal.
http://esupport.epson-europe.com/ViewArticle.aspx?lng=en-GB&kbid=313180&data=tgU002FqCAQg2JDh7ZlozEek9qHbvtmCoiLC
THANKS A LOT, from Bilbao-Spain
Replace Toner with gen cartridge.
Or Take cartridge back as faulty after checking that it was opened and installed correctly.
Check display on printer for indications that maybe it needs one of the 3 colour toners indicators are Y,C or M
K is black
I've just changed the Cyan colour but it now says MYK toner low. However, the cyan colour is still the one visible when I open the front of the printer so I have no access to the others to change them! What next? Would be grateful for your advice.
Thanks
Mai
Hello, we have an Epson WF-3520 and are having trouble changing the toner cartridge. When I open the lid we can see the cartridge case, but it doesn't automatically move out to where we can open it up to change the cartridge...how do we get the box to move out?
