Question about Standard Registar SD650 Color Copier
Standard SD650 Duplicator The paper tray is jammed in the down position. The tray and elevator guides are free but will not lift. The Service code on the screen reads "SC07-30" I am looking for the Service Reset Code to reset the the paper tray.
  • 10,515 Answers
The Error Code that you Got is for Friction Pad Motor Lock. This means that Either you have Defective Motor or Sensor that needs Replacement/ Repair. There is No Service Code Reset for this Error.You need to call a Professional on Site or Send the Unit for Repair.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 12, 2009
Standard top bin full?
I suggest you remove any sheets of paper from top tray then lift up and release a black plastic flap found under a plastic overhang on paper exit tray. This lever (If its not broken/missing), should be free and should drop down(under its own weight) freely. If not then it will involve using the manual to remove the top cover and find where lever is jamming (usually jumped out of a guide bearing.)
regards
carmike
Feb 17, 2014 | HP LaserJet 5200tn Printer
Had paper jammed - removed jammed paper - but nerror light still on
Before you can clear a "PAPER JAM" or "PRINTER JAM" error, you must locate where in the unit the paper is jammed.
First, unplug the machine for safety and disconnect the telephone line. Next, follow these instructions based on where the paper jam is located.
Paper is jammed inside the paper tray:
  1. Pull the paper tray out of the machine.
  1. Pull out the jammed paper to remove it.
  1. Reload the paper in the paper tray.
  2. Reinstall the paper tray.
Paper is jammed inside the machine:
  1. Remove the jam clear cover on the back of the unit. Pull the jammed paper out of the machine.
  1. Re-insert the jam clear cover.
  2. If you can not pull out the jammed paper, lift the scanner cover from the right-hand side of the machine until it locks securely into the open position.
  3. Remove the jammed paper.
  4. Check the print head's position. In the example photo the print head is positioned at the left hand side of the platen area.
  5. Gently move the print head to the center.
    Note Be careful to not force the print head to move.
    If the print head is positioned at the far right hand side, you cannot move it. Please contact Brother Customer Service from "Contact Us".
  6. Examine under the print head. If anything is found, remove it.
    Note Use a flashlight if necessary to check thoroughly.
  7. Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
  8. Reconnect the power cord and telephone line.
Note To prevent paper jams, do not put multiple kinds of paper in the paper tray at the same time.
If the message continues to appear on the LCD, the machine will require repair. Please contact Brother Customer Service from "Contact Us".
Thanks for using fixya......
Oct 26, 2010 | Brother Office Equipment & Supplies
A paper jam was not cleared in a timely manner, now the machine will only display "Error Code C0202, Call Technician" It is Saturday and I can not get a hold of anyone at our support center. How can I...
C0202= tray 1 elevator failure.
Open tray 1, check and make sure paper is loaded correctly.
With tray open, open and close front door. This will reset error code. With tray 1 open look to see if paper is stuck behind tray in back of machine, if so remove it ( this will block the lift motor for the tray).
Close tray 1, if you hear a popping noise the lift motor is damaged and will have to be replaced. Until it is replaced operate machine with tray 1 out to prevent error code.
Sep 18, 2010 | Konica Minolta Bizhub 362 Copier
Our Standard SD650 Duplicator has error code SC07-30. The paper tray is jammed in the down position. Need the reset code to clear the error
Through my own efforts & online research. Your service team never responded. I paid for live chat assistance which was not provided, and was then directed to email assistance which has been a complete joke. Please fully refund all fees charged to my credit card. I will look for other solutions to tech problems in the future.
Dec 11, 2009 | Standard Registar SD650 Color Copier
Riso GR3750
T2 indicates an elevator motor failure. Take off the back cover and check the lower limit sensor for the paper tray to make sure its not full of dust.
Reset can be done by holding the reset key down during power up.
Test mode is entered by holding down LINE/PHOTO and the M/P buttons during power up.
Test mode# 102 tests operation of the elevator motor.
Aug 27, 2009 | Eagle Signal Br1 30min Reset Timer
Hc5500 ERROR CODE S03-255
If you are talking about the first paper feed tray.. I had the same problem yesterday.. I had a loose wire.. purple.. on one of the sensors near the back.. wiggle the wires a little.. until the paper tray light is on.. the push button has a light.. I was in test mode and couldn't get the motor to go up and down in test mode either. .. turned out not a big problem.. but if one of those little wires is loose or moved it might not be making a connection ..in which case.. no motor.. If none of these things work you could have something stuck at the bottom.. there's a little microswitch to tell the machine the paper tray is at the bottom.. It's under the tray.. see if that thing is stuck or moves freely. .. Sometimes it's dead spot on the elevator motor.. manually try to move that when the machine starts.. The error comes when the paper tray is supposed to move up to the ready position and it doesn't move..
Jun 10, 2009 | Riso RZ220 Duplicator
Kodak esp 7 has a paper jam I cannot remove the paper
If you have tried the Kodak standard instructions for clearing the paper jam problem and it did not help try the procedure below.
1. Open the printing area of the printer (containing the ink cartridges).
2. The Ink cartridge holder should be to right side of track.
3. Look on left side, below the track for the cartridge that is used to
clean the print heads.It can be identified by a square black pad
approx. 1" sqaure that appears to be made of "felt".
If it is visible this is most likely your problem.
4. To correct problem locate the flat latching lever approx. 3/4" wide that
sticks up about 1/2" above the cartridge. It is locacted just behind
the "felt" square. Gently push lever toward rear which should free the
cleaning cartridge and allow the entir cartridge to move slightly
backward.
5. Close the top of the printer and cycle the printer off and back on.
If this is the problem, the "paper jam" error will now be gone.
This is such a simple fix I do not know why kodak does not inform
customers of this problem and how to fix it.
May 09, 2009 | Office Equipment & Supplies
T20-414
Check the paper ejection unit that is a T20 code T02 code would be a standard tray lift issue.414 is not listed in the book for eather code
Apr 13, 2009 | Riso RZ310 Duplicator
Paper doesn't feed
It could be a few things, but the times I've had similar problems it was either caused by the feed/gripper rollers in the paper trays being worn out, thus not feeding any paper or feeding half a sheet and then jamming.
Or, it could be that the elevator in your paper tray isn't lifting, but if it's taking paper it's probably the rollers.
Jan 12, 2009 | Canon Office Equipment & Supplies
Fault Code 08.001.44 Paper Jam
That is a failure in the maintenance kit tray area.
1. The Cap/Wipe/Purge belts have loosened up or are out our alignment. - Adjust the Cap/Wipe/Purge belts and follow the procedures outlined in the Service Quick Reference Guide for adjusting these belts and proper alignment. 2. Ink contamination or spilled wax is keeping the Cap/Wipe/Purge from properly moving. - Clean up spilled ink from the drum maintenance rails guides, sensors, and pulley belts. 3. The Drum Maintenance rail guides are out of position. - Remove and reseat if necessary. These rails may have suffered fatigue and may show signs of cracking or breaking. If this is the case it is a recommendation to replace the Drum Maintenance rail guides
The maintenance drawer itself may have the end tabs worn down from lifting up and down.
Mar 27, 2008 | Xerox Phaser 8200 Laser Printer
Standard Registar SD650 Color Copier Logo
116 people viewed this question
Top Standard Registar Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Standard Registar Office Equipment and Supply Expert? Answer questions, earn points and help others
